Old 06-22-2014, 07:06 AM   #1
Sequatchie , Tennessee
Hensley TruControl Gold brake controller?
Does anyone have any experience with this brake controller? I am thinking about buying one. This is the newer model that has the Tri-Axis sensor inside it, not the older one that hooked to the brake Master Cylinder.
They are on eBay for a good price right now and I was thinking about getting one.
Thanks!
Jeremiah
jerem0621 is offline   Reply With Quote
Old 06-22-2014, 07:20 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
We've had a Hensley brake controller for years and are very happy with it. They did replace it for us twice because of display failures with the early units. Third time is the charm, because this one has worked find.
We bought from the factory, so don't know what you might find on eBay. Watch out for those early bad display screens.
Old 06-22-2014, 07:22 AM   #3
1966 22' Safari
Weatherford , Texas
I meant it has worked fine. Need to proofread, since I type poorly.
Old 06-23-2014, 05:27 AM   #4
Thank you for the reply! Looks like I will be purchasing one of these brake controls
Old 06-23-2014, 06:53 AM   #5
1966 22' Safari
Weatherford , Texas
You might check with Hensley to see what warranty support they will give on second-hand units. We definitely needed the warranty on the first two.
Old 06-23-2014, 08:03 AM   #6
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
Wow $38 on ebay and $197 ($100 off from the regular price of $297) from Hensley. Doesn't sound right. Stolen/defective?
BeachHouse is offline   Reply With Quote
Old 06-23-2014, 10:16 AM   #7
Air Apparent's Avatar
Northern Illinois , Illinois
I have a Hensley True Gold controller that I purchased in 2009. This is an older model where the display "burns out" and no longer displays. That is what has happened to mine. It still works except for the display. So I wan to replace mine at some point in time.
I called Hensley this morning and I was informed that they have since changed the type of display as this was a problem in the older model. They will give me a discounted price on a new or rebuilt one because I have the old model.
I asked about the ones being sold on e-bay for $39 and was told that they believe that it is the old model being sold.
Dave
2008 Classic 34
Dodge Ram 2500 Quad Cab CTD
AIR #7317 WBCCI #1772 TAC-IL 1
Air Apparent is offline   Reply With Quote
Old 06-23-2014, 12:02 PM   #8
2002 19' Bambi
Lafayette , California
We have used the Hensley controller for a number of years. The display of the first one started to give out and I don't remember if they replaced it or gave a good discount on a new one.
In any case, we have been very pleased with the controllers.
Tim
Tim A. is offline   Reply With Quote
Old 08-17-2014, 10:19 AM   #9
2trackrr
1991 34' Limited
Waxahachie , Texas
Hensley Brake Controller
We had 3 hensley brake contollers on 1 trip last year. Some how we got home safe after we stopped and bought and installed a Tekonsha Prodigy P2 Electronic Brake Control. Hensley makes the worse brake contoller i have ever used and only bought it because of the quality of their hitch system. It is very poorly designed, built and functionality.
If it did not have the manual control on it we would have been killed when a semi "T" boned us. All in all when you manually lock up 3 axles you will stop a 34FT AS.
Save your life don't buy this product.
2trackrr is offline   Reply With Quote
Old 08-18-2014, 06:13 AM   #10
Thanks! I ended up getting a good deal on a Draw-Tite Intella Stop which is a rebranded Tekonsha Prodigy. This Hensley just didn't pass the sniff test, especially thanks to this thread.
Hensley gold 2 brake controller kingfisher Brakes & Brake Controllers 0 09-21-2011 02:54 PM
Hensley TruControl Gold TBC nickmeloy Brakes & Brake Controllers 0 12-01-2009 08:10 PM
TruControl Gold Brake Controller acltaos Brakes & Brake Controllers 15 07-12-2009 11:03 PM
TruControl Gold Brake Controller acltaos Brakes & Brake Controllers 40 06-25-2009 05:47 PM
Hensley TruControl Brake Controller? fred bartlet Brakes & Brake Controllers 4 09-06-2007 08:21 PM
