Old 05-24-2016, 12:42 PM   #21
dznf0g's Avatar
Oswego , Illinois
Originally Posted by franklyfrank View Post
That is very true.
You notice it while parking or such tight turning situation at slow speed. I normally disengage it as soon as I am of the highway. In regular highway driving I have not experienced it. The difference in descending on steep grades with it engaged is day and night.
I wouldn't do it on dry pavement, ever. You won't experience crow hopping, except on hairpin curves, but the system is always in a bind, as even rolling tire diameters are never exactly the same, let alone any steering input causing a bind. It is very hard on the transfer case to drive on dry pavement....not as bad in rain, but I avoid it unless absolutely necessary.
-Rich-
Old 05-25-2016, 01:52 PM   #22
Anna Maria , Florida
I would classify descending on a steep grade using engine brake as a situation where safety would dictate it to be necessary.
I don't believe the transfer case is a fragile piece of equipment on a truck designed for heavy towing. Your suggestion is misguided and there are enough people having anxiety attacks about other things on these forums without adding another.
franklyfrank is offline   Reply With Quote
Old 05-25-2016, 02:30 PM   #23
dznf0g's Avatar
Oswego , Illinois
Ok, if you say so. Guess my formal education, OTJ training and experience has taught me nothing. Here's what the manufacturer (my employer) has to say about it:
Drive Systems
Four-Wheel Drive
If equipped, four-wheel drive
engages the front axle for extra
traction. Read the appropriate
section for transfer case operation
before using.
{Caution
Driving on clean, dry pavement in
four-wheel drive for an extended
period of time may cause
premature wear on the system.
The damage would not be
covered by the vehicle warranty.
four-wheel drive may:
. Cause a vibration to be felt in
the steering system.
. Cause tires to wear faster.
. Make the transfer case harder to
shift, and cause it to run noisier.
But I am not sure what the big deal is anyway, I have NEVER had the rear tires want to slide on dry pavement while using lower gears on severe hills in all my years of towing...and yes, many times on 7 - 8% grades.
-Rich-
Old 05-25-2016, 07:59 PM   #24
HowieE's Avatar
Princeton , New Jersey
Images: 12
several have given reason why engaging 4 wheel drive on dry pavement is not a good idea. If you have not accepted the reasoning to date look at it this way. Those that have done it have commented there is an additional retarding effect. Where can that additional retard come from? It comes from the scrapping of the mismatched tires rotation. That can be from different diameter tires due to different ware patterns and the fact that is not a differential between the front and rear axle.
I had a tire company put a mismatched tire on the rear of one of the school buses I managed. It wore the other tire out in less than a week. You decide how often you want to buy tires.
2004 Excursion 4x4
Old 05-25-2016, 11:44 PM   #25
Cloudland2
davidrrand's Avatar
2016 25' Flying Cloud
Trenton , Georgia
4WD vs. AWD?
I think there may be some confusion between four wheel drive (4WD) and all wheel drive (AWD). All wheel drive vehicles like Subarus, Acuras, Hondas, BMWs, etc. are designed to operate on dry pavement. Traditional four wheel drive trucks are not designed to operate in four wheel drive on dry pavement.
I am not sure if all late model four wheel drive trucks that also have an AWD mode should operate on dry pavement and I have one (F-150 Lariat). I think it is possible as most AWD systems only kick in when wheel slippage is detected.
Maybe some of our truck techs here can answer this question.
davidrrand is offline   Reply With Quote
Old 05-26-2016, 09:07 AM   #26
dznf0g's Avatar
Oswego , Illinois
Yes, you are correct...but there is no confusion. The discussion surrounds "true" or conventional 4WD. And yes many trucks ans suvs, including the OPs description have a 4WD setting and an Auto setting. But AWD, as defined in the industry, is engaged all the time and provides for a "clutch" mechanism in the transfer case. "Auto" provides 2WD until the system detects slip and then engages the transfer case, but the front axle is always engaged in "auto" setting.
-Rich-
Old 05-26-2016, 09:32 AM   #27
Drive Systems
Four-Wheel Drive
before using.
