Old 09-08-2014, 01:17 PM   #1
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
san marcos , Texas
Images: 38
Send a message via AIM to kevinkatz
half ton or 3/4 for a 2500 lb caravel ?
i am fixin to buy a tow vehicle for my 1965 caravel that weighs about 2250lbs unloaded.
we want an SUV and i am looking at suburbans.
i got off the diesel idea and think that i am going to do gas. i want a 4x4.
so the question is whether to do the 1500 ( half ton) or the 2500 ( 3/4 ton)?
i have almost convinced myself that i want the 3/4. the suspension is beefier and they all come with the 6.0 motor. the problem is that there arent many used ones around and if i was prepared to go for a 1/2 ton i would have much more choice.
do you think that there is a real advantage by getting the 3/4 ton?
kevinkatz is offline   Reply With Quote
Old 09-08-2014, 01:29 PM   #2
Road Ruler's Avatar
Images: 38
IMHO...... there would be no advantage of getting a 3/4 ton and there would be many advantages of getting the 1/2 ton including a better ride.
Old 09-08-2014, 02:09 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The only reason for a 3/4 ton would be if you wanted to carry the trailer in the bed of the truck.
Clearly 3/4 is overkill on steroids.
You may even go so far as using a 342 rear with that small a trailer. However if you think you will get a larger trailer while still owing the truck get a 373
2004 Excursion 4x4
Old 09-08-2014, 02:27 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
A 3/4 ton will shake your poor Caravel to bits! Go with the 1/2 ton or smaller...we tow our small <3000lb vintage with a V8 Touareg - it's the best tow vehicle we've ever had and makes for a reasonably sized daily driver when not towing.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-08-2014, 02:41 PM   #5
You don't need a 4 X 4 to tow any Airstream, let alone a Caravel.
A half ton truck with standard springs will go a great job.
Rig it up with a Reese dual cam 600 pound load equalizing dual cam hitch, and you won't know that the trailer is behind you.
Old 09-08-2014, 02:45 PM   #6
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
san marcos , Texas
Images: 38
toureg
interesting that you say the toureg. there was one that i was looking at close by. it is the v10 but looks fantastic. maybe an option.
Old 09-08-2014, 02:45 PM   #7
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
1/2 ton van towed our Caravel for the last 11 years, literally did not know it was back there. Recently replaced with a Ford Flex, which is doing the job just as well. You don't need all that much tow vehicle to pull the tiny Caravel!
Stephanie
Stefrobrts is online now   Reply With Quote
Old 09-08-2014, 02:49 PM   #8
N/A , N/A
I agree with Road Ruler.
rostam is offline   Reply With Quote
Old 09-08-2014, 03:00 PM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
New Jeep Grand Cherokee Diesel and an Anderson WD hitch perfect combo with that light weight trailet.
MICHAEL
Old 09-08-2014, 03:07 PM   #10
InsideOut's Avatar
1956 22' Safari
Images: 108
It would be a good option IMO.
Shari
Old 09-08-2014, 03:23 PM   #11
r carl's Avatar
Lin , Ne
A used half ton suburban will do you well.
Old 09-08-2014, 11:30 PM   #12
2004 16' International CCD
Chicagoland , Illinois
The answer to your question boils down to payload. How many people do you want to haul? How much luggage do each of them carry? How much does all of the common/shared gear weigh? How much do the dogs weigh? How about food? What about the massive cooler filled with ice and beer? How about tools? A generator or two might be nice? Lawn chairs and a camp table? Maybe a wastewater container? Bicycles? Firewood? Roof rack storage container? Fuel? Will you bolt all manner of crap onto the truck? Brush bar, auxiliary lighting, air compressor, different bumpers, a winch or two, larger wheels and tires, etc., etc.
Since payload also encompasses tongue weight do you know what it will be when the trailer is filled with water, propane, gear, etc.? This can add up to a BIG number in the more modern trailers.
If you want maximum flexibility then get the 2500. It is a real truck. You won't need the payload everytime, but it sure will be nice to have when you do.
If you go with the 1500 just realize that you have a payload limit that you'll probably have to watch carefully when your trying to get fully-loaded for a campout.
Disclaimer: I just bought a 2013 Suburban 2500 4x4, to tow my trailer, and I just had my front overhead cabinet fall down. I can't ignore the possibility that it might be related to my new towing setup, although I've received plenty of feedback suggesting that the two are coincidental.
OMG - The engine and exhaust sounds are just so sweet. I don't even bother turning on the radio with this truck.
Airrogant is offline   Reply With Quote
Old 09-08-2014, 11:49 PM   #13
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
for what it's worth.....
1978 Airstream Sovereign 31', tow vehicle 1999 C2500 2WD 3/4 ton Suburban with the big block..... I treat generously with maintenance and upkeep. 162,000 plus miles and going strong. 10 mpg pulling the trailer. 14 w/o
Jim Lee is offline   Reply With Quote
Old 09-09-2014, 05:45 AM   #14
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Two of the longtime Airstream dealer/repair shop owners here (Inland RV and Can-Am Airstream) have repeatedly cautioned against using too a tow vehicle with too stiff suspension to avoid damage to your Airstream.
Your Airstream Owners manual also advises against it, as well as stating to never exceed 1,000 lbs tongue weight for the trailer. This weight limit means you don't need heavy payload to support the trailer; it comes down to what you must carry in the truck.
So these can be conflicting interests. My take on it is to match the truck to your trailer and hauling needs, with careful thought about what you really need to haul around.
Doug and Cheryl
caravel
"Heavy-Half Ton" Pickup Trucks hex Tow Vehicles 7 05-02-2013 12:49 PM
Dodge Releasing the 1500 Diesel Half Ton Kevin245 Tow Vehicles 18 02-17-2013 08:48 PM
1/2 ton vs 3/4 ton towing? subfan1 Tow Vehicles 7 12-13-2007 03:10 PM
Big 3 1/2 Ton vs 3/4 Ton Trucks Streamer1 Tow Vehicles 40 11-20-2007 10:13 PM
Half Ton Truck w/ 32' ('89) Excella? Boaz1362 1987 - 1989 Excella 26 11-30-2005 07:41 PM
