Old 03-21-2016, 03:29 PM   #29
Racine , Wisconsin
Thanks for thread. Im in market for truck now. Been looking for comparison of hemi and diesel.
Kilroy is offline   Reply With Quote
Old 03-21-2016, 04:10 PM   #30
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Pulled a lot of miles with a Dodge 2500 diesel and carried a bit of stuff in the bed. I have never felt heavily loaded. If you go over payload on one it might sag another 1/4 inch. Our 25' adds 800b to the truck weight when hitched with the WD bars tight. It might take the bumper down 1 inch without the bars. If you are carrying a motorcycle or something there might be an issue. It is the mega cab with a short bed and a low cover. 2 of us and a 30 lb dog.
Old 03-21-2016, 05:53 PM   #31
2014 25' FB Flying Cloud
Grand Rapids , Michigan
Originally Posted by jonnie3 View Post
Yes Im using an Equalizer WD hitch. My current Tundra has a payload of 1335 lbs (Crew Max, 4X4, Snugtop). Took it to the scales loaded with my typical cargo, with my wife and myself in the seats. I was 500 lbs over my GVWR and 130 lbs over my rear axle GAWR. Sounds dangerous to me. I love my Tundra but I love my family more. Thanks
Jonnie, I have a Tundra as well that I haven't had a chance to weigh in full trim yet with our 25' FC. Which trailer do you have?
My first run this spring will be to the local CAT scale.
I'm still mulling the eventual replacement and change my mind every day as to the front runner, and of course, gas vs diesel.
MIFC is offline   Reply With Quote
Old 03-21-2016, 06:46 PM   #32
gypsydad's Avatar
2017 28' Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
I visited a Dodge/Jeep dealership last week in Austin; while waiting for daughter's jeep to be delivered, I got to talking with the "truck expert" who said he has been selling Dodge for 19 years...I asked about the 1500 echo-diesel...he said it is a great little engine, but would not get it if pulling a 25+ foot Airstream or planning any loads approaching 6-7K total, as it would likely be at limits of that engine/truck combination. He likes the new Nissan 1/2 ton (5/8's ton?) with the Cummings...said same guy who did the Echodiesel for Dodge is now at Nissan and that he was hired to get the best diesel in a half ton so they could go after that market...his opinion...
Will be interesting to see how these all look in a year or two with you'all feedback!
Old 03-21-2016, 07:19 PM   #33
Plan-B's Avatar
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Watervliet , Michigan
Jonnie3,
I took delivery of a 2016 Ram 2500 4WD Crew Rear Air with a Cummins last Friday. Already racked up 750 miles. I took a 365 mile interstate trip today. I do not experience what you are describing. If you have not owned a 3/4 ton before, don't try to compare with any 1/2 ton. They are not the same animal in any respect. Maybe if I had not owned three 3/4 tons before I might be saying or experiencing your sensitivity to what you are feeling.
I can say this, my Ram 2500 hands down is the best driving 3/4 ton I have ever owned by a long shot. This is my first Ram 2500 too.
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
Old 03-21-2016, 07:38 PM   #34
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Jonnie
Compared to your Tundra the front suspension of the 2500 Dodge has a rather primitive straight axle with massive un-sprung weight and an old fashioned steering box. This is why it has very little steering feel and tends to wander. You will likely get used to the wander but it will always be trickier to handle in a quick maneuver.
If you are looking for safety your Tundra is better than the 2500 in almost every respect. In an evasive maneuver it is capable of staying upright in much more drastic maneuvers, stopping distance is shorter as well. I really would not worry at all about being 130 pounds over the rear axle capacity as that will never cause a problem. You can apply just a little more pressure to the torsion bars and easily bring it within spec. As well you are well under your tire capacities.
If you look at other trucks on the road you will see many work trucks that are sitting low, these trucks are all well over the axle capacity, often by several hundred pounds yet do you see trucks all around with broken axles or suspension parts? Obviously there is plenty of overbuild.
If you feel you absolutely need to have more capacity the F150 with the HD payload package will give you independent suspension, rack and pinion steering and a lower centre of gravity than you have now.
