Old 01-03-2009, 10:55 PM   #1
Airdreamer
Dreamnair's Avatar
1999 30' Excella 1000
Canyon Lake , Texas
How can you tell the towing capacity?
Is there a sticker or some other label on a truck that tells you what its towing capacity is? The manual tells us what the capacity is with and without a towing package, but we can't find anything on the truck that tells us whether its equipped with that package.
Dreamnair is offline   Reply With Quote
Old 01-04-2009, 04:35 AM   #2
lafayette , Indiana
You should be able to call the manufacturer and give the serial number and get a list of options the vehicle came with.
If its a GM they used to put it on the inside of the glove box door too.
t walgamuth is offline   Reply With Quote
Old 01-04-2009, 06:07 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
You can't tow very well with a low ratio fuel economy axle. It should be a 3.73 ratio at minimum, and a 4.10 if the engine doesn't have a lot of kick. Eight cylinders are better than six. It's good to start with a strong drivetrain.
Trailer tongue weight easily is 150-300# higher than empty tongue weight (considering modest personal gear in trailer. Filled propane tanks and WD/antisway gear is all mounted up front). Add up anybody and anything else in the tow vehicle. If that and tongue weight doesn't exceed TV payload capacity you're almost good to go. This assumes one is doing no tricks to lessen tongue weight by back-weighting the trailer (a very dangerous, unstable proposition). Because then I am going to state -- with a normal loaded trailer with which you don't exceed TV payload capacity, you will not be exceeding the tow capacity. At least I've never seen it.
Maximum tow capacity is just that - maximum. It's figured under highly unlikely circumstances of a lightweight driver, a quart of gasoline (almost) and absolutely nothing else in the tow vehicle. Then you can load that tongue weight to the max. It always looks good to have high tow capacity in the ads, so the advertising dept puts in some fudge factor too. Whatever... The tow capacity number circumstances are never seen in the real world. So I stand by my statement at the end of the last paragraph if you're going to be towing with relatively normal usage.
That being said, for a truck or SUV you already own you might check kbb.com or edmunds.com, used vehicles and look for specs. New vehicle tow capacity should be on the mfgr's website.
5 meter Langford Nahanni
Old 01-04-2009, 07:01 AM   #4
Images: 59
Trailer Life has a pretty good list, but you still need to know the equipment that came on your vehicle
(period missing)
Old 01-04-2009, 07:40 AM   #5
Airdreamer
Dreamnair's Avatar
Canyon Lake , Texas
Good Guidance
Thanks for the usual great help. The reference to Trailer Life was particularly helpful.
John
towing capacity, tow vehicles
Towing Capacity streamlean Argosy Motorhomes 19 09-10-2007 07:38 PM
How much towing capacity do I need? altamont Tow Vehicles 19 02-25-2007 01:16 PM
Towing Capacity hwpeddie Member Introductions 11 05-28-2006 05:19 PM
Towing capacity of AS motorhomes? joewinfield Mechanics Corner - Engines, Transmission & More... 3 08-09-2005 07:12 AM
Towing Capacity of the 360 swebster Airstream Motorhome Forums 37 06-01-2005 03:54 PM
