Old 07-14-2014, 03:05 PM   #1
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
How is this possible, same manf, almost same frame, diff GVWR
case in point.
2003 Ford F-250 SD with 7.3L PS diesel pickup, extended cab, long bed, 158" wheel base. VIN tags show Gross at 8800.. but the axles weight, front 5200, back 6084 = 11284 LBS, is quite a bit higher than gross..
now look at this.
2003 Ford Excursion with 7.3L PS diesel SUV, 137 Wheel base, VIN gross 9200, front 4700, back 5250 = 9950 LBS, which is just slightly above gross on tag..
What gives..
On SD, vin shows transmission as 9, axle as C1,
excursion trans is a B and axle C1.
so why the big difference in gross and axle total weight.. too me it appears the SD is underrated on gross by 1000 lbs or better..
info is from this SD, http://www.autowarehousesalesnservic...spx?id=4545377
and this excursion, http://www.autowarehousesalesnservic...spx?id=4666199
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
Timeshare owner/user since '99
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 07-14-2014, 03:54 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
First off, you're comparing a superduty pickup to an excursion - two different vehicles.
I have an '05 Excursion and a bit later 250 PU. The suspension is very different - especially on the front end.
Different spring codes call for different ratings.
Transmission cooling capabilities will effect gross.
Best to stick with the Manufacturers rating - many expensive engineers have thrown many hours at the ratings - they would not downrate any vehicle without a solid reason.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 07-14-2014, 04:04 PM   #3
jcl
Vancouver , British Columbia
When they spec'd heavier axles for the pickup, they would have allowed more headroom for not knowing where the owner would place the load, more fore or more aft. The Excursion would be designed for carrying the weight more between the axles.
No reason for GVWR to be the sum of the axle ratings unless you can control weight distribution between axles.
Also, as noted above, there are more considerations for GVWR than axle capacity.
jcl is offline   Reply With Quote
Old 07-14-2014, 06:22 PM   #4
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
They may also have completely different axles. Ford uses a number of axles and sizes. There are a number of contributing factors. As 87MH pointed out, the engineers know what they're doing.
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-14-2014, 06:32 PM   #5
dznf0g's Avatar
Oswego , Illinois
Are you expecting FGAWR + RGAWR to equal GVWR? It doesn't work that way.
-Rich-
Old 07-15-2014, 02:30 PM   #6
carl2591's Avatar
2005 31' Classic
i hear you on axle sizes etc.. if you look at a 2006 super duty the gross is 10,000
another point on the engineers know what they are doing,, then explain the 6.0L engine .. sorta make that something you make you go HUMMMMMM...
the axle code on VIN is same for both .. ???
Carl, Raleigh NC
Old 07-15-2014, 08:18 PM   #7
Nomadic , USA
What about the 6.0L engine? My 4 door Pontiac G8 GXP has a 6.2L v8 with 3.92 rear end, and produces 415hp & 409ft/lb of torque. They also put the 6.2L in the 2500HD's, but that doesn't make my Pontiac suited for towing.
Old 07-15-2014, 08:23 PM   #8
dznf0g's Avatar
Oswego , Illinois
no 6.2s in 2500s. Only 6.0l. 6.2 goes in high end SUVs and Max Tow 1500s.
I think he's talking about the Ford 6.0L diesel....which was problematic.
-Rich-
Is floor frame construction method same for both Silver Streak and Avion? Tony S Vintage Kin 30 11-26-2013 11:09 PM
1967 Airstream Overlander possible Floor/Frame damage??? huskygeorge General Interior Topics 9 09-27-2013 09:45 PM
GVWR Diff Bwtn 2004 & 2005 Safari? gb123 2004 Safari 3 03-18-2012 01:58 PM
2010 Suburban w/3.08 diff... phbarnhart Tow Vehicles 8 07-20-2011 12:32 PM
'04-'03 Ext. Diff. RivetED 2003 Safari 6 01-22-2004 07:39 PM
