Old 10-31-2007, 07:31 PM   #1
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
How To Get Better MPG's
I have a 1999 Chevy Suburban with a 454 engine. The truck is great. I really don't want to buy another truck but the gas milage is killing me. I would like to explore ways of improved MPG's. The first thing I think of is a full flow exhaust like a Banks system. Any suggestions or opinions? Anybody using a Banks, or similar, system?
Tom
tlavergne is offline   Reply With Quote
Old 10-31-2007, 07:38 PM   #2
_
there are many threads on fuel economy and improving mpg....
http://www.airforums.com/forums/f238...ads-18186.html
here is one, but a quick search found 15 in the towing, tow vehicle section...
there are also several threads on the banks systems
cheers
2air'
Old 10-31-2007, 07:44 PM   #3
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Thanks. I figured it has been discussed to death and did a search. I couldn't find much. Maybe I am not searching correctly. I will try searching again.
Tom
Old 10-31-2007, 07:53 PM   #4
_
this is a start for ya...
http://www.airforums.com/forums/sear...earchid=864645
cheers
2air'
Old 10-31-2007, 08:00 PM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Tom
Hi Tom, Take a look here. With a 454 it just boils down to good driving habits... The things you have mentioned will help a little. But, is it worth it in the long run? I really like the power out of my 454. So, I'll live with the fuel cost. My 73 Ford 4x4 gets better fuel mileage than the burb.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-31-2007, 08:12 PM   #6
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Thanks for the links. When it is time for new tires, new exhaust, etc. is when I will probably make a few changes. From what I have read it doesn't pay to spend to much $ on modifications...just use good common sense driving techniques. So for now I just need to continue to watch my foot on the gas pedal and watch my tire pressure.
Tom
Old 11-01-2007, 09:28 AM   #7
Tom
Towing a travel trailer, while using a persons usual "driving habits," alters fuel mileage to a high degree.
What is needed, is "on the road" towing lessons.
We can talk, we can guess, we can assume, we can ask, but the bottom line is no one knows a persons driving habits, except them, and sometimes, that could be a challenge too.
There are many factors that are involved when towing a travel trailer, especially an Airstream or Argosy.
I have towed a loaded 31 foot Airstream, in excess of 110 mph, that was documented on film. The faster you tow an Airstream, the better it handles, "IF" your rigged properly.
When we travel on the open highways, we have no idea what forces are working against us.
One of the biggest forces that alter fuel mileage, is the wind. A wind is of little to no concern to people that tow trailers, but it's a huge concern to pilots. So lets try an instrument that every pilot relies on.
Back in 1970 t0 1973, when I travel the country towing a 31 foot Airstream as my home, I installed an aircraft "airspeed" indicator in my car, and a altimeter.
I could at a very quick glance, tell you if I was towing into a head wind or had a tail wind, by comparing the speedometer reading to the airspeed reading.
As an example, if I was towing into a 20 mph head wind at 60 mph ground speed, then the airspeed indicator would say 80 mph, telling me that I need to slow down.
Reversing that, if the ground speed was again 60 mph and I had a tail wind, then the airspeed indicator would only say 40 mph.
Comparing the speedometer reading to the airspeed reading, quickly told me that I could tow a little faster, since I had a tail wind, or to slow down since I had a head wind.
Amazingly, I immediately increased my overall fuel economy by about 20 to 25 percent, simply using the airspeed/speedometer readings as a guide.
Installing an airspeed indicator is really very simple. Mount the gauge where ever you wish so that you can easily see it, and then connect a 1/4 copper or steel line to it and run the line so that it sticks out about 3/4 to 1 inch forward of the grill on your tow vehicle. You can also, for a little more money, have a lighted gauge for night towing.
Perhaps some owners could appreciably increase their fuel economy, by using the two gauges that will change your towing habits, very quickly.
Airspeed indicators can be purchased at Aircraft Spruce for a little over $100.00.
At todays fuel prices, it wouldn't take long to recoup your investment.
And while your at it, installing a "altimeter" in your tow vehicle also helps teach you "new driving" habits. They cost a little over $100.00 as well.
As altitude increases, the efficiency of gasoline engines decreases, unless it's super charged. That also lowers fuel mileage. But the most important part of using an altimeter, is to tell you if your climbing or not.
We can be on open highways for an extended period of time, and have no idea if we are climbing slightly or not. If your climbing, the fuel economy goes down therefore once again, slow down, until that climbing has ended.
By using your speedometer, an altimeter and a airspeed indicator, I promise you they will teach you new towing habits, very quickly.
Believe the gauges, tow accordingly, and you will become in short order, an even happier camper.
Old 11-01-2007, 09:36 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
and um...how do you get an alitmeter setting before departure...from a campground?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-01-2007, 09:51 AM   #9
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
check your sectional!! set it to current barometric pressure and read your altitude, many places have a good idea about how high they are...
So I got a few spare altimeters around the hangar and a few air speed indicators to boot, heck I'll even put in my "G" meter and a VSI.
Thats what I've been missing- now I'll feel right at home.
Seriously-- thanks for the good info Andy. ASI going in ASAP.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 11-01-2007, 09:53 AM   #10
Images: 59
If you are running a carbuerated 454 you could add a vacuum gauge. You practice working the gas pedal in a way that keeps the manifold vacuum as high as possible. It's pretty much a visual aid for the old "egg on the accelerator pedal" idea.
I think Andy's idea for windspeed and altimeter are really neat. I love gauges.
Old 11-01-2007, 10:16 AM   #11
There are two things in life that you believe in and listen to, or else.....
Gauges and Mama.
Old 11-01-2007, 10:17 AM   #12
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by doorgunner
check your sectional!! set it to current barometric pressure ....
well, duh, that IS the altimeter setting...and its what I don't have.
Since when do sectionals give you the current barometric pressure?
I know, I know...just find the nearest airport on the chart, and set it that way...very "rough", though.
Either that, or Andy only camps at airports.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 11-01-2007, 10:34 AM   #13
Images: 59
Gauges and Mama.
. . . and if they disagree, you'd better side with Mama.
Old 11-01-2007, 10:46 AM   #14
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Dang it! About a year ago I was thinking about doing just that (airspeed indicator) but talked myself out of it. Now I want to do it again.....
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
