Old 06-15-2016, 10:15 PM   #41
2015 27' Flying Cloud
Bozman , Maryland
I have a 2015 Sierra 1500 SLT with the 6.2 liter engine and 8-speed box. Also the max trailer tow package. There are 2 modes to the hill descent control. The more aggressive mode is invoked when you use cruise control; the transmission will start downshifting when you exceed the set speed by 5 mph and will continue to downshift if the vehicle keeps accelerating spinning the engine up to about 4200 rpm. The second mode is less aggressive and kicks in based on some combination of factors that I can't figure out. The nice thing is that when cruise control downshifting happens, applying the service brakes does not trigger an upshift. You can use manual control as well, without fear of over revving. The shift command will be refused if it would cause an overrun.
Regarding the use of "auto" on your 4wd setting, I don't see why that would provide any benefit. In fact, if you're in a low-traction situation (rain, snow), you should be careful about using a lot of engine braking. Use the service brakes instead and slow down a lot. Remember that most newer US-branded trucks with integrated trailer brake controllers include ABS and D.SC. Functions.
I've descended up to 10% grades without incident, using the service brakes as needed and never got them hot enough to smell. That's pulling an FC27.
DC Bruce is offline   Reply With Quote
Old 06-15-2016, 11:07 PM   #42
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Originally Posted by kscherzi View Post
Why not use the brakes? Brakes, by design, are a wear item and reletivly inexpensive to replace compared to a transmission.
You know the Runaway Truck turn outs over on 80? and there are several of them? And a few on 50 coming down Spooner. Ever see the trucks setting in that gravel? Or see a truck turned over and 80 is closed because he didn't have a Runaway turn out? Comes from inexperienced drivers riding the brakes. Best not descend at a speed where the rig pushes the engine revolutions up, that the compression doesn't hold back the rig.
First sign you have trouble is a warped rotor. Then fading. Maybe you'll see smoke.
Don't light up the forest with a fire from your brakes, not cool. They burn up the hills around Kyburz regularly with brake fires, and cigarettes.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Report on Chevy/GMC 1500 with 6.2 engine and Max tow pack DC Bruce Tow Vehicles 436 03-19-2021 07:22 AM
Equalizer hitch on 2014/2015 GMC Sierra 1500 Denali or SLT runnersg Hitches, Couplers & Balls 2 06-16-2015 12:36 PM
2015 GMC Yukon Denali 4WD & 2015 Flying Cloud 30 ? DHart Towing, Tow Vehicles & Hitches 22 04-09-2015 07:01 AM
2014 Chevy/GMC 1500 6.2L + max tow? DC Bruce Tow Vehicles 87 02-11-2015 07:17 PM
2015 Chevy 2500 LTZ HD vs GMC 2500 Denali HD Roadtech Tow Vehicles 2 10-21-2014 05:47 PM
