Old 01-03-2013, 05:41 PM   #15
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by TouringDan View Post
Aviator
I don't imagine your buddy has weighed his loaded truck at a CAT scale. I would not be surprised if he is exceeding the rear axle weight rating (4,050 lbs) by 1,000 lbs or more. Remember that his tongue is sitting right above the rear axle. I don't believe you can tow any loaded 5th wheel trailer with a 1/2 ton truck without exceeding the rear axle weight rating. Well there is one exception- a fiberglass Scamp 5th wheel made a few years ago.
Dan
What about that video of a VW bug towing a 5th wheel someone posted in another thread?
Old 02-10-2013, 03:18 PM   #16
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
My buddy tows a huge fifth wheel with his 2010 F150 and the Ecoboost power plant. He is very pleased with 11 or so mpg while towing and 22mpg around town when not towing!
hmm. Payload, payload payload.
I agree with you Dan. Too much for a 1/2 ton. This is exactly what the problem is. People shop considering the towing capacity only.
Switz, you are doing what you have to do, plan it out. Mojo is right 1100 lbs. tongue WD hitch. Your homework is correct. I believe you are spot on with the 25' and would also be fine with 27' or even 28'. I believe that beyond that you may be getting to the edge- Payload and, as you say GVWR. You will have the power though for sure.
Old 02-10-2013, 03:27 PM   #17
LFM
LFM's Avatar
2007 19' Safari SE
Laurel , Montana
Originally Posted by Aviator View Post
As an addition to my above post. My buddy tows a huge fifth wheel with his 2010 F150 and the Ecoboost power plant. He is very pleased with 11 or so mpg while towing and 22mpg around town when not towing!
I may br wrong, but when I bought my 2011 Ecoboost F150, I think that was the first year they were available.
Greg
LFM is offline   Reply With Quote
