Old 03-26-2015, 07:07 AM   #61
2023 25' Globetrotter
Manheim , Pennsylvania
Originally Posted by ROBERTSUNRUS View Post
Hi, according to your listed specs, your trailer is too much for your truck. I personally would not do it. But if you do tow with this combination, you will most likely have less problems doing it than some of the posters on this thread have with each other.
Yes, according to the 2009 specs maybe borderline, it was a new truck and Chrysler rated it conservatively. The revised 2010 specs on the exact same truck (model year 2010) say good to go. I have read many tow vehicle threads since I joined this forum. That's what got me concerned in the first place. Many people saying you can't tow anything over 19' safely with a 1/2 ton pickup. That's your opinion. I don't believe it. I wish I had a big diesel truck but I don't and I won't.
I would like to thank everyone that responded to my thread!
Jukeboxfun is offline   Reply With Quote
Old 03-26-2015, 09:04 AM   #62
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My half ton Chevy with 20" wheels tows my 31' trailer just fine.
I don't know what the sticker in the door jamb says and I really don't care...
Does that make me bad?
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 03-26-2015, 09:50 AM   #63
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Yea Morgan you're bad, if it works for you run it, having fun in sunny and warm San Diego !
Old 03-26-2015, 12:53 PM   #64
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I reckon that resembles my attitude.
My Tundra with 20's don't seem to mind towing my 30 for the past 5 years. Maybe it's overloaded. It don't seem to know or care.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-18-2015, 01:16 PM   #65
1982 31' Excella
Missoula , Montana
I have just returned from a 6800 mile trip pulling a 1982vExcella 31 pulled by a 2013 Ram 1500 5.7 20 inch tires. No problems and pulled great, as others have said get right hitch and set up correctly.
Vernbots is offline   Reply With Quote
Old 04-18-2015, 01:26 PM   #66
Tincampers's Avatar
Sneedville , Tennessee
More detailed information here:
http://www.dodge.com/bodybuilder/200...r/mlup1500.pdf
They do make a differentiation between 20" tires and the 17" tires.
I went round and round with this with my 2007 Ram 1500 with 20" tires with the 3.92 rear axle. Different places all said different things. In the end, I hooked it up and tried it out. I ended up selling it and bought a 2003 Suburban 2500 4X4 with QuadraSteer. Huge difference in towing performance and comfort.
Tincampers is offline   Reply With Quote
Old 04-18-2015, 01:53 PM   #67
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Another 3/4-ton convert!
Like I say..... get a 3/4-ton and quit worrying about it!
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-18-2015, 02:04 PM   #68
PaulnGina's Avatar
Good Ol' , USA
You'd LOVE it..... don't rule it out.
1987 Avion 34W
Old 04-19-2015, 09:02 AM   #69
2004 22' Safari
Albuquerque , New Mexico
Don't do anything yet...
We bought a 25 flying cloud twin which has a published base weight of 5,600 lbs. with loaded weight max of 7,300 lbs.
TV is
2009 Dodge Ram crew cab slt hemi.
3.55 axle
20 inch wheels
GCWR 12,000
GVWR 6,800
max trailer 6,400
Same truck with 17 inch wheels is rated
GCWR 13,000
max trailer 7,450
Do I get smaller wheels or a bigger truck? I bought the trailer, can't change that.
Check to see what the the rolling radius on your 20 inch wheels. Compare it to the stock 17 inch wheel rolling radius. As far as torque is concerned, there is probably little difference since my new Tundra has 20 inch wheels and a 17 inch spare. When I checked, they were within 1% on rolling radius.
Unless there is reason to believe the 20 inch wheel design is weaker, there shouldn't be a difference in the ratings... unless all 17 inch tire models also have a 4.10 rear end or something like that... but it is unlikely. 3.55 is probably bottom end, but should work. You should have the rest of the 'towing package' to include transmission oil cooler, HD cooling, HD alternator etc., but the transmission oil cooler can be installed aftermarket and is the most important of the bunch. If you want to spend a little more, you could have your rear end axle ratio changed (front too if a 4x4).
