06-23-2008, 11:37 PM
#21
1960 24' Tradewind
santa barbara
Ill respond to lieppers posts real quickly .It sounds like you have not had the experience of having someone pull right infront of you or your trailer brakes failing down a grade .Possibly the experience of rich luhres tail of his wheels rolling down the hill from broken wheel studs ,his brakes overheating and so on .it absolutly does
happen and the crashes weve seen on the highway and experiences of other forum members like thecatsandi come to mind ,crash of her airstream and pickup on a snowy road ,not the freeway either ,all excellent reasons to be prepared ,so why argue the point or dimiss peolpe who are thinking out the towing scenario and erring
on good judgment .Im at a loss to understand ,i think its just to argue the point .
Scott
06-24-2008, 08:18 AM
#22
1975 29' Ambassador
Reno
, Nevada
It is indeed really amazing! now we have the gang up on unpleasant ideas phenomena!
Yes, *it happens; there is a surfeit of idiots out on the road; all drivers needs to be prepared. But take a look at the reaction here. Take a look at the assumptions being made, what assertions are being made, the scenarios being cited and their applicability to the issue at hand.
One thing to note is the selectivity being suggested in who you listen to. I see a 'listen to forum folks who agree with me and not to a dealer who does extensive testing and has a business on the line who does not' - listening to only what you want to hear is not, IMHO, a good way to learn. Then there is the denigration of others' (e.g. mine) experience when what is being said is disagreeable - don't you think it would be better to deal with the substance of the issue rather than to try to denigrate the person raising it?
Also note the value judgments such as about the "right way" to do things that is unconditional and absolute - but not qualified or supported in a rational way.
The FUD mongering about brakes is just that. Yes mechanical systems can fail. Mechanical failure is definitely something to warrant concern. That doesn't mean confusing going down hill in the wrong gear with the entirely different situation of a panic stop is pertinent.
Also note that questions raised were ignored, points bypassed, qualified opinions ignored, and issues diverted.
I don't think using an Ody to tow a Sovereign is anywhere near as far out of the distribution as some of the arguments being made here to rationalize it being a bad idea. That doesn't mean that the Ody would be a 'normal' tow vehicle but rather that some folks are reaching very very far into the fringes to explain their opinions about why it shouldn't be.
06-24-2008, 09:29 AM
#23
Central
, Mississippi
There's at least one Honda/Airstream combo running the road. Last November I spotted the same unit twice in Natchez but never caught up with them to talk. They were towing a new 25' size, possibly heavier than a vintage 31'
06-24-2008, 10:36 AM
#24
St. Catharines
, South Western Ontario
There are a lot more than just one. Check out posts #8 and #10....
http://www.airforums.com/forums/f238...lot-40240.html
06-24-2008, 01:32 PM
#25
1975 Argosy 24
Collierville
, Tennessee
Originally Posted by Leipper
The Ody tow rating serves purposes other than helping folks determine what it will tow. OdyClub Forums has a number of discussions about towing with the Ody. Can Am RV in Ontario has helped a number of folks configure rigs that might not otherwise seem suitable to make comfortable (and safe) combinations.
The Ody has a 250 HP engine so it has the power. For the 2000's the weak spot may be the transmission but that can be handled with proper cooling.
i.e. towing with the Ody may make the weight police blanch but it can be done if the appropriate considerations are taken.
The 2000 model did not have the 250 hp motor. I'll elaborate, it had a 210 hp motor until 2004 when it got a 240 hp motor and then in 2005 up to 250hp.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
06-24-2008, 01:49 PM
#26
1975 Argosy 24
Collierville
, Tennessee
Happens on here all the time dude, if you don't listen to them and do as they do then you're a friggen idiot, even if you have had different personal experiences.
I like the way you think, appreciative sentiments previoulsy known here as Karma are coming your way.
Heinlein
06-24-2008, 04:38 PM
#27
1975 29' Ambassador
Reno
, Nevada
Thanks for the clarification. Personally, I don't think it makes much difference as normal use doesn't really need that much power (Consider that 80,000 lb semis often only have 300 - 500 hp) It is the tranny and gearing that is more of a concern, especially on the pre 2005 Ody's.
