Old 07-16-2009, 09:57 PM   #15
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Use the ditch method
Crusty has it right! Ditches or small hill berms are everywhere. Drop the tailgate, back into the rising ground and use a sturdy ramp/board/plate to go from the ground to the bed. Ride it on and safely have way less chance of dumping it.
Old 07-17-2009, 11:10 AM   #16
76sovereign's Avatar
1976 31' Sovereign
ozark , Missouri
This seems like the best and safest bet......
Originally Posted by ScottMac View Post
Greetings,
These photos are from an earlier post. (2008 F-250 long bed)
The bike in the photos is a Suzuki C50 - however, we most recently have used this setup with a Honda Goldwing. (2008 GL1800) and it works great. Unfortunately, I got wiped out in February - the Wing was destroyed and the ensuing health issues have prompted me to give up riding.
The ramp is made by USA Ramp (model A9) - USA Ramp - folding ramps for trucks, vans.
The ramp actually attaches to the hitch shank and works like a charm. I had to make one minor mod to the hitch (we had to grind off about 1/8" to 1/4" of the gusset for the sleeve to slide back far enough on the shank - it was so little that it does not violate the integrity of the shank). They are not "inexpensive", but they provide a wonderful solution to taking a bike as large as a "Wing" with you when you are pulling an Airstream. USA Ramp makes ramps in many different configurations. I spoke with them on the phone extensively before ordering and they were great to work with.
The ramp weight limit is 1200 lbs. Since we are no longer riding, I might be willing to make you a really good deal on the ramp and the attachments. I'm not sure I will ever have a use for it at this point. Check out the website - I absolutely loved this solution. The ramp is actually 43 inches wide - the website says 39, but he started making them at 43 when I bought mine. It is feet down so it is very safe and easy to ride the bike up into the truck.
The motorcycle stayed covered while in tow with a towable cover made by Geza Gear - it will not scratch the bike.
Hope this helps.
76sovereign is offline   Reply With Quote
Old 12-07-2009, 10:22 PM   #17
Bothell , Washington
if you haven't found a lift go to rampage lifts. they are about 2500.00. my riding buddy has one for his harly and i will be getting one for my road king. they are the best out there and a safer way then any ramp. good luck.
Outlaw
Outlaw is offline   Reply With Quote
A/C mounted in pickup bed? plossl Furnaces, Heaters, Fireplaces & Air Conditioning 12 06-25-2012 07:24 PM
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
If Airstream made a Harley kevin barnes Off Topic Forum 4 03-13-2009 03:49 PM
Off the Harley...and, into a Silver Bullet! Chief Member Introductions 9 08-01-2007 04:56 AM
Airstream/Harley dealer in NH Barbara Peerenboom Commercial Listings 17 11-13-2004 05:50 AM
