Old 04-15-2019, 02:56 PM   #267
pgordon888's Avatar
Philadelphia , Pennsylvania
Help spec a new F-250
Went through the whole F250 v F350 thing last summer when we were awaiting delivery on our new 14000 GVWR TT. We only have garage parking in the city for 2 cars so adding a super duty as a towing vehicle only was not an option (hanger outside of town for TT). Honestly, I could not tell any difference in ride comfort between the 250 and 350 on the test drive but loved the diesel towing specs and acceleration so knew the 350 was the only option after the dealer visit. Installed 4 corner Kelderman air ride with up to 8 inch on the fly adjustable ride height so as to fit in our garage. Bonus is that the highway ride quality is now on par with our old airmatic equipped Ď14 Mercedes GL. Not an inexpensive solution but much more affordable than adding a 3rd vehicle.
2019 Living Vehicle T27 "Live Series" TT
2019 F350 SRW SB (4 Corner Kelderman Airride)
2014 Nissan GTR (full 1100 WHP well-rounded build)
pgordon888 is offline   Reply With Quote
Old 04-15-2019, 03:31 PM   #268
CRH
1995 25' Excella
xxxxx , xxxxxx
I also drove a 250 and 350 before ordering. I couldn't tell a difference, either, when it came to the ride. I chose a 350 gasser with 4.30 gears. I also got snow plow and camper prep springs. I think the truck rides just fine...I use my truck for more than just the AS. Just the other day, I pulled a 12k pound trailer on the bumper and had no complaints.
CRH is offline   Reply With Quote
Old 04-15-2019, 03:57 PM   #269
pjshier's Avatar
2017 27' International
Wasilla , Alaska
Ride improvement
After several months and 2K miles, I can report the Sulastic hangars are working as desired: takes the "bite" out of the F350 unladen ride. about 1200 miles was across "suboptimal" Alaska highway conditions. I really like the idea of the air suspension for height adjustment, though. In the mean time, the Sulastic hangars "cusion" the ride and mitigate unladen rear axle hop going over significant pavement transitions.
2017 Int'l Serenity 27FB
2017 F350 oil burner
pjshier is offline   Reply With Quote
Old 04-15-2019, 05:38 PM   #270
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Originally Posted by pteck View Post
Yes, I did comment on the add on packages.
It's all for the sake of bringing some balance back into the dialogue that's common here - where more is more and more is always better.
As many of us know, more is just more. And more is not always better. Because there is always a cost. Either literal, or it tips the balance towards some quality at the detriment of another quality.
Payload capacity is one of those things. Boiled down, it's very much about spring rate. Sure there's other considerations, but it's more about that single parameter than many others.
It's no wonder, from sedans, to vans, to 1/2 ton trucks - they all generally have payload in the 900-1300lb range. As passenger cars first, ride quality is paramount.
Once a vehicle becomes more about performing laden work, ride quality is then a secondary factor as higher spring rates have to be there to support the load. Sure, there's been improvements and progressive springs. But it only can go so far as there's limited suspension stroke to work with. Too much progression, leaves too little spring travel for laden work.
One can have it all, payload and ride quality, by choosing the just right vehicle for the intended use. If that's the F250 - more power to you. They've come a long way and can be comfortable and capable.
I would just temper those that are then staring at the F350 on the account of "more".
Actually a F350 and a F250 ride the same unloaded.As the weight increases the F350 spring pack becomes more capable.Thus the term progressive leaf springs is achieved.
Old 04-15-2019, 07:07 PM   #271
DewTheDew's Avatar
2017 27' Flying Cloud
Frederick , Maryland
On a side note; the tires can make a pretty large difference in ride quality, too. Especially if you have street legal "off road" tires as they have a very stiff sidewall.
DewTheDew is offline   Reply With Quote
Old 04-15-2019, 07:47 PM   #272
2007 27' International CCD FB
San Diego , California
Yeah, if you actually read my post, I acknowledged that.
The tender part of the travel only goes so far. We've all experienced bigger bumps where 1-2" worth of plush travel gets used in a hurry. Then your teeth finds the firmer leaf pack.
There's no getting around the fact that high spring rates are a detriment to ride quality. That solid front axle is also there for capacity and durability. Not ride quality.
If one actually carries the load it was designed for, the ride can be reasonably good. Just don't expect that same ride empty.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i
Rear Bumper Hitch
pteck is offline   Reply With Quote
Old 04-15-2019, 08:01 PM   #273
Moflash's Avatar
The tender part of the travel only goes so far. There's bigger bumps in the road where 1-2" worth of plush travel get used in a hurry and then your teeth will find the firmer leaf pack. Ride quality isn't determined by a minimal example of smooth roads.
