Old 09-01-2007, 11:46 AM   #1
tetstream's Avatar
2007 19' Bambi
Somewhere , Between the Tetons and the SF Bay
Good swaybars make a difference
Thought this info might be good to post out here.
When I bought my new 2006 Chevy 2500 HD Duramax, I knew that the factory suspension was "soft" and I intended to pull my construction trailers (and a travel trailer later) down the road and on the interstate.
I first replaced my OEM sway bar (front only is original equip) with HD sway bars from here:
Frederico Performance Swaybars and Suspension Products
These are top quality solid bars with good quality hardware. Not Hellwig standard issue junk. The package includes a substantial rear bar as well. I did the install myself and I don't like being a mechanic.
At 500 miles, I replaced my OEM shocks with Bilsteins that I bought from
http://www.kennedydiesel.com/
Easy install myself without removing any wheels.
These two changes made a dramatic difference in the handling without ride sacrifice (IMHO). I would never be without HD sway bars. They make more difference in control than tire pressures. Well worth the $$$.
I am pretty sure that Frederico Racing makes bars for Burbs as well.
Have fun and drive safely !
ID:	44237   Click image for larger version
tetstream is offline   Reply With Quote
Old 09-01-2007, 11:50 AM   #2
tetstream's Avatar
2007 19' Bambi
Tire too !
Oh yeah, the other I replaced at 500 miles was the oem tires. I replace them with Bridgestone REVO A/T 265/75's E on the OEM alloy wheel. I generally run about 55-60 psi front and 70-80 psi rear. Great tire so far. I had C rated on another half ton truck and the tires were great. They are very sticky without wearing too fast. Good ride, not noisy.
Wow What a Difference! With the diesel. thecatsandi Tow Vehicles 11 10-30-2006 11:27 AM
the difference... of a hitch adjustment bradk Hitches, Couplers & Balls 11 05-22-2006 08:27 AM
The right person does make a difference stinkytwinky Waste Systems, Tanks & Totes 16 09-24-2005 11:53 PM
What's the Difference ? Bfrank Our Community 7 08-10-2005 01:17 PM
Where's the difference? azflycaster Airstream Trailer Forums 2 06-11-2005 11:20 PM
