Old 10-18-2007, 11:59 AM   #1
Stream 1529
Stream 1529's Avatar
Profile:  2004 34' Classic S/O
San Antonio , Texas
How does new diesel fuel affect older engines
I'm curious to see if the new, low sulphur fuel, is impacting anyone's older diesel engines. I have the 6.0 PSD, and when I had the fuel filters changed a few weeks ago they showed me some sediment on the securring bolt. I don't know if it was a result of filling up or caused by the new fuel. I haven't noticed any reduction in my mileage since the change over.
What, if any, types of additives are y'all using, and how has it helped your engine?
________Tom
Blog: www.travelpod.com/members/wbcci1529
'04 34' Classic S/O lounge, dome king, twin a/c, faux fireplace to keep the wife warm , equa-li-zer, prodigy, 4 birds, cat, dog - no kids allowed!
'05 Excursion 4x4, 6.0 PSD, magnaflow, helwig anti-sway, air lift springs.
Stream 1529 is offline   Reply With Quote
Old 10-18-2007, 01:12 PM   #2
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
________Tom
Yesterday, I was configuring a new mobile command post for one of our government agencies. The unit is built on a Prevost Chassis and we had a Prevost company representative present, the unit has a new model 510 HP Detroit Diesel. He pointed out the fuel filter and mentioned that the new fuel was washing a lot of dirt out of the old storage tanks and the filter had to be watched closely as they are becoming contaminated much faster than in the past.
One more interesting bit of information is that the Detroit Diesel has so much torque it had to be reconfigured so as no to tear up the clutches in the 6 speed Allison Transmission.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 10-18-2007, 02:28 PM   #3
2dabeach
2dabeach's Avatar
Profile:  2007 25' Safari FB SE
Closter , New Jersey
Smile
________Tom
Tom
There is a good post on "The Diesel Place" forum regarding the lubricity of the new ULS diesel fuel and tests of some of the additives on the market to address the potential problem. Here is a link to the page with the post and test document:
Lubricity Additive Study Discussion - Diesel Place
2dabeach is offline   Reply With Quote
Old 10-18-2007, 05:26 PM   #4
2airishuman
2airishuman's Avatar
Profile:
a bit of discussion on this topic...
http://www.airforums.com/forums/f161...sel-28760.html
ULSD-What's your experience?
http://www.airforums.com/forums/f238...rld-25248.html
Fuel Additives?
http://www.airforums.com/forums/f238...ads-18186.html
Increasing fuel mileage
i've yet to see a bottle or try the new stuff floating on the diesel place forums...
i DO now use 1 gallon of 20% biod per tank (38) of fuel, for the added lubrication....
ALL of these concoctions may foul the 2 fuel filters and ford had shortened the recommended change interval from 20k? to 10k...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-18-2007, 06:14 PM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I run a couple of older diesels. My main driver is a 1996 7.3 PSD that just hit 100k.(bought it in 2005 with only 37k on it ) I have been running the Standyne additive as a precaution. I prefer B20+ when I can find it. There is one station that I get past every now and again that carries B80, the truck loves that stuff. Much quieter and seems to have a tad more pickup (seat of the pants method) I change fuel filters religiously at 10k which is every other oil change. To me a filter is relatively cheap insurance and well worth the few extra dollars. I plan to upgrade to an additional separator/filter unit in the near future. To me the diesel has a lot of pluses and is expensive up front but with a bit of care should be a good long term engine. FWIW I typically have run my gas powered trucks over 300k with nothing other than routine maintenance and repairs of wear out items.
Aaron
WBCCI #2449 AIR #2495
Old 10-18-2007, 06:42 PM   #6
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
I added half a tank (13 gal.) of B-20 to the Sprinter during the trip from OR to ABQ a couple of weeks ago. The difference was immediately obvious! Quieter smoother engine and 2+ MPG. I thought I was in heaven!!
I didn't find another station the rest of the trip back to FL that had BIO and mpg went back to where it had been, so I am setting up an experiment to add 1 gallon of B-100 (as soon as I can get a 55 gal drum of the stuff from the distributor in Miami) to the tank at each fill-up which will give me about a B-10 mix.
On the flip side, I noticed a 2mpg drom in mileage wen the ULSD stuff hit the pump. During the trip, I found a few stations that still pumpud LSD, and the mileage went right back up with the stuff. I hope the BIO test will do the same thing on a permanent basis.
PS: While in OR, I had my engine management computer re-programmed for +30 horsepower and +40 ft/lb torque. The difference was incredible. Subtle, but you sure know that the little 2.7L diesel was really cranking out the power. On the trip back to FL, the mileage was the same as before, but I sure pulled those long 6% grades with a lot more ease (and speed also!) I'm a happy guy!!!!!!!!!!!!!!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 10-19-2007, 02:02 AM   #7
Brad Hunt
Profile:  2007 25' Safari SS SE
Alton , Illinois
I noticed the new 15 ppm fuel gets 14 mpg while the old 500 ppm fuel does better than 15 mpg--these are tow figures. Additives are much more important in the winter and are probably not necessary until the temp. drops to around 32-40 degrees or lower, Just to be safe, I am checking my filters more often until I know how this new stuff works.
The "Ann Rutledge"
Brad Hunt is offline   Reply With Quote
Old 10-19-2007, 07:03 AM   #8
RedSHED
many cheeses are edible
RedSHED's Avatar
Profile:  1985 31' Excella
Columbus , Indiana
I've heard that ULSD & bio can both have an effect on rubber seals.
I've not seen any data on this, but it's what I've heard.
This would only be an issue if your engine is early 90's or older. (dates approximate).
RedSHED is offline   Reply With Quote
Old 10-19-2007, 07:53 AM   #9
lewster
Commercial Vendor
lewster's Avatar
Precisely!
That's why I'm only running a concentraion of B-10 (10%) max in the Sprinter. I saw one at the dealer with the engine out and totally in pieces. When I inquired about it, they said the guy was running straight BIO, and it ate the seals. They need to be Viton seals to run the high concentrations.
I don't know why they just don't build them with viton seals fron the get-go. Maybe in the near future as BO gets more use.
AIR # 10325
Old 10-19-2007, 09:03 AM   #10
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
When I do my research flights in the middle of absolutely nowhere with a runway, I have to take all of my diesel powered ground support equipment with me. Diesel fuel is generally not available without a long drive into the closest town. Our ground power unit, air conditioning cart, tugs, etc are all run on Jet A with oil added to the tanks. We have never had a problem except getting a little to much oil in from time to time and getting some smoke. We pump the Jet A right off the aircraft's tanks through a special quick disconnect to the equipment.
345 engines wpapke Classic Motorhomes 19 05-03-2007 08:11 AM
ULSD fuel and older Diesel engines? jking Classic Motorhomes 2 03-08-2007 05:52 PM
Pending Pa legislation may affect YOU!! Cedars On The Road... 9 06-25-2005 10:26 PM
Will the rise in gas prices affect your summer plans? nds Off Topic Forum 13 06-02-2004 07:49 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
