Old 07-18-2011, 09:15 PM   #43
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by star kitty View Post
I have a label called Service Parts Identification and its full of codes that I don't know how to read. The only code with a decimal point is 131.5 on the top of the list and that doesn't sound right.
star kitty,
Let's try this again. The axle ratio is not listed numerically in your glove compartment. It is represented by two capital letters and maybe one number like GU4. You will have these which represent parts or option codes when they built your vehicle. You may have 20 or more of these listed on a white background and adheared to the inside of your glove compartment. Hunt for the codes I mentioned and if none of them match, write them all down and I will tell you what you have.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-18-2011, 09:17 PM   #44
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
Originally Posted by overlander64 View Post
Greetings Star Kitty!
Your Suburban shouldn't have any problems towing a coach the size of yours. When I ordered my K2500 Suburban in 1999, the dealer tried to talk me into a K1500 with the HD towing package as it had a 6,000 pound trailer tow rating (with max tow package, the differential was 3.73). I suspect that you will find that your Suburban has either the 2.73 or 3.08 differential which would pose issues when towing in the Rockies. If the truck has the 3.73 differential, I would suggest some potential culprits that might include:
  • A partially plugged catalytic converter.
  • A dented/restricted exhaust or tail pipe.
  • A partially collapsed "double-wall" exhaust pipe.
  • A muffler with collapsed baffles.
  • An exhaust heat riser valve that isn't operating freely.
  • Dirt in the fuel injection/throttle body system.
  • Weak fuel pump.
  • Leaking intake or exhaust gaskets.
  • One or more Vacuum Leaks.
  • Mechanical issue with the motor.
Good luck with your investigation!
Kevin
Holy crap Kevin, that list is impressive.
Here are a few mechanical issues I do know about the vehicle and maybe they are leading to the lack of power.
I do know it has an exhaust leak because I can hear it up near the engine compartment and a friend of mine who is a mechanic also stated that it had a leak. Also, I had to replace the fuel pump in Denver before leaving for a road trip and I made it 300 miles before it failed in Grand Junction. Had to get it towed and a new fuel pump re-installed. Two fuel pumps in one trip got very expensive.
I know it's time to leave this older vehicle for someone else and step up financially to get a newer, more reliable vehicle for me.
It's just finding the right vehicle for towing and every day use that is the challenge.
star kitty is offline   Reply With Quote
Old 07-18-2011, 10:18 PM   #45
davidz71's Avatar
1986 25' Sovereign
star kitty,
I've found that it pays to change the inline fuel filter religiously when dealing with Chevy products. Our '95 Astro had a smaller fuel pump electrical wire from the pump relay to the in tank fuel pump than the '96 Astros. Ours burned up in the tank and we went through three relays when the contacts also showed signs of burns. After the pump was replaced I ran a larger wire back to the tank and change fuel filters often even in my 2500HD and C1500 stepside.
Craig
AIR #0078
3.73 rear end
Old 07-18-2011, 10:45 PM   #46
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Two fuel pumps!!!
I'm with Craig, sometime during one of those replacements it should have dawned on someone that the filter might need replacement.
It was always a given at the dealer I worked at, new pump gets a new filter.
KISS principle at work here.
It's 'kinda like suck'n a Mickey D shake thru a straw.
OL64's exhaust recommendation's are another common cause for droopy performance.
A little more research and you might be able to forget that new TV,
Good Luck
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-19-2011, 08:50 AM   #47
star kitty's Avatar
denver , Colorado
Originally Posted by davidz71 View Post
star kitty,
The fuel filter was replaced during the first replacement. That filter had about 300 miles on it when I broke down again. I didn't have it replaced when I had the second pump installed because it was brand new.
Old 07-19-2011, 09:36 AM   #48
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If you had the fuel filter replaced at the first pump replacement, you did your due diligence and are entitled to chalk the failure of the new pump to a defective pump.