I think that the increases in power and efficiency of modern vehicle engines and transmissions are an amazing advance that often seems taken for granted. It used to be that slogging up highway grades was accepted as a fact of life but now it seems expected that even an 8% grade shouldn't slow you down no matter the load or elevation.
yeah, I know. One of my pet causes is for better civility in these discussions so that some of the more interesting voices are less inhibited about offering their insights. I figure exposure is probably a good first step.
At the Western Pacific Ralroad Museum rally this past weekend I couldn't help but look at those locomotives (600,000 hp! ?) and think about the tow vehicles some folks seem to think appropriate. ;-) I guess Don has a bit more practical approach (see GOAL: Get Out And Look! on Zephyrs). Jerry says they used to have a smaller locomotive (only 6,000 hp?) in a parade in Hawthorne - that could look interesting towing an Airstream.
06-24-2008, 07:18 PM
#28
Liquid Cooled
2017 27' Flying Cloud
near Indy
, Indiana
A couple years ago I looked at the then new Pilot. It too had a 3500 lb towing capacity, but it had the added restriction of 25 square feet of frontal area.
My recollection is that this was to keep the transmission from leaking out the magic juice that makes it run, but I could be mistaken.
06-24-2008, 07:22 PM
#29
Liquid Cooled
near Indy
, Indiana
Slightly OT, but I'm thinking there are only two or three locomotives over 6000 HP. A couple of the larger steam engines approached that, then after a wait of 40-50 years some of the GE and EMD units hit that range.
I agree about the 80000 lbs on 300 hp. I think you'll see lots more of that.
06-24-2008, 08:11 PM
#30
1986 25' Sovereign
Southern Middle
, Tennessee
ya' know, it gets really interesting the degree to which folks go to try to refute some things (or individuals). Knee jerk responses are just as dangerous in these discussions as they are on the road IMHO.
Do you really advocate sudden maneuvers with an RV as a general means to avoid disaster? Really?
Do you really think it a good idea to tell a newbie that he should swing the steering wheel to avoid things with his RV? Really?
What would happen if your "slightly" was 'slightly too much' ?? Perhaps you have the experience to know how much steering at what speed you can get away with but do you think it good advice to suggest others work that line as a general thing? Really?
And just what is an "emergency maneuver" anyway? Is it a slight change in steering or is it an effort to make a sudden large change in direction?
What you can get away with or what you may have survived is one thing. Those incidents may even provide material for examples and be useful if they can provide insight into general rules or concepts. Otherwise, it pays to consider just what you might be suggesting as driving advice and to whom you suggest it.
Don't blow this out of proportion! I checked out the right lane, applied the brakes (didn't stab them to the floor) until I realized that the trailer brakes had not responded as quickly as I had hoped, then steered past the jerk. You weren't there, you don't know my truck, Hensley Arrow and trailer combination so give it a break. Yes, slamming on brakes and jerking the steering wheel can very well cause a jack knife. Fortunately I have 4 wheeled for many years on dirt roads and mud as well as taken our department's defensive driving and pursuit course. I don't claim to be an expert but I'd do the same thing again tomorrow if faced with the same situation. You do what you wish.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
06-24-2008, 08:54 PM
#31
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
http://www.quorumcorp.net/Downloads/...tyOverview.pdf
I'd like to see a picture of that 600,000 HP locomotive!!!
"You don't know where you've been until you leave, enjoy life" RLC
06-24-2008, 11:26 PM
#32
1975 29' Ambassador
Reno
, Nevada
re "I'd like to see a picture of that 600,000 HP locomotive!!!" -- me, too. But that's why the question mark as what I was told didn't make sense (except for hyperbole about some folks tow vehicle preferences ;-) )
I believe this is the vehicle
The history is at Union Pacific's DDA40X Centennial Locomotives - that page indicates a more reasonable 12k hp but I am not sure if it is for half or all of this thing.
