Old 05-16-2016, 03:59 PM   #1
PSU1981
2015 27' Flying Cloud
Spring , Texas
How much excess towing capacity
We have a 2015 27FB FC that I pull with a 2015 Tundra with 10,000 lbs towing capacity. The cloud has a UBW - dry weight around 5800 lbs - With Max gross weight of 7600 lbs. Anyways how much excess towing capacity should I have to say pull thru the Rockies? Be able to tow anywhere in the U.S. ?
Glenn
PSU1981 is offline   Reply With Quote
Old 05-16-2016, 04:07 PM   #2
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
It is more about your payload capacity,than it is about your towing capacity.You will know if you have enough towing capacity when you reach the Rocky Mountain pass.Some people are fine with the foot to the floor and a top speed of 45mph.Others get home and trade for something more capable.
Old 05-16-2016, 04:41 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I don't know that there is any magic number but I recall years ago a rule of thumb that used to be quoted is that you should be towing at around 75% of your TV's rated capacity.
I doubt that is based on anything particular formula, but I have used it as a yardstick because it seems to me to be logical that for longevity and reliability of the tow vehicle it makes sense not to be pushing what the manufacturer claims to be the limit all the time. Things should be less stressed and last longer the less they are taxed.
So that is what I try to do, and it seems that is about where you are at also with your present rig.
Not sure how meaningful the 75% really is though as I read of many folk who tow at way over their vehicle's rated capacity and appear very happy with the results, reporting no problems at all, either in power, braking, handling, or in vehicle reliability problems - other than maybe going more slowly up hills!
Not for me though - I guess you pay your money and take your choice, I still like the 75% factor!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-16-2016, 05:05 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Your Tundra will pull your 27 foot Airstream over any mountain out west. You may not be the first one to the top (that would take a 3/4 ton diesel ) but you'll make it fine. You have more torque per pound that just about any gas powered Class A and they go over those passes all the time.
Your issue as mentioned previously is to make sure that you have not overloaded the payload capacity of your tow vehicle. Despite what Airstream says (825 lbs tongue weight,) your actual tongue weight is likely pushing 1,000 lbs.
Bob Martel
WBCCI# 5766
Old 05-16-2016, 05:30 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You have it, use it. You'll do fine, we have towed all over the country and every western state with similar trucks. Take it easy until you learn what it can do, and learn to use the transmission climbing and descending (very slowly on steep grades at first), the engine loves to rev to deliver power and provide compression braking downhill, let it, don't be afraid to use the truck and trailer service brakes to help hold speed when needed.
You've got a great truck that can pull any Airstream throughout the U.S. Don't let somebody talk you out of wasting money on a new one that you may not need.
Be sure you have a quality weight distribution/sway control hitch and setup, fully a third of a successful towing combination.
Doug and Cheryl
Old 05-16-2016, 06:08 PM   #6
malinois38's Avatar
2008 28' International
Happy Valley , Pennsylvania
I tow a 28' International with my Tundra (Crewmax 4x4 with Fiberglass cap). I have put "E" rated tires (highly suggest!) on and have a 1325lbs of payload capacity. The payload(Listed on white sticker on "B" pillar Driver's side)is going to be your limiting factor, but by no means a deal breaker. In other words, after 1050lbs of tongue weight and my wife and two kids, almost everything else goes into the Airstream.
I towed to Maine last summer with no problems whatsoever. I had plenty of power going up/down the Ski Resort areas in the Northeast. I would also suggest you get used to manually downshifting on the down hills to save your brakes, works great. FYI averaged about 10 mph.
malinois38 is offline   Reply With Quote
Old 05-16-2016, 08:10 PM   #7
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Glenn
Based on the 5.7L:
380 HP/400 ft-lb
4.30 rear end
10,000# tow rating and you've got a 7600# max gross trailer.
You've got more than enough truck to tow that Airstream anywhere.
Now add a Hensley (or Propride) and you're in clover.
boondockdad is offline   Reply With Quote
Old 05-16-2016, 08:57 PM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
07 dodge with 6.7 cumalong weighs 8800 towing a 13 31' classic with 7750 on the axles, plenty of power at 1600 rpm, exhaust brake on the down side really saves the brakes...
