Old 03-21-2008, 09:48 AM   #1
safari25-05's Avatar
summerfield , Florida
high pitch whining noise..
I have a 1996 chevy tahoe, 5.7 liter. When traveling in warm to hot weather, there is a high pitch whinning noise under the car, happens even if not towing. Anyone had this problem and if so how did you solve it. Thanks
safari25-05 is offline   Reply With Quote
Old 03-21-2008, 09:52 AM   #2
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Sounds like you need to call Click and Clack.
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 03-21-2008, 10:10 AM   #3
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Alternator?
Transmission?
Could be lots of things.
If you have a mechanics stethescope or just a wood dowel, you can probably isolate it to an area or item.
Good luck.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-21-2008, 10:19 AM   #4
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Is it there regardless of speed?
I'll suggest fuel pump...
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 03-21-2008, 10:23 AM   #5
Retired.
. , At Large
Bill
I'll second the fuel pump suggestion. Especially if it has ever been replaced, they tend to hum, buzz, and howl whenever the engine is running, whether the car is moving or not.
Old 03-21-2008, 10:25 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Does it happen all the time. Or is the annoying noise only when the other half is also in the truck....
Old 03-21-2008, 01:53 PM   #7
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Fuel pump. noise is good. no noise, oh oh, no start and ka ching ka $chingaling. Keep your fuel tank over a quarter full to keep coolant on the intank fuel pump.
NevadaGeo is offline   Reply With Quote
Old 03-21-2008, 02:31 PM   #8
1973 25' Tradewind
Romulus , New York
I had the same problem on my 95 burb. see if it is louder when the tank is low.
jayray5 is offline   Reply With Quote
Old 03-21-2008, 02:52 PM   #9
1 Rivet Short
1989 25' Excella
My last GMC started whining when it reached 90k miles or so...
Bill
Old 03-21-2008, 04:53 PM   #10
Ned
1986 31' Sovereign
North Judson , Indiana
I have a Tahoe 2002, the rear diff gets low of the 90 weight oil and the the gears will have a whine. I had a leak after a repair and found that the gear housing was low. quieted down when I added some.
hned10060 is offline   Reply With Quote
Old 03-21-2008, 05:59 PM   #11
jayray5..question
can you tell how you solved your problem?? And no to your question to me.
Old 03-21-2008, 06:11 PM   #12
1973 25' Tradewind
Romulus , New York
solved it
My problem was a bad fuel pump--I replaced the whole tank, start up your truck and put a long extension (metal or even a broom handle) up against the tank. If you feel the vibration that is it. Put it to your ear and you will hear the whine.
Old 03-21-2008, 06:49 PM   #13
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
My father had a vac. leak at the tranny that had the same noise. Sounds alomost like you got a turbo at low speed...?
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 03-21-2008, 07:39 PM   #14
1984 31' Excella
Broken Arrow , Oklahoma
Images: 11
Whiney sound
Mine is caused by the power steering pump (1990 GMC van).
It sounds like a turbo charger all the time the engine is running also.
Beginner
Beginner is offline   Reply With Quote
My trailer is whining! thecatsandi Batteries, Univolts, Converters & Inverters 7 01-03-2008 09:35 AM
How high have you been????? FlaAirstream On The Road... 23 10-27-2007 10:41 AM
Noise flyguy Batteries, Univolts, Converters & Inverters 5 06-07-2007 04:56 AM
Dining and whining? Amy in an Argosy The Pet Forum 21 03-02-2004 06:01 PM
**Furnace Noise** Silvertwinky Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-07-2003 03:42 AM
