Old 08-24-2019, 06:41 AM   #1
2016 25' Flying Cloud
Holly Springs , Mississippi
Have you replaced your transmission cooler? ...or added one?
My F-150 has a factory-installed transmission cooler, but I wonder if it is adequate. Occasionally the transmission temperature goes above 20dF when towing. So three questions:
(1) How hot is too hot?
(2) Have you replaced your existing transmission cooler, or added one if one wasn't already installed? Which brand and type did you choose?
(3) How effective is the one you installed?
Thanks, all.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 08-24-2019, 07:32 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Ck your owners manual...
Our Burb will go into 'limp mode' when the trans temp is sustained at around 260*F.
Normal towing for us is 150-200mts.
125 w/o the AS
I did install an aftermarket cooler in our 95 Burb.
The 454 ran a bit hotter and the cooler did help a lot.
In our colder climate it's important to have a fluid by-pass to allow for quicker warm-up in low temps.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 08-24-2019, 07:58 AM   #3
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
When I had similar questions, I did a Google search using transmission cooler Airstream and found many threads on the subject. One of the better ones I had come across was this thread:
http://www.airforums.com/forums/f463...des-51433.html
I found it useful because it not only showed the comparison, but some observations that went on for several years post install.
panamerican is offline   Reply With Quote
Old 08-24-2019, 09:48 AM   #4
Gary W's Avatar
2019 27' Globetrotter
Lacey , Washington
F150 Transmission Temperatures
Bob,
I have a 2012 Ecoboost F150 that I pull an AS 2019 Globetrotter 27 FB. Towing temperature for the transmission is 190-200 degrees. It will go higher pulling a pass but never approaches the yellow or red caution zones on the factory gauge.
Consult you factory owner's manual or discuss with your Ford service folks. My dealer showed me where the first transmission service is at 150K miles or if there is a problem. You will also find no dipstick or drain plug, its a sealed system.
Unless your having an issue, you should be fine.
Gary W.
Gary W is offline   Reply With Quote
Old 08-24-2019, 11:16 AM   #5
Salem , Oregon
I have a 2016 F150 4X4 with 3.5 Eco Boost pulling a 2019 27 ft Globetrotter. I have never had any indication of higher temperatures. Dave W
NoResults is offline   Reply With Quote
Old 08-24-2019, 02:00 PM   #6
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
I used to use one of these https://trucool.com/products when I was towing my 25 with a 4.7L Jeep GC. I liked it because the oil would by-pass the cooler in winter but would flow at full blast the hotter it got. It really did the job well. Jim
Jim Flower is offline   Reply With Quote
Old 08-24-2019, 07:50 PM   #7
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
I just went through this with my truck. 05í Sierra with factory aux cooler would stay around 190-200 towing, creep up to 210 in the hills in hot days. I changed that out to a Hayden unit twice the size. Definitely keeps it cooler not towing, around 150-175, but towing in the hills it still went to 200. Not worth the hassle if you ask me. If I bypassed the radiator cooler it might work better.
cliffcharb is offline   Reply With Quote
Old 08-24-2019, 08:17 PM   #8
Put it after the OEM rad cooler.😂
W. H. Auden
Amanamus
"Tahawus"
Old 08-25-2019, 08:47 AM   #9
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
This is also correct for the Trucool installation. Jim
Have you replaced your pancake TV antenna? Bob662 Audio, Video & TV 34 12-03-2017 01:10 PM
On your 2010 or late models what have you added.... THEPILL 2006 - 2010 International 23 05-26-2013 08:01 AM
Have you replaced your Sony radio? Kistler Audio, Video & TV 8 12-23-2007 04:46 PM
aux transmission cooler? nickglase Mechanics Corner - Engines, Transmission & More... 10 04-08-2007 10:37 AM
Transmission cooler thenewkid64 Mechanics Corner - Engines, Transmission & More... 13 11-10-2003 09:37 AM
