Old 03-02-2009, 01:21 PM   #1
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
Cool I am towing this year with a yukon!
It has 3:73 Gears and a 5.7 350 motor I am having trouble maintain speed on the hills what gears would help get me over the hump with out loosing too much speed and other stuff 4:11 or 4:56?
shermantic is offline   Reply With Quote
Old 03-02-2009, 01:33 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
This is not too uncommon. I have 4.10s and 6.0L and rather than beat up the engine, I opt to loose very slight MPH. I can, if I depress the gas, maintain my MPH. If you can't, maybe your engine is getting tired.
Old 03-02-2009, 01:40 PM   #3
"Cloudsplitter"
Trans in 3 or OD?
I would use 3 on all but the--------------terrain.
Old 03-02-2009, 02:01 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
What model year is the Yukon, and which transmission is installed?
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 03-02-2009, 02:31 PM   #5
Vintage Kin
Fort Worth , Texas
If it's any help, we all used to, in the 1960's & '70's, used to lose speed in going up hills since that was only reasonable. Might get a running start at 'em, is all. In the mountains, constant wide-open-throttle was necessary to cross some passes. Note that WOT was maintained for ten, fifteen, twenty minutes. On others, constant 3000-plus rpm was the norm. This was on vehicles that had a better power-to-weight ratio than what you are driving, but with numerically-lower gears (3.23 or 3.21).
The advances in engine construction ensure that todays motors have better internal clearances and parts fit. They don't burn oil -- brand new -- at 500-miles/quart. Keep in mind that these "old" engines also lasted over 150,000-miles, untouched.
With todays sophisticated engine controls, they should last as long or longer. I wouldn't sweat having to work the engine hard; not one bit. They're made to take it, so use 'em. That's what the redline is for!
Maintaining speed is relative. If you can keep to the posted minimums, then you are fine. If you can't, then maybe it is worth changing the rear gear set. I wouldn't. Burning some extra fuel doesn't hurt anything. Maybe change the oil according to the severe service guidelines in the manual is what I'd do.
Going slowly up the hills, engine singing, is part of the fun, IMO. Too bad it ain't the old days where we flipped the air cleaner lid over just to listen to that giant set of secondaries on the QuadraJet!
Old 03-02-2009, 04:14 PM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Going over the Colorado passes I am more concerned with maintaining a reasonable RPM verses MPH. That's just part of it, Like turning the heater on to blow off excess heat when it's 95 degrees pulling the east bound lane of I 70 to the Eisenhower Tunnel.
Old 03-02-2009, 04:34 PM   #7
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Just speaking from experience with Mustangs and 1 truck with 4:56 gears, 4:11's are probably the best compromise. A truck with 4:56 gears in Drive is really going to be singing at 55-60 MPH.
94Tri is offline   Reply With Quote
Old 03-02-2009, 08:14 PM   #8
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
I have 3.73s and a 5.7L in a 1993 Blazer and a 74 27' Airstream and it pulls just fine! It does need wide open throttle over the top of Snoqualmie Pass to maintain 55mph (for a couple of minutes).
somefun is offline   Reply With Quote
Old 03-02-2009, 08:37 PM   #9
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
I also have a 96 k1500 pickup with a 5.7 350ci / 4l60e trans with 3:73 Gears and it seems to have plenty of pep
The Yukon is a 95 with over 200K less miles then the 96 it has 5.7 350ci / 4l60e trans with 3:73 and its a real dog! (the 96 is the vortec and 95 is tbi is there that much differnce?)
Old 03-02-2009, 09:04 PM   #10
"Cloudsplitter"
Yep...The Vortec was a big improvement. Friends 96 Burb would blow my 95 away before the towing mods.
I liked the TBI's reliability though.
Towing with a Escalade ESV or a Yukon XL Denali Rosie39j Tow Vehicles 24 03-08-2006 08:40 PM
Engine/Year Trans/Year Matrix ViewRVs Mechanics Corner - Engines, Transmission & More... 36 10-23-2005 07:40 PM
'02 Yukon XL for Towing Sandy H Tow Vehicles 4 08-05-2004 06:24 PM
Towing a 25' Airstream with a Yukon? HowardD Tow Vehicles 16 07-04-2003 02:20 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