I think the weight ratio of this locomotive to an Airstream and also the wheelbase ratios would please some worried about towing capabilities as well - some probably think you'd still have to have a HAHA or a ProPride hitch, though, even when still using rails ...
exactly!
one common error, perhaps a nitpick, but the number isn't a capacity but rather a rating. What I'd like to know is why so many of these cargo vehicles have the same rating. The Honda Pilot uses the same engine with only minor differences (as far as I can tell) in the gearing but has a higher rating. The Ridgeline has a lower hp engine but a higher tow rating.
The note about frontal area is getting into what I think are more pertinent criteria than many we have seen in this thread. I've put enough chicken scratch in the back of my Ody to know how a typical Sovereign tongue load will impact handling so I don't consider that to be much of an issue. I've also seen how the tranny handles engine RPM with loads and some rather steep highway grades so that isn't much of a worry, either. But frontal area representing a continual wind loading could be a factor in overall stress.
Tow ratings just offered on a spec sheet doesn't help much if you don't know what factors are assumed, presumed, and considered in its calculation and the variances involved.
The fact is that GCWR and towed load ratings are dependent upon many factors. IMHO typical abuse of these ratings will have a driver seeking alternatives well before any failure mode for exceeding such ratings is going to appear.
06-25-2008, 12:08 PM
#33
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
6600 hp each
Tow a lot of streams with that
06-25-2008, 02:45 PM
#34
Ridge Runner
1998 34' Excella 1000
Hattiesburg
, Mississippi
Won't know untill you try
This is an interesting thread. He wants to pull a 31 ft. trailer with a Ody? He won't know until he tries. Get on some depends and go for it.
2003 Chevy 2500 HD D/A LS EC SB, Leather Seats, Fog Lamps, Bilstiens Shocks, Nerf Bars, Edge Juice/Attitude , 50 Gal Aux Tank, Jordan Brake Controler, Century Ultra Cap W/Lift Side Windows
1998 34' Airstream Classic, 1400 lb Hensley Arrow Hitch, two EU 2000i Hondas
06-25-2008, 03:21 PM
#35
2007 25' Safari FB SE
Bozeman
, Montana
Try these spreadsheets to get a quantitative estimate!
http://www.airforums.com/forums/f463...tml#post456088
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
06-25-2008, 05:14 PM
#36
1975 29' Ambassador
Reno
, Nevada
that I'll do, but this isn't the point at issue. The point at issue is generic advice for others that will help them stay out of trouble. We should be setting good examples, not bad ones both in these forums and on the road. The FUD mongering on one side contrasted to the 'see I can to do it' on the other doesn't help anyone.
or borrows from the experience of others who are doing it - such others as often seem to get abused on these forums.
This is the common presumption of binary phenomena. I see it a lot as a form of argument - Either something works or it does not with nothing in between. What makes it a rather poor form of argument is that very few of these things actually work that way. Its close cousin is the numbers game as if they have no qualifications and are absolute arbiters of absolute accuracy.
There are many factors to consider and evaluate in context in choosing a tow vehicle. It is really too bad that you cannot discuss them in a forum like this without encountering diapers arguments.
06-26-2008, 11:30 PM
#37
1960 24' Tradewind
santa barbara
with all due respect liepper, you yourself are engaging in the very thing your crying about ,abiet you are wording it in a more contrived type of dialect .never the less ,
you are in fact disregarding the actual experiences of members such as I and the others posting on this thread , that have in fact been involved in actual situations .
We have a great perspective of BEING THERE ! in those situations ,not only the manuvering from harms way ,but all trailer towing .i see that you complained about being challenged on your view as if it should be off limits ,yet you can in fact continue
to malign those that don't share your view as " arguementative " and so forth .
I also see that your reply here implies that many don't know what there talking about
with there own experiences , davidz71 for starters . you do not address the actual events I stated either so ,one has to conclude therfore that your own opinion is all your concerned about .Ridgerunner has it right ,its not about diapers liepper ,its about getting the CR%#@$ scared out of you ,when things go wrong .Trying somthing different might be fine in some cases ,telling someone he can tow a 30 ft airstream
with a honda minivan when he DOES NOT HAVE ANY EXPERIENCE DOING SO is quite
another thing altogether especially if the vehical is clearly overloaded and your
disregarding hondas tow ratings on top of it all .you guys have to stop looking at the
210 0r 250 horsepower rating ,thats only a small part of it . If you don't want advice
from the folks here that have the real world EXPERIENCE ,don't ask for it .
