Old 06-25-2011, 10:39 PM   #1
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Home made mud flaps.
Hi, I have been contemplating making mud flaps for my Lincoln and finally decided how I was going to do it. I won't know how well they work until I take a trip, but they should be better than nothing. I decided that it would be simple to add an angle iron on the bottom of my hitch receiver. I bought a piece of 1" angle iron from the metal supply store. I had them cut it 7' long and when I started to fit it in place, I decided that it was about 6"s too long. I laid the angle iron on the ground, up against my rear wheels and cut it to the width of my rear tires. There are two bolt holes on the bottom of my receiver that I had planned on using. I also needed to use larger nuts and a few washers to space it evenly. The two bolts weren't enough to hold the angle iron firm enough so I cut two smaller pieces of 3/4" angle iron to make end brackets. To hold the end brackets in place, I had to drill two 1/4" bolt holes in the receiver. [warning do not cut drill or weld the hitch] OOOppps. Oh well two little holes shouldn't hurt anything, especially where I drilled them. I went to NAPA Auto parts store and bought two of the smallest truck mud flaps they had in stock. I measured and drilled my angle iron and rubber mud flaps to fit where I wanted them. I decided that I wanted to make my own mud flaps because I wanted them to stay on my tow vehicle whenever I unhooked and removed my Equal-i-zer hitch assembly and be able to remove them easily with only four bolts. The total cost was right at $50.00, The break down is $6.00 for the angle iron, $30.00 for the rubber mud flaps, and another $6.00 for nuts bolts and washers. Plus taxes.
ID:	133297   Click image for larger version
ID:	133299   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-25-2011, 10:52 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Those home made mud flap looks good! I've been contemplating making some myself. Thanks for sharing how you did it.
Old 06-26-2011, 07:03 AM   #3
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I like that!! In fact, I guess I will be doing that. You did I very clean, simple design that will work good.
Thanks for sharing,
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 06-26-2011, 07:59 AM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
BOB
They look real good. Thats kinda what I did. I went to the local Fruehuf Dealer(semi-trailer dealer) he had several skids of flaps that were ordered by some company and not used. My hitch(receiver) that came on the truck had openings on the ends. I used two peices of aluminum angle each pushed in from each side.I think I had the bolts and washers. The angles are held in by a tarp strap and can be removed if needed. I probably have 12 bucks in mine. SORRY No pictures. They have been on the truck for 3 or 4 yrs now. I just leave em on all the time. SW 1 tons dont come with flaps is why I leave em on all the time,to protect others and it helps keep from throwin water and stuff on my flatbed and on customers equipment while in transit and I dont have to go hunt them everytime I hook to the AIRSTREAM.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 06-27-2011, 08:50 AM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Looks good Bob!
I'm also working on a set that is removable. I have everything welded up now I just need to get the flaps.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-27-2011, 09:14 AM   #6
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Bob;
Mud flaps??
that ford product got 4 wheel drive?
drive much on dirt roads?
BUT
Where's the chrome silhouette girls?
I'll be looking for them when I see you in Oct. ! !
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 06-27-2011, 09:44 PM   #7
Salem , Oregon
Images: 18
Originally Posted by doorgunner View Post
Bob;
Mud flaps??
BUT
Hi, doorgunner.
Mud flaps??............... Yes of course.
That Ford product got 4 wheel drive?............No, and you don't have to have 4 wheel drive to need mud flaps; The rear wheels can do a lot of kicking.
Drive much on dirt roads? .................No, but this next trip might be on some unpaved roads.
Where's the chrome silhouette girls?...............Lee Lee said I can't have them; I told her I would put the naked lady on my side and a naked man on her side. I got one of those looks that only a wife can give you!!!!
2005 Safari 25-B
Old 06-27-2011, 10:19 PM   #8
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
You guys are too funny
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 07-05-2011, 10:49 AM   #9
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Mud Flaps, Toad Rock Guard
I tried also to solve the flying stone chip problem for a small investment.
I have mounted behind the wheels the normal OEM mud flaps, but needed something to protect the toad.
My problem with the Clipper was that with the overhang and the low suspension height, many times I will drag the rear on the entrance to the coffee shops on the road. Anything solid on the rear is going to be damaged. I did not want an expensive skirt and solid heavy flaps were not the answer.
This seems so work so far and is light and pivots on the aluminum round stock.
It allows airflow, but restricts most rock chips and slows any that bounce off it.
Our toad Tracker has not experienced any damage so far.
Dave
Name:	deer and motorhome july 2011 036.jpg
ID:	134006   Click image for larger version
Name:	deer and motorhome july 2011 021.jpg
Name:	deer and motorhome july 2011 020.jpg
ID:	134008   Click image for larger version
Name:	deer and motorhome july 2011 019.jpg
Name:	deer and motorhome july 2011 017.jpg
ID:	134010   Click image for larger version
Name:	deer and motorhome july 2011 016.jpg
Old 07-11-2011, 09:05 AM   #10
JFScheck's Avatar
Rockville , Maryland
Images: 33
Nice job Robert, and they look good too!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 07-11-2011, 11:00 AM   #11
dznf0g's Avatar
Oswego , Illinois
Nice, Robert. One suggestion. It appears that there is a space at the top where rocks could get over the top between the bumper cover and the top of the flap. ( and the little ^&*!!!#$% will find any crack). If you can stand behind the truck and see any portion of the tire tread, I would suggest mud flaps for the truck wheel wells, or installing an extension for your rubber a few inches above the metal bar. High enough that you cannot see ANY tire tread from behind.
NEVER MIND, I blew up the pic and see that you have extra rubber folded under. I would worry about wearing the paint on the bumper though. Maybe a couple of Velcro loop side, stuck on at the contact points?
Old 07-11-2011, 10:56 PM   #12
Salem , Oregon
Images: 18
Hi, yes the rubber mud flaps fold up under the rear bumper, so that area is protected. As for the paint, The Lincoln isn't that nice anymore and I suggest that anyone taking a trip, such as I'm on now, wait a few years with your trailer and tow vehicle because they will be damaged. "Bob & Lee's random trip"
2005 Safari 25-B
Old 07-12-2011, 02:05 AM   #13
batman's Avatar
1964 22' Safari
modesto , California
Robert I like your idea. I would like to try combining masseyfarms idea with yours. Only using all aluminum angle and frame extruded aluminum for the flap/rock guard. Bolt it on when needed and remove it when I don't. Thanks for sharing...
batman is offline   Reply With Quote
Old 07-12-2011, 09:52 PM   #14
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
masseyfarm Dave--
Are those vortex generators on the aft side of your rig?
Have you run a reynolds number analysis on your rig?
just wunderin,,,,
www.popasmoke.com
YETI ( 65 Quart )
How about MUD FLAPS? Splitrock Rock Guards, Segment & Window Protectors 98 11-22-2017 08:02 AM
AS Tax Deduction as Second Home boutdoors Dollars & Cents 36 05-16-2016 02:58 PM
1500 Mile Trip to get her home - Suggestions? Bambi_Bandit 1960 - 1964 Overlander 17 03-01-2015 05:17 PM
