Old 10-29-2008, 06:34 AM   #29
SteveH's Avatar
Common Sense , Texas
Bill,
We have a member in our unit that pulls his 34 footer with a Toyota 1/2 ton crew cab pickup, and says "it pulls it fine with no problems....it has a 10,000 pound towing capacity".
And so it does, as he shows up at every rally just like everyone using 3/4 and 1 ton trucks.
Regards,
Steve
Old 10-29-2008, 06:52 AM   #30
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Sounds like the Ant's are back in the Hill, great!
Be happy we still have choices.
Do what your comfortable with, do it safely.
PFC
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-29-2008, 07:24 AM   #31
2006 34' Classic Slideout
San Clemente , California
As far as a truck goes; you will be fine with a 1/2 ton or a 3/4 ton for a 25' Airstream. Don't let anyone talk you into anything bigger. All you will need is 3.73 gears for that weight.
As far was what truck you want; it depends on what you are looking for.
1/2 TON: I am not 100% sure what I would use if i would get a 1/2 ton. But I can tell you that my 2004 F150 5.4L FX4 3.73s towed my 2005 25' CCD with no issues at all. So I would probably get another one of those.
3/4 TON: If you want a gas engine, no question about it get an F250 with a V10. If you want a diesel, go with the truck that you enjoy the most. All have their advantages and disadvantages. Just remember, a diesel is worth it if you actually work your truck alot. If you are only going to tow a few times a year and that is the only thing you use the truck for, it may not be worth the cost. I am a huge diesel fan myself and currently full-time in my 2006 34' SO Limited and tow it with ease with my 2006 F250 6.0L FX4 3.73s.
Most people think that it is the power of an engine that makes it a safe TV. The fact is, stopping power should be what is the ultimate factor in a TV. Bottom line is just about any 1/2 ton truck will handle a 25' Airstream trailer. A 1/2 ton is just not as durable as a 3/4 ton is all. GL in whatever you decide.
sbrou14 is offline   Reply With Quote
Old 10-29-2008, 07:32 AM   #32
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Contemplate your tongue weight. A properly set up trailer (safe) will have 10- 12 percent of the total trailer weight as tongue weight.A 6000# trailer safely set up will have 600#-720# tongue weight. Weigh your trailer and tongue!Then you can do the calculations you need to do.An inproperly balanced trailer will cause safety issues that the biggest truck & fancy hitch cannot overcome. And in regards to the tow vehicle,an early model F series 7.3 DIT Diesel is the best. Oh wait, I am a Ford diesel mechanic and that was the truck I happened to own when I got my Airstream. Mine has 265,000 miles on it and runs like the proverbiale watch! Good luck and go camping,A lot !
Diesel1 is offline   Reply With Quote
Old 10-29-2008, 08:45 AM   #33
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
[QUOTE=BillTex;The problem with tons (as just mentioned by DrPlay) is payload, not tow capacity. Yes you may be able to tow 10,000# with a ton (yikes!) [/QUOTE]
As I have Stated many times this is an opinion not fact... Have you towed your rig with a Titan, Tundra or F150 to see how it handles????
The OP may not even want a Truck we don't know as he/she has not posted again...
_____ Quote SteveH
I have towed my trailer with a 2006 dodge 3/4 ton and my Sequoia,, It towes much better with the Sequoia... Smoother for sure....
I have also towed a 2004 28' Safari with no trouble...
It's what your use too.... I would just say, stay within the tow load ratings... And If your doing long trips, 80% of the load is good place to start.
My Sequoia has a larger tow rating than the newer 3/4 ton burbs... Whats up with that????
Lets not burn the ants here... IF you are not comfortable with a 1/2 ton thats fine...
But there are a lot, a lot of people towing with them, and they are not having any problems or creating lawn ornaments as has been suggested....
Most accedintes are not caused by the tow vichle but by driving to fast>>>>> Or when passing semi Trucks...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-29-2008, 09:44 AM   #34
SteveH's Avatar
Yep, the First Thing needed for a safe equasion is a competent, safe driver. Without a safe driver, no matter the tow vehicle, you've got an accident just waiting for a place to happen.
Regards,
Steve
Old 10-29-2008, 10:14 AM   #35
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
My experience pulling a 2005 25FB with a half ton is not opinion; it is fact. Until recently I pulled Lucy with a 1/2 ton 2004 Chevrolet Tahoe (5.3 liter), and a 3/4 ton 2005 Suburban (6.0 liter). I had these two TVs at the same time, and tried towing with them alternately. The Tahoe could tow Lucy just fine as long as there were no severe upgrades. When these situations were encountered with the Tahoe, she strained considerably to get Lucy up the hil at 70 mph. The Suburban had no trouble at all doing this.
The part that concerned me more was the braking. The Tahoe did not have the brakes of the Suburban, and this was very noticeable in hard stop situations. Also the Tahoe had rear coil suspension which felt a little mushy as compared to the rear leaf springs of the Suburban. Most half tons (including Tahoes) come from the factory with load range C tires which don't cut it when you want to tow 7000# + for a long distance at high speed.
My somewhat extensive experience with 1/2 vs. 3/4 ton TVs during the same periods with the same Airstream has led me to the following conclusion:
A 1/2 ton TV is probably sufficient for the casual Airstream camper who pulls his trailer 80 miles to the lake or RV resort and back home, and does this six or eight times a year, maybe makes one 500 mile trip per year.