Silver.Sanctuary is offline   Reply With Quote
Old 04-19-2015, 10:23 AM   #70
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
I have not seen to many drivers that fit the 175 pound allowance in the empty weight calculations. The FAA finally had to concede that there are not too many 170 pound standard weight passengers either.
Skip the theory and go to the scales and see the real numbers.
Weigh the truck with nothing in the back bed, no hitch head and just the driver and a full tank of fuel. Then you know the truck's true empty weight. Subtract that number from the GVW number on the door jamb to get the actual payload for the truck. You will also on the print out have the loads on each axle and compare those numbers to the maximum rating on the door jamb.
Now load all the stuff you plan to carry in the bed and install the hitch head and take the usual passenger and cross the scales. Look at the axle loads and the remaining payload.
If the remaining payload is less than the Airstream published tongue weight, you have to off load all the stuff in the bed and cross the scales again to see if the net payload is greater than the Airstream published tongue weight. If the number is too low, end of story as the real tongue weights on Airstreams always exceed the one in the literature.
If there is still payload available by this point, take the trailer loaded for camping, full propane and fresh water tanks, same stuff in the back of the truck and the passenger to the scales again. The scale report will now include the load on the axles of the trailer as well as the front and rear axle of the truck. Typically the trailer axles are not overloaded, but the truck's rear axle and possibly the front could be overloaded.
A weight distribution hitch can, in theory, move the apparent weight around between the front axle and trailer axles and thus unload some weight from the rear axle. In a perfect world, one would expect ⅓ of the tongue weight to be spread on each axle group. By adjusting the hitch, more weight can be moved to the front axle which when properly set up should have the same or more weight on it than before the trailer was attached.
In the case in question, the big issue will be the combined weight of both vehicles when hitched together exceeding the door plate GCVW number. That is the controlling document if there were an accident. Higher weight capacity on the next year model do not apply to a prior year's rating on the door jamb. If that number is the same or lower than the GCVW limit, then one can spend time adjusting the weight distribution system to get the axle weights where they need to be.
The logic is that exceeding these maximum numbers could put the operator in a legally non-defensible situation for intentionally operating their vehicles in a reckless manner by overloading it. Commercial drivers are the ones held responsible for the weights in the truck.
Good luck in your research.
Old 04-25-2015, 08:35 PM   #71
I can now speak from actual experience towing the 25 FC with my 2009 Ram 1500. I have towed it about 1500 miles now. The truck has a strong 5.7 liter V8 and has sufficient power to handle the job over some pretty good grades in western PA. The key with this is the Tow/Haul mode, it makes it all possible, the proper shifting and engine braking under load is great. The Equalizer hitch makes it very easy to tow an Airstream at highway speeds with merging not a problem. I averaged about 11.9 miles per gallon towing.
That being said, if I had the money, I'd probably get a 2500 diesel to do the job.
I wouldn't want to try to tow anything larger than the 25 footer with what I have.
So far, the Dodge Ram 1500 did everything I asked it to do without a problem.
Old 04-25-2015, 09:14 PM   #72
PaulnGina's Avatar
Good Ol' , USA
Glad to hear you had some successful travels.
Save up your pennies while you keep your eyes open for a 2500 diesel. Good deals pop up if you're patient. You won't regret it.
1987 Avion 34W
Towing with a 1999 Dodge Ram 1500 crew cab with 8ft. box with 5.9L engine Paul and Sue Tow Vehicles 11 07-27-2009 08:44 PM
Dodge Ram 1500 Tow Vehicle UK-Airstream On The Road... 6 06-07-2008 12:54 PM
Dodge Ram 1500 Tow rating HELP!!! cobra93 Tow Vehicles 11 02-05-2008 07:20 PM
Dodge RAM 1500 SLT 5.9 liter tow vehicle abridges01 Tow Vehicles 10 08-17-2006 08:25 AM