Just some things to consider.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 03-21-2016, 08:06 PM   #35
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
You can always add an aftermarket steering stabilizer to the front axle.
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-21-2016, 08:39 PM   #36
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
How do you compare a 2500 ram with 6.7 cummins with a tundra with a 5.7? Well the tundra isn't even in the same ball park, about like comparing the 5.7 chevy with a duramax.......
Old 03-21-2016, 09:40 PM   #37
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
I have a lot of respect for Andy but I believe his assessment of the Rams steering is a little extreme. After an adjustment period, I find the steering of my 2500 to be very nice. Not as quick, no question...but it has lots of steering feel and it is easy to drive...
I'd also argue that safety is not always about a zig or a zag... I found that driving the Ram 2500 home (1000 towing miles in a long day) I was more relaxed and thus more attentive. That is arguably a safer state of being to drive in.
My 2500 feels just more comfortable and relaxing to drive than my F-150 ever did under the same conditions.
I'm not out here to drive aggressively...
No disrespect to Andy, he has mastered the art of tow vehicle/trailer set up for enhanced handling but I believe that there are other factors that bear consideration...
Bruce
Bruce B is offline   Reply With Quote
Old 03-22-2016, 12:56 AM   #38
Originally Posted by KJRitchie View Post
Yep the diesel engine takes away a lot of payload.
Maybe your should look at a 3500 series truck. I think the gas version 2500 is only about 400lbs better than the Cummins.
Kelvin
Comparing the same 2500 build (SLT Mega cab) the Cummins option reduces payload by 900 lbs compared to the 6.4 Hemi. Diesel does increase the towing capacity by about 3000 lbs. I need payload if I bring my wife and my sons family. 6 seats needed. Thank you.
jonnie3 is offline   Reply With Quote
Old 03-22-2016, 01:34 AM   #39
I have a 2015 25FB FC. Im short changed on my Tundras payload for several factors; 200 lb shell, 50 lb rubber bed mat, Crew Max, and 4X4. I wish I had paid more attention to the payload cap and GAWR. Everyone is much more concerned with towing capacity, but thats only a small part Ive found. Maybe if I were doing an occasional short trip camping every once in a while it wouldn't concern me much. But Im retired and like to get out all over the country on a pretty regular basis. And Diesels are too heavy for my payload needs. The RAM 2400 Cummins takes away about 900 lbs of payload over the 6.4 Hemi. And costs over $7000 more. Im not interested. Hell Im only towing a 7000 lb trailer. What more do I need in terms of an engine.
Old 03-22-2016, 01:44 AM   #40
Originally Posted by Andrew T View Post
Hi Jonnie
Andrew T
I will be camping with my wife, son, daughter in law, and two grand kids. I wouldn't feel comfortable with that much weight in my Tundra. Im already 500 lbs over GVWR and that would go up another 500+ lbs with my sons family and all their stuff. Im definitely going 3/4 ton. But I do appreciate your comments. Thanks
Old 03-22-2016, 02:16 AM   #41
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
jonnie3, could the son and family and stuff travel for weekends in their own vehicle so you could keep the near-new Tundra. Might be tough to seat six in a five-passenger truck anyway, not to mention the Airstream.
Doug and Cheryl
Old 03-22-2016, 07:23 AM   #42
Gainesville , Florida
Because of the heavy Diesel engine, there is only Ten psi difference in the front max load pressure and light loads pressure in my truck. Now the rear is totally different. Front tire pressure is critical for best service. Too low and I have poor handling.
avionstream is offline   Reply With Quote
Dodge Ram 2500 4x4 6.4 Hemi vs 6.7 Cummins ajnjarv Towing, Tow Vehicles & Hitches 60 05-11-2016 12:39 AM
2016 Ram 2500 Cummins 20" Tire Pressure Llando88 Tow Vehicles 15 12-01-2015 10:01 AM
Hemi-Powered Ram 1500 versus 30' Classic LittleRadio 2001 - 2005 Classic 34 10-19-2014 10:10 PM
2010 Ram 1500 5.7 Hemi? DesertDog Tow Vehicles 29 07-11-2011 03:24 PM
Ram 1500 hemi Mifair Tow Vehicles 12 10-28-2010 10:41 PM
