Old 02-07-2009, 08:59 AM   #1
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Help please re: ultra low sulfur diesel fuel!
We hope to hit the road next week on a cross country trip to California.
We recently bought a new truck to handle our also-new-to us AS. It is my first diesel, we haven't towed with it yet, but I'm really liking teh truck now that i am used to its slightly larger dimensions compared to our last 1/2ton truck.
It has the Duramax diesel, and teh manual states i am to use "Ultra low sulfur diesel fuel.'
From what I have read, that is the only type sold in Canada, but in the US, you can get both "Ultra low" and "Low."
If this is correct, what I am wondering is whether most gas stations sell one type only or both, and is it well posted as to what the product is?
Hopefully most would have the ULSD.
I'm, wondering too - if by mistake or necessity I put in a load of low sulfer instead of ultra low, hopw big a deal is it?
Major problem or now big deal as long as I don't make a habit of it.
I'm not sure if it harms the particulate filter, injectors, or what.
Any & all advice appreciated!
Thanks ....... Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Wingeezer is offline   Reply With Quote
Old 02-07-2009, 10:22 AM   #2
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
Here in California we only have Ultra low sulfer diesel. Believe it or not your truck will love the sulfer if it could get it. The sulfer keeps the moving parts in your fuel system lubricated but does increase the exhaust particulates. I use an additive in my truck made by Standyne to help the pump and injectors with what they took out of the fuel. Your truck is more sophisticated than mine so it will be just fine with whatever you put in there.. just no veggie oil fuel.. still too dirty for the new vehicles. We have the new Mercedes Diesels towed in all the time when customers customers want to try something green.. the only green they get to do is hand over lots of greenbacks..
Enjoy your new truck..
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 02-07-2009, 11:13 AM   #3
Tincrew's Avatar
2007 25' International CCD
Ponderay , Idaho
We have made several trips across the US and we've never seen anything but the low sulfur diesel. We did find a couple of places in Oregon that sold bio-diesel, but they are really far and few between. Have fun on your trip, we live in CA, let us know if you have any more questions.
Tincrew is offline   Reply With Quote
Old 02-07-2009, 11:27 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
I'm not sure this is true for trucks introduced after about 2 years ago. Did they call that 4th Gen on the transition? There was supposed to be a potential for damage. My 2006 truck is 3rd Gen and can still use the LSD (200ppm) fuel if it were available.
Wingeezer, Tincrew actually means ULSD. I'd see a few pumps still labeled LSD a year or more back. These days all I'm seeing in fairly broad travels is ULSD -- even in the truck islands at truck stops. Truck stops usually won't have diesel at the automobile pumps. It's occasionally a challenge figuring which are pay-at-the-pump on the truck islands -- usually those closest to the cashier.
5 meter Langford Nahanni
Old 02-07-2009, 11:35 AM   #5
Tincrew's Avatar
Ponderay , Idaho
CanoeStream, you're right, typing error, sorry. Only Ultra Low everywhere. If you have a pre-2007 diesel and you can get Low Sulfur Diesel, its a real find.
Old 02-07-2009, 12:39 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
ULSD is readily available and will be the norm, with the LSD being the exception. IIRC it is required in all 2007 and later diesel engines. I run an additive in my 96 PSD to make up for the lack of sulfur. My truck LOVES B80 when I can get my hands on it. In my case any amount of bio is a plus. YMMV
Read your owner's manual as to what is required and adhere to it. New trucks is expensive and diesel engines even more so.
Aaron
WBCCI #XXXX AIR #2495
Old 02-07-2009, 03:13 PM   #7
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Just fill 'er up; additives maybe every 5-10K. I'd love to run bio, but I have enough trouble with fuel filters failing with the "good" stuff.
Old 02-07-2009, 04:31 PM   #8
Vinnie
Ditto on the Stanadyne additive. Any vehicle not specifically designed for ULSD is going to eventually have problems unless you start using some kind of lubricant/additive to protect the injector pump and injectors.
I just replaced the injector pump and injectors on our 92 non-turbo 7.3 diesel engine. The mechanic (whom I know and trust) said they are getting more and more diesel engines in with gauled and seized shafts due to the lack of lubricants in the diesel fuel. I'm now adding Stanadyne Formula Junior to each tankfull.
Just my $0.02
1975 24' Argosy Motor Home
Old 02-07-2009, 08:05 PM   #9
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1977 25' Tradewind
Eastern , Washington
I believe it was in 2007 that ULSD was mandated. You cannot buy anything but ULSD for on the road use.
A good additive makes me feel good, but I'm not sure it is needed with every tank. The injector pump makers don't want you to use them, they say it eats the seals. I'm not sure I believe that either.
Clean fuel is what is really important in Common Rail systems. Some use 28000 psi to the rail and dirty fuel will eat your injectors alive. Works like pumping abrasives through your fuel system.