David
DKB_SATX is online now   Reply With Quote
Old 07-22-2011, 04:23 PM   #49
davidz71's Avatar
1986 25' Sovereign
It is amazing how terrible the quality is on some products today. I replaced an alternator a few years ago and it failed the same day. In-take fuel pump replacement is labor intensive and a pain if the pump is bad.
Craig
AIR #0078
3.73 rear end
Old 07-22-2011, 05:05 PM   #50
Tool Hoarder
West , California
I have a 2002 Suburban 1500 with a tow package. The bigger gear ratio along with bigger air intake modified computer chip and bigger exaust gives a lot more horse power.
marzboy is offline   Reply With Quote
Old 08-13-2011, 04:33 PM   #51
star kitty's Avatar
denver , Colorado
Update:
Wanted to follow up and thank everyone for their recommendations. I ended up purchasing a 2008 Toyota Sequoia with the 5.7 liter motor. Holy cow, what a tower! Super psyched.
Towed it through the mountains a few days ago to do some camping and to see how it would perform in the hills. It far exceeded my expectations in terms of power and handling. It has a tow/haul feature and sport shifting which allows me to choose my gear range. I was able to keep up with traffic with plenty of power available to maneuver safely. Also used a weight distribution hitch.
The downside to all this power and luxury was the fuel mileage. I looked at the computer once during an accent of a mountain pass and quickly backed off the throttle and slowed down! Yikes....she's a thirsty competitor. Also, the price for the vehicle. I paid more than I wanted but in the end I have a vehicle that pulls well with a great warranty.
Thanks to mojo for talking to me about the Touareg and TouringDan for the Sequoia recommendation.
P.S. I am selling my Suburban for a great price if anyone is interested!
Old 08-13-2011, 04:47 PM   #52
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Nice! Now that's a "big girl" truck!! Enjoy your new ride.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 08-13-2011, 05:49 PM   #53
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Congratulations on your new Sequoia. We had a 2002 and it was a very comfortable SUV, but burned lots of gas. So does the 5.7 L. in our 2007 Tundra. We can tow up the passes our much heavier trailer very fast, but every time I glance at the fuel gauge, it looks lower. Keep it down to 50 or 55 and that'll help.
It's easy to go faster and pass sports cars, but it costs a lot. It's tempting to air it out and that engine can certainly do it. The mpg readout should read 99 going downhill if you keep your foot off the gas. Don't forget to downshift going downhill. You don't use any more gas and it's a lot safer. I just had to replace our front rotors as they warped at 62,000 miles, probably from overheating even though I downshift on steep and long grades. In 3rd, you can go up to 60 or so and get some engine braking. In 2nd, top speed is around 55. You can tell if the rotors are warped if you get brake chatter when you use the brakes. For a while they used thinner rotors that were supposed to dissipate the heat better, but they didn't. Thinner meant warping.
One time when we were late, I towed our trailer up Monarch going east and passed everything hitting about 65, but got about 3 or 4 mpg.
Gene
Old 08-13-2011, 08:55 PM   #54
star kitty's Avatar
denver , Colorado
Gene
That's funny! That's about what my computer was reading too - 4 MPG. And yes, there was plenty of power to spare but at that price, no thanks!
I just took it up Monarch Pass today and it didn't even break a sweat. Drank a lot, but didn't sweat much.
Gene - maybe I'll see you out there someday. I hit the western slope quite a bit. Great area.
Old 08-14-2011, 05:04 AM   #55
Boy....hard to believe 4mpg under any conditions!!!
backwards?
PFC
"Tahawus"
RLC
John Prine
Old 08-14-2011, 08:27 AM   #56
Master of Universe
Gene's Avatar
backwards?
We make some of it back going downhill. I haven't tried backing up hill, but I have to go over Monarch Pass today and I'll see if it helps.
Gene
Good Tow Vehicle for 3,500 lbs ventport Tow Vehicles 20 08-20-2011 07:50 AM
Tow Vehicle for 27' Overlander pyrenees Tow Vehicles 9 05-06-2011 08:18 PM
The ultimate tow vehicle! I found it! brad1 Tow Vehicles 8 03-21-2011 07:47 PM
