Old 10-20-2010, 05:45 PM   #43
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
The new 2011 Ford trucks are getting outstanding overall owner reviews from what I can tell so far, and in fact I'm planning to buy one myself this coming spring.
One thing I would check carefully is whether you will be safely within the axle weight limits with your trailer and the F250. I know when we towed our 31' Classic Ltd with our 2000 F250, we generally exceeded the rear axle weight limits - of course we had a cap on our truck bed, and I filled our 8' bed with lots of toys and stuff whenever we went camping. At times, I wished we had had an F350.
As far as how I would equip a new F250 for myself (cost is not a concern of mine, whereas comfort is) here's what I would get:
King Ranch extended cab, 8' bed, 4 wheel drive, navigation and sat.radio, 20" wheels and tires, factory sprayed in bedliner, 3.73 axle, dual heavy duty alternators - 200 amp.
You're cheating yourself on what you can carry with you if you get a short bed (I'd never have one myself) and there are many places - campgrounds included - where you'll find - or at least I have - that a 4 wheel drive is a necessity. I don't like to bang up my truck bed, so have always had a sprayed in bedliner - and Ford's price is lower than I've paid to have it done locally in the past.
I've always put Ford cetane booster and multi-purpose additive in my 2008 6.4L Ford, and will probably continue to do so in the future. It runs and tows like a champ, and I expect the 2011's are even better!
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 10-20-2010, 07:31 PM   #44
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
John
Just curious...why 20" wheels?
And why 200 amps, do you upgrade your charge wire also?
Tx,
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 10-21-2010, 12:16 AM   #45
flyfisher's Avatar
2004 30' Classic
John
Oh, and I forgot 2 of the most important items to make sure are included on the truck (they already may be included in one of Ford's option packages - I'm not sure):
1. Power telescoping trailer towing mirrors
2. Reverse back-up camera
Flyfisher
Old 10-21-2010, 12:42 AM   #46
flyfisher's Avatar
2004 30' Classic
Tx,
Bill
Bill -
I've see a 2011 F250 with these upgraded tires (the ones I saw had Michelins) and wheels - and they looked awsome on the truck. I guess no other reason than that.
By charge wire are you referring to the battery wire? -- I assumed that that was part of the upgrade, but probably should check.
Flyfisher
Old 10-21-2010, 01:40 AM   #47
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I have 20 in wheels on my F150 and the ride is great. Better than any sedan I have owned.
I very highly recommend the NAV system which has an integrated backup camera. hitching up cannot be easier with the camera. It even has guide lines superimposed on the picture!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-21-2010, 06:18 AM   #48
1 Rivet Short
1989 25' Excella
Bill -
Putting 20" wheels on anything expected to carry some weight doesn't make a lot of sense?
Kind of defeats the purpose of getting a truck...particularly a HD truck (as the OP indicated)?
Looks cool, but leave the big wheels to the import car tuners...
As for the charging, unless you upsize you charge wire to at least 4 awg, what do you gain? Do you have some oher motivation for specing 200 amps?
Just trying to figure out your line of thought...lots of other good ideas for the OP to consider. Isn't it fun spending someone else's $ !
Thanx, Bill
Old 10-21-2010, 09:30 AM   #49
2006 30' Classic
Milton , Florida
You don't say what truck experience you currently have. If you have not driven a F-250, crew cab, long box Ford truck, then you might want to do so before making a purchase decision. This is a long vehicle, and it is not nearly as manuverable as a F-150 short bed. Tow a 28' to 30' TT and the entire rig is quite long.
We opted for the F-250 short bed for the above reasons.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 10-21-2010, 09:36 AM   #50
Bill,
Are you talking about 20" tires in general or are you commenting directly on 20" tires provided on the King Ranch? I do not see any weight carrying problems. They are LRE tires. I was looking up Michelin ATX2 replacement tires and I think the tire carried 3750 pounds.
Barry
pattonsr is offline   Reply With Quote
Old 10-21-2010, 10:29 AM   #51
_
many more 20 inch tire options these last 5 years...
but replacements are expensive (and the oem spare is 18)
the 20s provided by ford as oem have plenty of load carrying capacity.
but wheels/tires are tied to gearing and option packages.
so one cannot simply "order" 20s without impacting other specs.
_______
also the 3.73 is ONLY available on gas trucks or DRW trucks.
drw trucks are only spec'd with 17s.
srw diesels are only available with 3.3 or 3.5 rear ends.
_______
aftermarket one can do whatever they like,
but wheels/tires/gearing and payload are tied together.
base alt is 157amps, upgrades are 200 (single alt) or dual amps at ~375 amps.
again the ALT is tied to specific package upgrades or options.
cheers
2air'
Old 10-23-2010, 02:13 PM   #52
2009 23' FB Flying Cloud
1959 24' Tradewind
1951 21' Flying Cloud
Northeast , Iowa
Just want to say thanks for all the comments and suggestions--this community is a great resource to draw upon!
epperp is offline   Reply With Quote
Old 08-03-2011, 10:45 AM   #53
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
A consideration that hasn't been brought up is the design of the 4x4 front suspension. The Ford F-250 has a strait axle in the 4x4 and independent front suspension for the 4.x2. This is the same with the Dodge. The Ford and Dodge will ride smoother and steer more with more precision as a 4x2. The GM models have independent front suspension with both 4x2 and 4x4. If 4x4 is really desired, look at the GMC and Chevy for the best handling and riding 4x4's. Another consideration in choosing 4x4 is if it has dry rode capability in 4x4. Most 3/4 truck setups don't. So, it is not very useful while towing on road because you can't use 4x4 mode unless the road is covered with snow!
rp709 is offline   Reply With Quote
Old 08-04-2011, 01:03 AM   #54
Maniacal Engineer
barts's Avatar
Menlo Park , California
I specifically ordered manual hubs on my 96 4x4 F250; I use 4 low all the time when parking the Tin Pickle, or climbing steep hills at slow speeds on pavement by simply not locking the hubs.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 08-04-2011, 08:38 PM   #55
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
One option that most everyone slips by is the "snow plow option". Even if you live in Florida, this $80 option is one of the best. It gives you added front springs, HD radiator, HD alternator, and only costs $80. Even though I ordered my 2008 a while back, here is the sticker with my options.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-04-2011, 09:05 PM   #56
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
- Bart
I'm not sure if the manual hubs are available anymore. But with this new six speed and 3.55 gears, first is 14:1 so it's close to 4-low!
newroswell is offline   Reply With Quote
Towing Report. 2011 F250, 6.2L gas, 6spd TorqShift Wayward Tow Vehicles 30 02-18-2013 10:10 PM
2011 Ford F250 Diesel - Don't Drive One Unless.. ShinyRoad Tow Vehicles 119 01-20-2012 08:06 PM
2011 F250 6.7 Diesel, first mileage test hhendrix Tow Vehicles 97 05-30-2011 11:22 AM
Ford 2011 F250 Diesel Aquabud Tow Vehicles 31 01-08-2011 06:59 AM
1976-1979 Ford F250, Whats the best spec?? Bex Tow Vehicles 12 09-14-2010 06:12 PM
