Old 10-23-2008, 05:21 PM   #1
2008 19' Bambi
Decatur , Alabama
Honda Ridgeline Revisited
I am new here and just purchased a 2006 19' Bambi. I have been towing a Casita 17' Liberty Deluxe with no equalizer or anti sway set up. Some of you more knowledgeable owners with Ridgeline's please tell me how I need to set up for towing the Bambi. It is being delivered tomorrow as I bought it used (3 trips). I will not go out in it until I make sure I am set up property. The tow rating on the Ridgeline is 5000 lbs.
Thank you for your comments in advance.
Stephen
sarmstrong@allsportinc.com if you would like to email me!
Nightwind15 is offline   Reply With Quote
Old 10-23-2008, 07:32 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
How much does the Bambi weigh?
what is the tung weight of the Ridgeline?
What is the weight difference between the Casita and Bambi??
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-23-2008, 07:35 PM   #3
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Stephen, I don't have the exact weights for the '06s, but the most recent Airstream Weights guide I have lists the '03 Bambi 19 with a dry curb weight of 3770 lbs, a dry hitch weight of 425 lbs and a GVWR of 4500 lbs. Your Ridgeline has a max tow weight rating of 5,000 lbs, so by the time you get gas, passengers, and luggage in the Ridgeline, it's going to be near or over it's GCVWR. You'll be OK, but barely. I don't know what the rating is for dead hitch weight on the Ridgeline, but I'll bet Honda suggests weight distribution when it pushes 500 lbs.
I have looked at Ridgelines on several occasions, but the 5000 lb tow rating was a killer for me. I recently bought a Nissan Titan to tow my 5300 lb Bigfoot 25' with. We traded in our '06 Civic with 60k on it on a new close-out '08 Accord this week and our dealer had a nicely equipped '08 Ridgeline with $7k in discounts... it was tough not to look!
I don't know what you towed your Casita with, but you won't notice much difference between it and the Bambi. I'm a big proponent of weight distribution and sway control hitches, and for the Bambi 19/Ridgeline combo, a Reese Dual-Cam with 600 lb bars would be just about right. I'd also recommend a Tekonsha Prodigy or P3 brake controller. Your trailer will weigh nearly as much as your truck, so you'll want every edge you can get in handling and braking, and the WDH/brake controller are about the best edge you can give yourself.
Good luck!
Roger
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 10-23-2008, 07:38 PM   #4
purman's Avatar
1968 28' Ambassador
Well there you Go.... Roger your the man.... Sounds good
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-23-2008, 08:04 PM   #5
Road Ruler's Avatar
Images: 38
We spent spent some time a month ago with a couple that were towing a newer, large Airstream with their Ridgeline. It was a pro set up and with the "orange" connection. They said it towed great and had no complaints. Seems like a Bambi should be a piece of cake.
Old 10-23-2008, 08:39 PM   #6
mustang's Avatar
1999 27' Safari
Kent , Ohio
I read an article about the ridgeline, check with your dealer / hitch installer. I am not sure on year or what but it had something to do with the unibody construction.
mustang is offline   Reply With Quote
Old 10-23-2008, 08:52 PM   #7
SteveH's Avatar
Common Sense , Texas
Yes, I read somewhere that Honda did NOT recommend a WD hitch with the Ridgeline.
Regards,
Steve
Old 10-23-2008, 08:59 PM   #8
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Here's an enlightening thread from the Ridgeline Forums started by our own Jack Canavera!
Weight Distribution Hitch
Roger
Old 10-23-2008, 09:02 PM   #9
Road Ruler's Avatar
Images: 38
Old 10-24-2008, 12:18 AM   #10
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I wonder if the Ridgleline being of unibody construction is why Honda recommends not using weight distributing hitches? Perhaps it places undue stress on the roof? When we tested the Ridgeline at Ford's Arizona Proving Grounds it was the only vehicle whose roof popped( an oil can like pop) when it was driven through the twist ditches. No other unibody type Suv did that. Makes me wonder if you could buckle the roof with a WDH?
Diesel1 is offline   Reply With Quote
Old 10-24-2008, 06:40 AM   #11
Road Ruler's Avatar
Images: 38
Nightwind.... The Ridge is a popular TV...
Over 90% of the Ridgelines towing TT's are using WDH's and there are no reports of issues resulting from the use of a WDH. So much for Honda's document suggesting not to use one. Misprint!?!?
Check out the Ridgeline owners club. There are 40 pages of positive results and experiences from Ridgeline owners.
Ridgeline's can tow (photos) - Honda Ridgeline Owners Club Forums
Old 10-24-2008, 09:40 AM   #12
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
This is true. We don't use one and haven't had any problems.
Ahab is offline   Reply With Quote
Honda Ridgeline RTL Tow vehicle mswartz Tow Vehicles 11 02-18-2013 05:10 PM
Towing with a Honda Ridgeline lloydnc Tow Vehicles 26 05-07-2008 09:37 AM
Towing with a Honda Ridgeline? lloydnc Tow Vehicles 9 11-19-2007 08:24 AM
Towing with a Honda Ridgeline air19 Tow Vehicles 17 10-26-2006 11:58 PM
