08-16-2008, 10:12 PM
moderator
2016 27' International
Wilton
I have a steep driveway.. Help!
I need the help of some creative thinkers! I just purchased a 2001 30' S/O. She is big and heavy! The towing part is done with my F350 Crew Cab but the parking part took me 45 minutes because of the angle of my driveway. I live in an area where my home and yard is about 5 feet higher than the street. There is plenty of parking once you get up the driveway but thats the trick. Once i get the trailer up the curb with a little ramp and across the sidewalk the rear of the trailer will begin to contact the driveway. If i remove the load bars it drops the tongue about an 1 1/2 inch. The truck is a dually so it doesnt drop much. So here is what i was thinking..
Could i use my jeep wrangler? In 4 wheel low its basically a tractor. Since the truck is so long its hard to manuever through the gate and swing it around into the shelter. The wrangler could nearly act like a forklift with its short wheel base. The tongue weight is so heavy i would never consider hooking it up to the jeep as it would break something. Has anyone ever used a vehicle in this way to move their trailer around.
I told my wife i needed to look into getting an airport tug and she was less than excited..
I need the tongue low and power to get up the driveway.. some kind of wheel other than the front jack wheel? any thoughts?
Thanks Vinnie
08-17-2008, 12:29 AM
Corona
Thanks Vinnie
Park the trailer on the street.
Install a ball mount on the "front" of your Jeep, with a ball height of maybe 10 inches, or less.
That will give you maximum control.
08-17-2008, 05:49 AM
Retired.
, At Large
Plan B would be to get a simple drop hitch ball mount to go in your receiver with a 2 5/16" ball on it. When you get home, stop out front, unhook from the truck, remove the WD stuff and hitch gear, and replace it with the ball mount. Drop the trailer back onto the ball of the non-WD ball mount. Back into the driveway. No special front hitches or Jeeps required, and total cost would be less than $50.
08-17-2008, 05:56 AM
Graham
, North Carolina
I know that the front hitch will work, a boat company down the street from me pushes some big boats with a front hitch on a lawnmower
08-17-2008, 05:57 AM
2001 30' Excella
Bedford
, New Hampshire
Use the Jeep as Andy says
I have a 30 classic and move the trailer all over the place with a small 20 hp tractor. Our barn and parking area is at least 6 feet above the garage. The little tractor pulls it very well and backs it into the barn. You don't need alot of horse power to move these trailers. Low speed and low gear will put enough torque to the wheels to move the trailer all over the place.
Mark
-Life is a journey, not a destination.
Aerosmith
08-17-2008, 06:58 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
will the jeep stop the trailer when going down hill to take it out? will the rear wheels of the jeep get ANY traction at all?
i'd go with terry's suggestion of a lower ball mount. The k.i.s.s. method works fine as long as it gives you the angle you need.
Ricky
08-17-2008, 08:22 AM
Durango
"will the jeep stop the trailer when going down hill to take it out? will the rear wheels of the jeep get ANY traction at all?"
In four wheel low/low, you probably won't even need brakes! I've winched out heavy loads and never lost traction on the rear wheels.
08-17-2008, 09:15 AM
moderator
Wilton
Thanks guys, The easiest and cheapest idea would be the truck with an inexpensive drop hitch.. just switch out in the street. The problem with that is the manuvering once you get past the gate.. not a straight shot. I will post a pic today. I have the jeep and love the idea of the front mount hitch with the front tires ability to swing the rear of the trailer around like a fork lift does at the storage lot. I think the jeep could stop it as its concrete surfaced. I do have a small cement lip to go up from the street to the sidewalk. Is there some kind of rubber tire that would take the shock a bit when attached to the jeep but helping with the tongue weight? If the tongue could remain about 8 inches in height (havent actually taken this measurement but guessing) then im clear to go up.
Thanks for all the feedback. It get me thinking about that airport tug again.. lol
Vinnie
08-17-2008, 09:47 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
can the jeeps front axle take all that tongue weight? i know with my pick-up, the plow leaves the rear wheels almost useless without ballast in the rear.
i agree that the jeep would make maneuvering a WHOLE lot easier. i use a bent driveway with a gate too!
Ricky
08-17-2008, 11:01 AM
Putnam
, Connecticut
Check the drop. You may find that a lower hitch will bottom out at the beginning of the incline if it's on a bar. How about a new drive or house to go with the nice trailer...
08-17-2008, 12:20 PM
1999 27' Safari
Kent
, Ohio
It is always the unexpected. I wouldnt try it with a jeep. The lawn tractor would be safer.