There's no getting around the fact that high spring rates are a detriment to ride quality. That solid front axle also is there for durability. Not ride quality.
I read your post.
Thatís not actually true.The primary spring in the progressive spring pack is soft one and thatís the one you are using when unloaded.The spring pack is progressive and becomes more capable as more weight is applied.
You evidently have not driven a new F250 or F350 much less pulled a larger Airstream trailer with one.
Old 04-15-2019, 08:17 PM   #274
nryn's Avatar
2019 27' Globetrotter
Chicago area , Illinois
FWIW I drove both the 250 and the 350, same model year, and felt a difference. I realized later that I hadnít checked the window stickers closely and couldnít say whether they had different options that may have contributed to the difference in road feel (such as camper or snowplow prep).
A friend who has a 2016 250 rode in mine a few weeks ago and couldnít believe it was a Superduty. When I spoke to him last week he was on his way to the dealer to see what heíd get in trade toward a MY18 or 19.
I think thereís a lot of posturing, academic speculation, and navel-gazing on these threads, and when itís kept civil itís all fine and maybe someone learns something. But it often isnít kept civil and I would like to keep this thread a productive one for the time it has left. Before the thread descends into bickering, letís just say that Superduty trucks are not SUVs and vice versa, and this thread is about the process and details of speccing the F-250.
Thanks.
nryn is online now   Reply With Quote
Old 04-15-2019, 08:22 PM   #275
Moflash's Avatar
Thanks.
Was this a 2017-2019 F350 Superduty that you drove? If both were equipped with the same options they would actually ride the same.
Old 04-15-2019, 08:38 PM   #276
nryn's Avatar
Yeah, both 2018s. Like I saidóI didnít pay enough attention to their options. I did know enough to check that they were both 4x4s and gas engines, but they may have different tires and so forth too. My bad. Still would have ended up with the 250 though
Old 04-15-2019, 11:56 PM   #277
I read your post.
Sounds like you may have bought into marketing material without understanding how a progressive pack actually works.
It's based upon the amount of suspension deflection. Unladen, yes it rides on the fluffy soft leaf at the very top part of the suspension stroke. Laden, and with the fluffy leaf compressed/deflected, it rides primarily on the HD pack.
When you hit a big enough bump unladen, it will get into the HD pack that then gives you a nice kick.
F350 rides like an F250? That's a new one.
Rear Bumper Hitch
Old 04-16-2019, 02:19 PM   #278
Moflash's Avatar
Actually no.I have been in the automobile business for 45 years.I am also an ASE certified technician.Member of the Chevrolet truck Hall of Fame.Certified in medium and H.D trucks.I have done consulting for GM,Ford,Mercedes Benz,Porsche,Ferrari and Lamborghini.I have studied suspension theory with some of the best in the industry and have driven on most major race tracks in the USA and Europe.
I have owned a new 2012,2015 and 2017 Ford F350 6.7 SuperCrewís and will have a 2020 10 spd auto when released.
Please continue to tell me more of you 2017-2019 Ford Superduty progressive spring knowledge.
It appears you pull with a 10 year old Lexus SUV with 33í tires. Hmmm
Peace out
Old 04-16-2019, 02:37 PM   #279
2018 27' Flying Cloud
Panama City beach , Florida
Peace out
I want to buy you beer!
Jason W.
USAF retired!
2018 FC 27FB queen
2019 F350 CC SRW 6.7 Short Bed
Eagle Keeper is offline   Reply With Quote
Old 04-16-2019, 02:58 PM   #280
I have owned a new 2012,2015 and 2017 Ford F350 6.7 SuperCrew’s and will have a 2020 10 spd auto when released.
It appears you pull with a 10 year old Lexus SUV with 33’ tires. Hmmm
Peace out
So rather than lay out your credentials. How about you spend some time to tell us how this works? And how a higher spring leafs on an F350 is to ride the same as an F250?
I'm sure those trucks ride as great as my 10 yr old Lexus with your consultation.
Rear Bumper Hitch
Help spec a new F-150 nryn Tow Vehicles 88 09-09-2018 10:00 AM
250 meets 250 meets 250... "made for Germany" in Germany split window Classic Motorhomes 27 11-29-2016 11:44 AM
Any TV off road type tires? 2016 F-250. 250 vs 350? 6.7 Diesel or 6.2 Gas? Need help! Danattherock Tow Vehicles 53 07-19-2015 01:21 AM
250 MH :: 1990 Airstream 250 barend Airstream Registry Discussions 0 08-19-2011 08:32 AM