I use a Nictane filter in addition to my stock filter.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 02-07-2009, 09:29 PM   #10
2005 28' Safari
Mono City , California
ULSD is a MUST for the life of your DPF. LSD or high ash engine oil will cause the DPF to fill with ash more quickley requiring removal and ash cleaning. ULSD is required under ARB regulations in California. Make sure you check the owners manual on your vehicle before you add any additive to the tank. Some additives can cause damage to the DOC. Both the DPF and DOC are very costly. Depending on size of the DPF they start at a cost of $1500 and up, the DOC $2500 and up. I just installed a DPF device (retrofit) on an older truck (required under ARB regulations) at a cost of $12,000. Repalcement cost for the DPF is about $7500.
Good Luck.
TBSarfari28 is offline   Reply With Quote
Old 02-07-2009, 09:41 PM   #11
wncol2004's Avatar
1953 25' Cruiser
Hopkinsville , Kentucky
Diesel fuel.
Ultra low versus low sulfur.
The newer Ultra low sulfur diesel engines will take damage from using Low sulfur diesel. Use what your manual says you should use.
Warren
1995 Ford Conversion F350 crew cab dually 7.3 liter diesel.
1953 Airstream Cruiser Travel trailer (The Runaway Sue)
Western KY
wncol2004 is offline   Reply With Quote
Old 02-08-2009, 06:17 AM   #12
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
There are still stations and truck stops selling LSD. I try and get it whenever I can. The BP station at I-75, Exit 414, Ellisville, FL is one that comes to mind. I think the LSD smells better than ULSD which has a varnishy smell to me.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-08-2009, 06:43 AM   #13
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
I run Stanadyne performance additive in every tank. I own a 2003 Duramax, I purchased new. I have maintained, even babied, the rig by the book. It has only 65000 miles, and I just went through a complete injector change. A $4000.00 repair luckily covered by GM's recently extended warranty to cover the known injector failures.
I have added a filter after the stock filter and before the pump. We'll see if that helps.
All I have seen for the last year or so is ultra low sulfur fuel.
Jeff & Cindy
jdalrymple is offline   Reply With Quote
Old 02-08-2009, 08:45 AM   #14
Wingeezer's Avatar
2005 30' Classic
Thanks to everyone who provided input - as always, this forum is a fantastic place to learn!
It sounds as though I don't need to worry too much about getting the right fuel and knowing what it is that I am buying - that had been my concern.
I certainly don't have any intent to try using LSD instead of ULSD even if I could find any. I was just curious to know how detrimental it might be if I got a load in by mistake.
As far as putting additives of any sort into this truck, I think that I'll likely stick with the GMC manual and use none - especially since I bought a 6 year extended warranty. Hopefully GM will be around long enough for me to benefit from it!
Likewise, although there may be benefit from changing computer chips and all sorts of things I think I will refrain and keep everything 100% stock. I'm on retirement income and this truck cost a fair chunk of change so no point taking chances with it!
Thanks again to everyone .......... Brian
2005 Classic 30'
Old 02-08-2009, 10:13 AM   #15
ScottW's Avatar
2007 30' Classic
Hernando , Mississippi
I just checked my 07 Ford powerstroke. A placard on the inside of the gas tank door states that either LS or ULS diesel is acceptable. Works for me.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 02-08-2009, 12:57 PM   #16
Dwight's Avatar
1999 34' Excella
Joshua , Texas
GM Approval of Stanadyne Performance Formula®
“Information on Diesel Fuel Additives”, GM Bulletin # 03-06-04-017; March 13, 2003
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 02-08-2009, 03:02 PM   #17
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
Wingeezer,
Congrats on your new toys!
I deliver campers all over the US and have logged 467,000 miles in the past 4.5 years. You will have no trouble finding ULSD and by all means please do not use anything else in your particular truck. The fuel I prefer is Flying J which is used 99.9999% of the time in my truck and I have never had an issue with it, not saying it can't happen. Go to Flying J for current daily diesel prices at each Flying J location. One of the better features of Flying J is they cater to the RV'er by having an RV island with sewage dump which is separate from the car and truck islands and there is also dedicated RV parking. You can also apply for one of thier rewards cards and get a few pennies off each gallon of fuel.
Have a great trip!
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 02-09-2009, 06:45 AM   #18
Wingeezer's Avatar
2005 30' Classic
Originally Posted by blacksheep View Post
Wingeezer,
Have a great trip!
Godspeed,
Trent
Yep, we've been fans of Flying J ever since I took early retirement ten years ago and we started making these cross country RV trips. Their fuel prices always seem good, lots of room to move the trailer around, and a great convenience to get a short overnight snooze when travelling
We are never wiithout our FJ brochure in the truck! I also have many of them in my GPS so we can aim for them for an overnite stop!
Brian
Brian
2005 Classic 30'
Auxillary diesel fuel tank cmreumund On The Road... 8 10-24-2008 09:40 AM
Low sulphur vs ultra-lo sulphur diesel? ScottW Tow Vehicles 24 02-27-2008 02:35 PM
Help! Diesel mo/ho fuel problem. Mike Leary Classic Motorhomes 12 06-07-2007 09:23 AM
New Diesel Fuel Tarheel On The Road... 31 09-02-2006 07:57 PM
Diesel fuel Scott Hopkin Airstream Trailer Forums 8 03-04-2005 03:32 PM