Old 05-16-2016, 08:58 PM   #9
1986 31' Sovereign
Miami , Florida
Been towing my 1986 31' Sovereign with a 2004 Nissan Titan for 11 years and some 70000 miles all over the lower 48 including eight round trips to Yellowstone from Miami. Never a hiccup, never a "white knuckle" moment. The truck just rolled over 204000 miles.
On any grade up to 8%, 3rd gear and 3600 rpm gives me 65 mph. My foot has never been "on the floor".
You truck is far more powerful than mine and has better brakes.
My only limitation, as noted in several earlier posts is payload. Hasn't been a problem as we carry very little in the bed of the truck.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-17-2016, 11:10 AM   #10
Kingsburg , California
Tundra
The problem with Tundras is not the pulling, it is the stopping. There are a couple of inexpensive fixes using drilled and slotted rotors with a semi ceramic pad. Makes about a 20% improvement cold and maybe a 30+% improvement hot. These kits are less than $500. Go to the dealer for the big brake kit and you will be looking at close to 7k, granted it is a much better setup and has much better performance.
Mike S
bigirish2 is offline   Reply With Quote
Old 05-17-2016, 11:13 AM   #11
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
A bit smaller trailer but we pulled our 25' Flying Cloud through the Rockies last year with our 2012 Sequoia without any problems. Same drivetrain as your Tundra.
See this Youtube video of someone else pulling an Airstream 25' in the Rockies with a 2010 Tundra:
Greg
greghoro is offline   Reply With Quote
Old 05-17-2016, 12:11 PM   #12
Dearborn , Michigan
Images: 21
Mike S
Trailer should be pulling err, stopping its weight.
The original electric brakes on my '65 Ambassador were phenomenal. I don't think it was possible to fade those drums out, and the stopping power was nose-bleed rating.
The electric brakes on my 2005 Classic 31', not so much. Never felt comfortable with that setup.
Couldnt be happier with my current electric/hydraulic setup in my 30' S/O Classic. Dexter 1600psi actuator, and 6k disc brakes. All the way down Big Horn, Continental Divide, Smokies, and everywhere else, never a hint of fade. Could stop a rig 4X my weight. Wonder why Airstream dropped them.
Old 05-17-2016, 12:21 PM   #13
ericpeltier's Avatar
Superior , Colorado
As a person who tows in the mountains a lot (live in Boulder CO), here's my two tips:
You have plenty of engine.
At the top of the pass, leave it in 2nd gear and enjoy the slow downhill. If you get up to 50mph just down from the pass, and need to slow further, it can get dicey.
Eric
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 05-17-2016, 12:52 PM   #14
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
As has been said, it's all about payload.
The tongue weight of my 2014 FC25FB with solar is 1252# on the Airstream scale in Jackson Center. That is the loaded weight with about 800# of cargo. I could not configure my 2013 F150 3.5 Ecoboost, 3.73, max tow and cargo options to not exceed the drive axle GVWR of 7700#, never mind the stock tires 2600# rating. I was well under its 15,400# GCWR. A Blue Ox with 1500# bars with "one link showing" got the drive axle to about 150# over by transferring weight to the trailer, not the steer axle. I now have a 2016 GMC 2500 Duramax which solved all my "problems".
Based on posts I see here my guess is that at least half of us are happily driving tow vehicles that are overloaded in one way or another. The F150 drove like it was all good, but the scales told a different story.
BillfromWI is offline   Reply With Quote
Excess Parrbond on A/S Skin Cousin Eddie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 10-03-2012 03:37 PM
Excess parts available Exsys Cabinets, Counter Tops & Furnishings 12 02-18-2012 07:59 PM
How much towing capacity do I need? altamont Tow Vehicles 19 02-25-2007 01:16 PM
Carbon Monoxide: How much is too much? Lotek General Appliance Topics 3 01-08-2005 06:06 AM
How much is to much garry Our Community 13 07-08-2003 03:53 PM
