Old 04-22-2015, 09:33 PM   #1
Hybrid tow vehicle?
Is anyone using a hybrid to tow their Airstream? We are looking at purchasing a tow vehicle and considering one of these hybrids: Yukon, Ford F150, OR Chevy Silverado. Any experience out there? Thanks!
Eleganza is offline   Reply With Quote
Old 04-23-2015, 02:35 PM   #2
Greenville , South Carolina
you aren't going to see much advantage to the hybrid when you're towing. That's why the prius et al aren't great for long road trip vehicles. You won't be using the electric drive when you're towing, you won't get any MPG difference around town when towing, certainly not on the highway, so it will never offset the increased cost and it certainly isn't any better for the environment unless you do a lot of stop and start traffic on a daily basis.
tbone1004 is offline   Reply With Quote
Old 04-23-2015, 03:27 PM   #3
paiceman's Avatar
Upper St Clair, PA , PA-Summer/FL-Winter
If you tow much I don't think a hybrid is your calling. However, if limited towing and a lot of around down driving then go for it. Their tow ratings are ok, and they can certainly do it, but the only time the engine will shut down is when you stop at traffic lights etc.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 04-23-2015, 03:45 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I don't think Ford has a hybrid in the F-150 model.
As for the others, the large truck hybrids that GM sells don't really get sufficiently better mileage than the all-gas versions to justify the cost. But do check the torque ratings. It may be that the hybrids have a lot more torque which could be useful in towing. Also, make sure that GM approves towing with a hybrid (I have no idea if they do.)
Bob Martel
WBCCI# 5766
Old 04-23-2015, 07:59 PM   #5
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Typically the significant extra battery weight for a hybrid will chew up big chunks of your payload when comparing hybrid and non hybrid models of the same vehicle. Something to watch out for if you will be using most of the payload with your setup. As with any other TV selection, check the load ratings, payload etc so you can make an informed decision. If it all checks out and you want a hybrid - go for it.
Boundless Power Systems LLC
Mount Vernon, OH
27FB International / Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 04-24-2015, 12:56 AM   #6
Thanks!
All you all make sense. I appreciate the hive mind. Time to rethink.
Old 04-24-2015, 05:04 AM   #7
andreasduess's Avatar
1984 34' International
Toronto , Ontario
If budget allows, and if an SUV is an option, the Mercedes GL class has a high payload capacity, about the same as a body on frame full size SUV, and can tow most any trailer. They also come with the fantastic BluTec diesel engine that will deliver exceptional mileage.
From what I am reading, those who tow with it like it a lot.
andreasduess is offline   Reply With Quote
Old 01-01-2017, 03:50 PM   #8
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
As AnnArborBob points out, torque is important for towing and hybrids generally do have a LOT more of that. Plus, they may be able to harness a lot more energy from stopping all that weight and use regenerative breaking to put it back in the batteries. I'm very intrigued by the possibilities. Another thing I would like to accomplish is using the hybrid as a generator! If it could be setup to deliver high voltage DC back to the trailer and then step it down once it gets back there. In theory, you could have unlimited power if you could set it up so the engine starts up to recharge the batteries when low. I believe the GMC Yukon/Chevy Tahoe can tow an airstream no problem. I have also been considering the Mercedes GL diesel because that is just a lot more my style.
But what I'm really trying to say is that I disagree with those who write off hybrids as tow vehicles. Sadly, however, large enough hybrid vehicles for towing are becoming less common now that GM has discontinued their large hybrids.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 01:55 PM
Chrysler Aspen Hybrid to tow 16ft int'l toaster ab Tow Vehicles 9 08-07-2008 07:53 AM
Looking at Hybrid and Vintage Tow Vehicles rec Tow Vehicles 16 06-28-2007 10:20 AM
GM hybrid pickup Silvertwinkie Our Community 9 07-25-2004 03:39 PM
Problem with Hybrid display mode... malconium Forum Admin, News and Member Account Info 1 07-21-2004 06:58 PM