Scott of scottanlily
06-27-2008, 08:22 AM
#38
1975 29' Ambassador
Reno
, Nevada
ah yes, now the ad hominem ("contrived type of dialect') and other misperceptions.
"disregarding the actual experiences of members" - I don't think so as I don't see other Ody owners talking about the vehicle and I do see a lot of prognostication about low odds events (brake failure), anticipated fear (diapers), weight absolutes (ratings vs capacity), and other rationalizations. Theorizing is not an actual experience and a lot of what I have seen in this thread is theorizing rather than actual experience.
"to malign those that don't share your view" - I try very hard to malign only the logic used or the conclusion, not the person. There is a very big difference between the behavior and the person. I avoid comments directed to individuals ("with all due respect liepper") and opinions about personal character ("you ...") and unfounded accusation of implications.
I (try to) listen very carefully to those who do not share my views and pay attention to the basis for the views. I also consider my own reactions and responses. That is how I learn. As I noted above, I often get dissapointed because the views I see are based more on ideology and theory than on an effective consideration of factors and issues in the real world. I'd love to discuss the points I raise so I can hone them but, instead, my personality gets razed.
"you do not address the actual events I stated either so ,one has to conclude" - jumping to conclusions about an absence is not a safe activity IMHO. Perhaps I didn't address the topic because I didn't want to be too insulting to someone? Or perhaps because I didn't consider the issue of value in this discussion? Or perhaps I was trying to avoid excess inflamation of the discussion?
"especially if the vehical is clearly overloaded and your disregarding hondas tow ratings" - how do you know the vehicle would be overloaded? Isn't this a presumption created from nothing?
" If you don't want advice from the folks here that have the real world EXPERIENCE ,don't ask for it" - I wasn't the one asking for advice. I am just objecting to what I think is bad advice that seems based on questionable assumptions, a lack of recognition of the factors involved, misperceptions, errors, and a dismissal of the experience of those who have indeed 'been there and done that.'
06-27-2008, 09:47 AM
#39
Vintage Kin
Fort Worth
I get tired of the assumptions that the unibody and body-on-frame cars of the 1960's and 1970's didn't exist. Or, pull trailers up to around 7,500-lbs (sometimes more) without incident, without extraordinary expense to the owner, for up to (and beyond) 100,000 miles with drum brakes, hydraulic shocks, bias-ply tires and all the rest. They did.
I can see that there are vehicles now that likely can do a nice job, using the criterion of that day and age (Chrysler 300/Charger/Magnum). As well, the TT tires/shocks/brakes/lighting are better, the hitches can be FAR better and roads in general have better signage and markings.
I also don't remember anyone being dumb enough to tow at 70 mph pre-1974 (diesel truck and toyhauler anyone?) I am not in favor of mixing in driver skill in this kind of discussion because the range is huge, but ANYONE driving an RV of any sort ought to have respect for the fact that these are the least-able vehicles/rigs on the road.
My parents, grandparents and I all did this with cars, right into the 1980's. Several hundred thousand miles of the US, Canada and Mexico. (And the unibody Chryslers were the best of these; as well as the high-compression engines of the late 1960's).
Leippers comments are dead-on about the nature of these discussions, even though I advocate knowing what one's rig feels like in an emergency lane change maneuver (which is different than it is in a car, the time for "emergency" is sooner, the steering action less, and hopefully one knows the speed at which this can be done and is not far above it.
Shouting it down, using language that denigrates the other voice, circular reasoning . . . give it a break.
As to whether that Odyssey can haul that trailer, sure, looking at the numbers is the very first consideration. But it doesn't lead to a predetermined answer.
06-27-2008, 09:57 AM
#40
1998 31' Excella 1000
South Berwick
, Maine
I'm not saying right, wrong, indifferent or offering an opinion - I'm just saying that a couple of weeks ago I attended a rally where a guy was pulling his '70's 31' with a Odyssey (year?), and his Dad was pulling his 34' with a Astro van (I think he went to Alaska with it).
WBCCI 24291
New England Unit
Metropolitan NY Unit