{Caution
The big deal is that while descending, with all for wheels engaged in full time four wheel high, all four TV tires are aiding in holding the TV back without having to hit the brakes as often. It is simply safer. I use it whenever I am on up or down mountainous and curve terrain otherwise it is in 2 wheel at all times.
Old 05-26-2016, 10:12 AM   #28
2018 27' Flying Cloud
To be clear on my vehicle, I do not have 4WD, but 2WD. I did have AWD, but that was on my Subaru Outback and that couldn't tow my last trailer, or the Airstream.
wbrisett is offline   Reply With Quote
Old 05-26-2016, 10:15 AM   #29
dznf0g's Avatar
Oswego , Illinois
Ok, I double checked myself by contacting our Brand Quality Manager for PUs. He verifies all I have said and also, like me, believes this is a non-issue. It is virtually impossible (on clean dry pavement) for an automatic transmission of any vintage to create more than a "chip" before GAS engine RPMs catch up to gearing/tire speeds. And then only if the operator drops too many gears relative to road speed. On modern transmissions (electronic) the trans has self protect logic the prevents dropping too many gears by operator error. I can't recall when that started, but it was MANY years ago.
In addition, there are other systems which will mediate on slippery surfaces (rain, oil/water mix, or God forbid..snow/ice). Although it is not in the owner manual nor service manual, there is logic in the traction control system to also account for the "reverse kind of slip" we are talking about here. Also Stability control and trailer sway control logics will mediate as well.
Modern GM diesels have these algorithms as well, plus the exhaust brake is tied into the remedial action as well.
We could talk about really old tech vehicles and manual transmission, and diesels with sticks, but that should be another thread.
Bottom line, with the OPs title line vehicle, as well as many other manufacturers vehicles, this is a non-issue and WILL cause accelerated wear/failure of transfer cases, especially if adopted as a practice.
All that said, if you are on a slippery or gravel/dirt surface, your advice is appropriate.
-Rich-
Old 05-26-2016, 10:19 AM   #30
dznf0g's Avatar
Oswego , Illinois
You're fine. Don't worry about it. Your truck has many, or all, of the remedial action safeguards I mentioned. Especially if it has the ITBC. (I am assuming you're well averse to proper mountain driving techniques....if not ask someone)
-Rich-
Old 05-26-2016, 10:42 AM   #31
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Vantair View Post
FF,
Excellent point as forgot to mention having the 4x4 and available AWD setting. Never used it except for test on a ski trip/mostly cleared road.
Anyone else out there using the AWD setting while towing and would it be good mechanical practice all the time or just anticipated downhills ? Also Shifting to it while freeway speeds or only stopped ?
It's not an AWD setting...It's "auto". See above post.
-Rich-
Old 05-26-2016, 06:16 PM   #32
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Why not use the brakes? Brakes, by design, are a wear item and reletivly inexpensive to replace compared to a transmission.
kscherzi is offline   Reply With Quote
Old 05-27-2016, 02:49 AM   #33
The idea is to not burn up your brakes, instead you allow the vehicle to help you so you're not riding the brake. As several have pointed out, the grade braking feature is designed to help you without damaging the transmission. I have seen it engage a couple of times on my older (and lighter) Aframe camper, but not on steep declines, and really didn't feel the affect of it, so I had no idea how well it worked. That was the point of my discussion here.
Can you just ride the brakes? Yes... and this may be the only option depending on the vehicle. But it actually can be harder on the brakes and rotors since they can get extremely hot if you end up riding them. It's not the brake pads you worry about so much in this situation, but the rotors. Damage those and you're going to wish you hadn't.
Going through the mountains of New Mexico and Colorado will give me quite a bit of experience with the grade braking on this trip. I'll post my first hand experience in a couple of weeks when I return from the trip.
Thanks to all for the information provided.
Old 05-27-2016, 08:23 AM   #34
To use your brakes as a primary to slow your descent will over heat them and could make them useless.
This entire argument is pointless in my opinion. To argue against common sense, which unfortunately seems to be very common on these treads is down right stupid. Engaging all four point traction in conjunction with the engine brake to aid in safely descending on steep grades is what professional drivers do.
