Old 09-03-2014, 10:16 AM   #1
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Has the miles per gallon of diesel fuel diminished?
It has been about four years since I towed my 27 FB International with my 2008 Dodge/Cummins 6.7, but as I remember, at about 62 mph, I was achieving 14 mpg.
Now, with my new Serenity 30 RB, having pulled about 1500 miles on this trip, heading northwest, with some significant winds from the west and southwest, I am looking at from 10.5 to 12.5 mpg. Yikes!
I chatted with a fellow at a rest stop who was pulling an Airstream for the past 13 years and he stated the mpg he achieved has diminished in the past several years.
My question is this: For those who are pulling with diesel engines, has anyone else noticed a decrease in fuel mileage over the past few years?
Of course, the wind factor may be entirely to blame, and the fact I am 500 lbs heavier may be the problem. but I was curious about others experience.
I am head east in a week, then back south east so I will reassess the overall fuel mileage once the trip is complete. I was just disappointed to be pulling at about 62 - 64 mph and have what I consider to be poor fuel mileage.
Thanks for any thoughts on this issue.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 09-03-2014, 10:21 AM   #2
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Great question, I look forward to the responses. From personal observance and discussion, I know it's well regarded that ethanol forced on everyone with a gasoline engine saw a decrease in MPG.
Wondering if there has been a change in the diesel formulas as a result of EPA/Government mandating.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-03-2014, 10:23 AM   #3
MYater's Avatar
1948 22' Liner
Roy , Utah
Send a message via AIM to MYater Send a message via Yahoo to MYater Send a message via Skype™ to MYater
I haven't seen any kind of difference with my '04 Cummins Ram based on similar towing and weather conditions when using the fuel from the same location.
When I change anything I do get differences though, and the things that I think will not effect me much, seem to effect me the most. Go figure.
"Some things you can tap. Some things you can hit. Know which one is which!"
1948 Airstream Liner 22'
MYater is offline   Reply With Quote
Old 09-03-2014, 10:46 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I tow with a 6.0 Ford excursion and have not noticed any change. In fact I just had both coolant and oil temperature sensors changed because of erratic reading and saw a couple mph improvement.
Anything that influences the CPU can change the fueling ratio. You might have someone you trust hook an OBD2 reader and check the engine settings. Do not take the truck to a dealer, God know what they will do.
2004 Excursion 4x4
Old 09-03-2014, 10:55 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Bio diesel gives me a lower mpg. You never know the actual percentages. In Texas it is labeled on the pump. But even that is not accurate.
For instance, with single hose gasoline dispensers the State regulators "flush" the line with 5 gallons prior to taking sample.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-03-2014, 11:52 AM   #6
Msmoto's Avatar
2007 25' Safari
Images: 135
Yes, I plan on having the truck "improved" with more open exhaust and adjustments to the computer settings to improve fuel mileage.
And, avoiding the dealer…. absolutely. One I had trusted in the past may have screwed up mine when they did some repair on the catalytic converter and charged me for something like a "clean flush" which actually may have messed things up in the exhaust system.
Is anyone running a straight through exhaust with a chipped out computer?
Old 09-03-2014, 12:32 PM   #7
JimGolden's Avatar
1977 31' Excella 500
I lost about 1-2 mpg after the sulfur was reduced in 2007. But have noticed no change in the past few years.
I've been able to get that 1mpg back using fuel additives, but normally don't bother.
I have an 04 1/2 Ram with the 305hp/555ft-lb and heavy duty 4-speed auto (as opposed to the regular duty 4-speed auto). Probably have pulled the triple axle 25,000 miles with it and so far very happy.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 09-03-2014, 07:20 PM   #8
jcl
Vancouver , British Columbia
I wouldn't think sulphur reduction would make any difference in mileage.
Bio diesel blends will. And summer vs winter blends will.
