Old 07-29-2004, 01:06 AM   #1
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
HD Flasher?
Hi all! Well, I went and bought a 94 1 ton Dodge B350 (not maxi) wagon for the family trip to CA. The "hot rod Astro" just had too many heat issues (although pulled great!). Well, the van seems to be the cat's meow, however, I noticed the lights flash too quickly when the turn signals are on. I think this is because I need a heavy duty flasher? Anybody know where it may be located on my van? No manual was included with my van.
Thanks!
Marc
Old 07-29-2004, 05:05 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Thanks!
Marc
I will look while I am at work to be sure, but it should be either in the glovebox, or to one side of the steering column under the dashboard.
Old 07-29-2004, 05:49 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
......I noticed the lights flash too quickly when the turn signals are on.Marc
Marc:
Do a walkaround on the van with the turn signals on. Sometimes a burnt bulb or bad connection will cause the lights to go into the "fast flash" mode.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