If you pull your Airstream 20,000 miles a year with 5,000 and 8,000 mile single trips, carry a tandem kayak with all its gear, two generators, extra gasoline, a complete set of tools, clothes and provisions for six weeks away from home, and several hundred pounds of business equipment, a 3/4 ton is what I want to be driving.
In other words, it depends on your style of Airstreaming as to whether a 1/2 or 3/4 ton TV is the right one for you.
Brian
SuEllyn & Brian McCabe
Old 10-29-2008, 11:08 AM   #36
purman's Avatar
1968 28' Ambassador
Brian
I would agree with everything you have said here.... IT makes a lot of sense...
Bottom line your Tahoe wouldn't carry all that weight... So you need a 3/4 ton...
Tundra is rated for what? 10800 lbs, my Sequiao 9600lbs I wouldn't want more than 8000 lbs on a long trip... for sure...
Wish the PO would post what he was looking for we could maybe help him/her out more..
Or maybe it was just someone kicking the ant hill and burning it
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-29-2008, 11:09 PM   #37
2007 31' Classic
holland , Pennsylvania
make sure what ever truck you choose that it has heavy duty cooling.also make sure it has additional cooling capacity for the tranny.i have towed with half ton trucks with towing packages that would overheat on warm summer days.these trucks were gas v8 engines.the newer trucks are equipped with tow/haul transmissions that even have extra fluid pumping capacity when you are in the tow/haul mode.if a truck is not properly equipped they dont tend to have much longevity.i had a expedition that i towed a 26 ft sob with.it seemed when i would get to my destination that the trucks tongue was hanging out.also most hills in pa,the accelerator felt like i was putting my foot down in a bucket of water.every hill i watched the temp gauge go up.traded that truck on a diesel excursion,have a bigger and heavier airstream and now i feel like the truck is towing the trailer.remember it helps to have a tow vehicle with some weight when you are towing a travel trailer.that is generally why the 3/4 tons are a more stable tow.
xonvldz is offline   Reply With Quote
Old 10-30-2008, 04:23 AM   #38
1973 31' Excella 500
Morristown , Tennessee
All vary goood advice above. I towed a 1971 25' land yacht for many miles and used a Ford E150 conversion van with the standard 351. This was often in the summer with the air conditioner running. I did install an extra transmission cooler and had the towing package that came with the truck.
Just a couple things seemed to make the difference. Making sure that it kept cool was easy as long as I turned the air off for 3-5 minutes before slowing from highway speeds, kept the brakes in good shape - hard stopswere a little harrowing. The biggest point is that stability seemed related to wheelbase of the tow vehicle rather than the power or braking ability. The van pulled great in that sense. I now pull a 31' e
Excello with a GMC Denali PU and the package is better in every way. It is stable with plenty of power (345 hp), towing package and transmission and plenty of braking.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Old 10-30-2008, 06:00 AM   #39
SteveH's Avatar
JOE! You mean to tell us you are pulling a 31' Airstream with a 1/2 ton truck???? How can that POSSIBLY BE????
Regards,
Steve
Old 10-30-2008, 08:05 AM   #40
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Just an FYI, the person that started this thread hasn't been back since they made their first and only post. Do you think we scared him away?
Old 10-30-2008, 09:14 AM   #41
purman's Avatar
1968 28' Ambassador
I think it was a set up to devide us
Then there gonna come back for the kill
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-30-2008, 10:14 AM   #42
Certifiable
mistral blue's Avatar
Talking Op?
Roger Myers Jr.
Roger Myers Junior, voiced by Alex Rocco and Hank Azaria, is the CEO of Itchy and Scratchy International, and is the son of Roger Meyers, Sr. He distributes the cartoon, which is frequently criticized by parents because of its violent nature. Marge wrote a letter to Roger Meyers Jr. in "Itchy & Scratchy & Marge" denouncing the violence in the Itchy & Scratchy cartoon. Roger responds with a letter calling her a screwball. He is a jaded and selfish businessman who has nothing but contempt for the children who comprise his audience. In "The Day the Violence Died" Itchy and Scratchy International is bankrupted following their trial against Chester J. Lampwick, when Bart and Lisa are too late in providing information that could save the company. He also possesses an extremely obnoxious personality, where he only cares about people who can help him. This is displayed in his contempt for the writers of Itchy and Scratchy when Abraham Simpson becomes the flavor of the month. This is shown again when holding auditions for the voice of Poochie. In "The Itchy & Scratchy & Poochie Show", he creates Poochie in an attempt to bring the show's ratings back up. Homer is asked to voice Poochie, and does so. The show's ratings plummet, and Poochie is despised.
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
mistral blue is offline   Reply With Quote
Emergency lights on your A/S trailer with no tow vehicle safari57 Lights - Interior & Exterior 10 11-19-2014 05:18 PM
'71 Tow vehicle/trailer 7 way connector wiring Lumatic Lights - Interior & Exterior 12 08-15-2010 08:19 PM
Gas vs. trailer vs. tow vehicle Lumatic Tow Vehicles 13 04-29-2007 09:23 PM
Tow vehicle/Trailer match Darrell Root 2002 - 2005 International 7 07-31-2006 10:20 PM
Hooking Up Trailer Battery to Tow Vehicle flyfshr Batteries, Univolts, Converters & Inverters 11 02-27-2004 10:50 PM