To suggest that the manufacturer builds a truck with this capability and than not to use it because it wears on the truck is asinine. If one doesn't have the basic understanding of the concept of using the locked 4 wheel drive option as needed and not when it isn't shouldn't be on the road pulling a trailer.
I was very specific in my initial post that I use it mostly descending and occasionally as needed, never suggested as a full time driving mode. I didn't think it was needed assuming we are all intelligent competent individuals.
Old 05-27-2016, 08:46 AM   #35
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Yes, you are correct as it is AUTO (was going from memory).
Perhaps AUTO would be a better compromise between 2 wheel vs 4 wheel drive on such downhills ?
Vantair is offline   Reply With Quote
Old 05-27-2016, 10:50 AM   #36
kscherzi's Avatar
Images: 24
My vehicle has 4 drive options. 2H, AWD, 4H, 4L. The owners manual (Ford) is very clear, only 2H and AWD on pavement. 4H and 4L non pavement only othwise damage may occur. Engine braking is accomplished by shifting down thus causing the engine to be forced to rev higher which is reletively harmless. Putting into 4H or 4L on pavement will also help to slow down because the transmission is binding internally, probably overheating, and trying to destroy itself. For these reasons I don't buy the argument favoring 4H downhill on dry pavement.
Your vehicle and trailer brakes ought not to overheat to the point of damage or fade unless you allow the rig go too fast.
Old 05-28-2016, 08:57 AM   #37
Buy it or not it is obvious you don't have any experience with utilizing your vehicles capabilities and options to your advantage. And the only reason I am responding is that you are misleading people into believing that using the 4 wheel option is not advisable and that a half ton 4 wheel drive pick up is a fragile piece of equipment. That is pure poppycock.
I use it every time conditions require it. I have yet to to experience transmission over heating or any other adverse effects. Have you ever plowed snow with your pick up ? Obviously not. The stress a truck is placed under pushing heavy snow and ramming snow banks to push up the pile is far more stressful than descending at 30 or 40 MPH 30 minutes at the time.
I used a Tahoe to plow our facilities over 10 seasons. I literally beat the crap out of it plowing. It was also my daily driver and used for many trips to Florida ended up putting 230 K miles on it. Never had any Transmission or Drive train failure. So please stop projecting your anxieties on everyone else.
Old 06-13-2016, 04:05 AM   #38
Back from Yellowstone. Headed out to the black hills as well. Our steepest descent was a 8% grade. The good news is you're right, had nothing to worry about. :-) The truck and grade braking handled things like a champ.
So, bottom line, the GM grade braking system gets high marks in my book and works very, very well.
Old 06-13-2016, 04:08 AM   #39
dznf0g's Avatar
Oswego , Illinois
Although not the rockies, I was in Smokies last week, and found the same with my 30'er in tow. You certainly use the brakes a bit more than a diesel, but not a lot. And certainly not enough to even warm the brakes much.
As I recall, 6% was common and most I saw.
-Rich-
Old 06-13-2016, 05:03 AM   #40
SeaLevel's Avatar
Jupiter , Florida
Great. Thanks for the update. We are pulling our 25' out of the FL flatlands for the first time starting next weekend, and while I can do things like make sure it's level and that the WD hitch is setup right, I don't have an easy way to test grade braking. So it's good to know that it worked well for you.
SeaLevel is offline   Reply With Quote
Report on Chevy/GMC 1500 with 6.2 engine and Max tow pack DC Bruce Tow Vehicles 436 03-19-2021 07:22 AM
Equalizer hitch on 2014/2015 GMC Sierra 1500 Denali or SLT runnersg Hitches, Couplers & Balls 2 06-16-2015 12:36 PM
2015 GMC Yukon Denali 4WD & 2015 Flying Cloud 30 ? DHart Towing, Tow Vehicles & Hitches 22 04-09-2015 07:01 AM
2014 Chevy/GMC 1500 6.2L + max tow? DC Bruce Tow Vehicles 87 02-11-2015 07:17 PM
2015 Chevy 2500 LTZ HD vs GMC 2500 Denali HD Roadtech Tow Vehicles 2 10-21-2014 05:47 PM