08-17-2008, 12:32 PM
1992 34' Limited
Grand Island
, Nebraska
I feel your pain! After spending a lot of money on a 75' driveway/RV pad with dump station and electric hook-up I found that I hadn't planned on the tremendous overhang of the 34' Limited. Caused some significant scraping and damage for the first few months. I decided it was unacceptable to cause further damage to the concrete and risk significant damage to the truck so I called the concrete guy back and altered the problem area (about 30'). I'm happy now although due to needed alterations on the public sidewalk and related building codes, the cost of the alteration was almost as much as the original total. For me, since I planned for long-term usage, it was worth the hassle and expense of changing it early on.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
08-17-2008, 06:59 PM
moderator
Wilton
Lots of good feedback! I really want to try the jeep for this task.. Remember the old days when trailers would have the small set of wheels on the tongue to help out the tow car? Is there anything like that, that would go with the direction to the trailer? Here are some pictures so you get the idea.
http://www.airforums.com/photos/show...?i=19984&c=509
http://www.airforums.com/photos/show...?i=19985&c=509
http://www.airforums.com/photos/show...?i=19961&c=509
New house..eventually.. driveway.. Hmm. I am not even allowed to keep my garbage cans on the street without public opinion so it would take an act of congress from the HOA to get the driveway modified. I was able to get her up there with no damage using some boards under the left side wheels. Thanks for all the feedback..
Vinnie
08-17-2008, 07:05 PM
Retired.
, At Large
Vinnie, is the area between the street and the sidewalk where it dips for storm drainage the problem?
If it is, we had the exact problem with our Overlander and Sovereign. I solved it with a pair of 5' long 2"x12" boards. I placed them over the area, and used them as a bridge for the trailer wheels. No more scraping, and it can be removed and stored in the garage.
Removing the WD bars lowers the tongue, and raises the rear, as well as allowing quicker and easier response when backing (I think you already do this).
08-17-2008, 07:21 PM
moderator
Wilton
Hello Terry, Yes thats the area. From the pictures you can almost tell where the scaping has occured. It doesnt take alot of contact to make those big marks in the driveway so i stopped right away so i wouldnt hurt the trailer. Im thinking i will try a drop hitch and switch in the street and then take in on up with boards.. $$ cheapest solution. I really like the little Kubota tractor idea but not sure i could see around the trailer to back it up and the jeep keeps popping into mind as i already have it. Im going to hitch it up just to see. Im a mechanic by trade and know that it will fully collapse my rear coil springs on the jeep but dont think it will do major damage just to lower and see. What a difference a few makes.. my 22 foot trailer went right up it.. Did someone say something about axles? are there others available that would raise her up a bit?
Thanks Vinnie
08-17-2008, 07:43 PM
Retired.
, At Large
I haven't had much to say about the tractor idea, but when we camped in an RV park that required they park our coach, and they used a 20 hp Ford garden tractor, it wasn't pretty. They had to add weights to the front to keep it from performing wheelstands, and that wasn't enough, they had to have someone ride on the hood of the tractor besides. It didn't instill any confidence in using a garden tractor as a tug.
08-17-2008, 07:45 PM
1971 23' Safari
Richmond
, Kentucky
Vinnie - not to hijack your thread but - where did you get your cover for your AS - it look great!
Digger Bear
Non impediti ratione cogitationis
08-17-2008, 07:48 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
inlandrv andy can help you with higher rated axles.
Ricky
08-17-2008, 08:00 PM
moderator
Wilton
Hi Terry, I can understand the tractor thing.. I just hooked up the jeep a few minutes ago. It kept dropping until the tires were stuffed up inside the wheel wells. There is NO WAY i can use this without some kind of wheel to offset the weight!
Digger Bear,
The shelter is from portable garage depot www.portablegaragedepot.com
Ask for Greg. He handles all the internet sales. $2300 with shipping. It was a special.
I bet the axles are expensive. The coach hardly has any miles on it as it has been sitting since 2003 and its an 01'. I guess time can affect them as well.
Thanks Vin
08-17-2008, 08:10 PM
Corona
Digger Bear,
Thanks Vin
Vin.
A parked anything that uses torsion axles, can ruin them, simply because it sat.
Rubber must be exercised in order to stay alive.
The following article, will teach you how to check out you axles in 15 to 20 seconds, without taking anything apart.
Dura Torque Axle
We have provided replacement axles for 2005 trailers, that were just "parked."
If your axles are finished, new axles with a different starting angle, can raise your trailer sometimes as much as 3 to 4 inches. It depends on how bad they may be now.