But the largest variable remains the driver.
jcl is offline   Reply With Quote
Old 09-03-2014, 09:37 PM   #9
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I once owned a 1998 vw jetta tdi and was able to pull down 48 mpg on a regular basis. When ULSD was introduced the car would never get better than 44 mpg.
Winter diesel will drop my Dodge diesel by 2 mpg.
From what I have read the biodiesel will also drop mileage.
Deleting the emissions is supposed to help by 2 or 3 mpg amount other improvements.
You may not like the straight piped exhaust as the drone can drive you crazy.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 09-03-2014, 09:59 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
"Hi. I'm from the government. I am here to help you. ".
PLEASE STOP HELPING US!
Channing
WBCCI# 30676
Old 09-04-2014, 04:15 AM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I haven't noticed any great reduction in my diesel mileage. But a variance of 1-1.5mpg is negligible in my book on the truck. I typically get in the 14.5-15.5 range anyway with my 7.3 PSD 4:10 gearing DRW, CC. It is a heavy beast and not geared for maximum mpg anyway. I did talk to the guys at Gale Banks a while back and they recommended a larger exhaust, better air filter system and an upgraded turbo housing. IIRC it was a bit over $2500 at the time, should get a 10-15% increase in mileage, plus some power gains, again not really huge on a 15 mpg truck. I passed on it for the time being, the truck has only been getting 3,000-4,000 miles a year put on it at this point.
Aaron
WBCCI #XXXX AIR #2495
Old 11-04-2014, 11:15 AM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Most operators noticed a diminution in mpg with ULSD. I now use Power Service in every tank and only Esso or Shell diesel. MPG is back at what it was and occasionally better.
The rule for best economy in a CTD is 666: 6-psi boost or less; 60-mph or less; and 600F egt.
Don't assume truck or TT alignment is perfect, verify. Same for bearing preset. Brake drag on both. Steering gear slop. I'd also recommend KONI FSD shocks. Closed shoulder highway rib tires are best for FE and longevity. The champ is currently the Bridgestone Duravis m500
. I've added a small anti-roll bar to the rear of mine (and increased the size of the front one). A Panhard Rod (also called Rear Track Bar) are other additions to reduce steering wander. TT tires to sidewall max pressure and TV to best pressure versus measured load. FE is a about the small things adding up.
Of course, FALR on a Dodge is a good idea. As is a Pro Pride hitch.
A pre-emissions CTD can pull a bigger A/S at 14-16 mpg with the above nearer to 60-mph. Have found around a dozen other examples in South Central US
Old 11-04-2014, 11:29 AM   #13
SteveH's Avatar
Common Sense , Texas
Which Power Service do you use?
Regards,
Steve
Old 11-04-2014, 11:40 AM   #14
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Power Service Silver.
Also the tank cleaner formulation every so often.
Lubrizol came up with a new additive that cleans injector interiors not just tips. PS uses it.
The others are all okay but Schaeffers 2000 is the one to have. I'd use all their products throughout the truck but lack storage space for bulk. Worth ordering (as I used to do on all our vehicles).
5W-40 synthetic engine oil allows my engine to turn over more easily even down south here in Hades. Rotella posts the best numbers according to the tribologist I consult. Donaldson Stratapore oil filters and MOPAR deep air filter.
Need to add that fuel filters should be changed ahead of schedule (Baldwin only on CTD)
Plug in truck coolant heater year round is another nice as to reducing engine friction. Can be seen at pump. 90 minutes to 115F.
Aftermarket Miles Per Gallon Gauge herrgirdner Off Topic Forum 11 05-22-2008 08:32 PM
6 gallon?....10 gallon?.... FreshAir Water Heaters, Filters & Pumps 16 06-15-2007 04:57 PM
$4 per gallon gasoline JimGolden Off Topic Forum 94 05-03-2007 09:49 AM
Miles per Gallon? Phil Gobie On The Road... 52 12-21-2006 06:56 PM
The QUEST for 20-25 Miles Per Gallon Mr Jody Hudson Tow Vehicles 32 08-04-2002 05:16 PM
