Old 09-15-2016, 11:30 PM   #1
2016 26' Flying Cloud
niceville , Florida
Gmc Denali debacle
Went to a GMC dealer in Tacoma for oil, tire and rotate. They courtesy added 3 gallons of GM DEF, truck miles was 11000.
Now at 14000 miles, DEF system warned speed limit, went to dealer in Denver, GMC. Long story short.
$2235 to replace contaminated DEF system.
Last person to touch the DEF tank and service it was dealer in Tacoma.
Not warrantable item. And in case you wonder I didn't add diesel fuel to my aDEF tank in a. brand new Denali 2500HD! OMG I was sick.
kapt59 is offline   Reply With Quote
Old 09-16-2016, 01:06 AM   #2
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Thread Title Misleading
I am sorry for your experience, but your thread title is very misleading. There is/was NO PROBLEM with your GMC Denali. You had a bad experience with a DEALER that is an independent business and not part of GMC. You should take this issue up with the dealer that filled the DEF.
Knowing that the DEF fill on your GMC is under a locking hood (rather than in an easily accessible fuel door on other brands/models) means that no one could have tampered with your truck by adding a contaminant to the DEF tank unless you ever left the truck unattended with the hood unlatched. This is not true of some other brands. I believe this is actually a benefit on the GMC (& Chevy) HDs - one has to unlock the door to unlatch the hood to fill the DEF. If you have never left your hood open with the truck unattended, the source of your problem is likely the dealer that filled the DEF, even if the contamination was an accident (e.g. a newby putting washer fluid in the wrong filler neck).
Again, sorry for your issue.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 09-16-2016, 05:33 AM   #3
Gainesville , Florida
Accidents happen. Contact the dealer to make sure they know, see what they say before doing anything. They need to know, they may have an inexperienced or careless employee. This may not be the first time this happened at that dealer, and they need to have a record to figure out who fd up.
Old 09-16-2016, 06:28 AM   #4
RonaldC303's Avatar
Washington , Utah
I guess that I do not fully understand what happened. The DEF system was fine at 11,000 miles but was contaminated at 14,000 miles? How did it function for those 3,000 miles?
I have a 2015 GMC Duramax myself. On a trip last summer the DEF system malfunction warning light came on and I was speed limited by the time I reached the next GMC dealer. As it turns out, it was a software issue for which there was a TSB. The repair was no charge under warranty.
My question now is whether the Denver dealer misdiagnosed the problem and made it your liability?
I am truly sorry you had to go through this. Being on the road and developing tv problems where you are forced to seek out the nearest dealer is aweful. Best wishes going forward.
RonaldC303 is offline   Reply With Quote
Old 09-16-2016, 06:38 AM   #5
dznf0g's Avatar
Oswego , Illinois
Pm coming.
-Rich-
Old 09-16-2016, 07:42 AM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
On my '13 Silverado 2500, the DEF tank heater was defective, throwing warning lights and threatening speed restriction. It was replaced under warranty. Sounds like your issue may be more with a mishap at the dealer who gave you the complementary DEF top off so you should definitely talk with them - but I'm sharing this just in case you have the same issue...good luck!
Old 09-16-2016, 09:19 AM   #7
Boxite's Avatar
2008 22' Sport
It's very unlikely the dealer providing the "complimentary DEF" caused this problem. The truck drove for three-THOUSAND miles just fine... so the contamination did not occur 3K miles previously. This sounds like a system or software/sensor problem.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 09-16-2016, 09:40 AM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What was the contamination?
MICHAEL
Old 09-16-2016, 11:03 AM   #9
dznf0g's Avatar
Oswego , Illinois
That depend upon what year it is. OP doesn't say.
-Rich-
Old 09-16-2016, 11:34 AM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have a 2011 Chevrolet Silverado 3500 Duramax that I have owned from new. It now has 110,000 miles on it.
I have experienced the "Poor Quality DEF" warning on five occasions over the past five years. Each time we were traveling with the Airstream and went to GM dealers in different parts of the country. These dealers were in California, Utah, Florida, Ohio, and Maine.
As it turned out, none of these warnings were caused by bad DEF. On two of these occasions, the dealer was able to shoot a new code to the truck's system (per GM service bulletins). On one occasion, the dealer replaced NOX sensor #1. On another occasion, the dealer replaced NOX sensor #2. On the most recent occasion (July, 2016), the dealer replaced the DEF pump module.
None of this had anything to do with DEF quality. It was all caused by malfunctioning electronic hardware and software. The first four DEF incidents were covered under the GM 100,000 miles extended diesel warranty. The most recent service, where the DEF pump was replaced, was on my dime as the truck had passed the 100,000 mile mark by then.
This DEF thing has been a giant pain since I have owned this truck, and this is the only problem that I have had with it since new. I started researching DEF problems several years ago. I have read numerous articles on the issue. The consensus of opinion seems to be that the Federal Government forced the manufacturers into this before the technology to monitor the DEF system was ready. Accordingly, DEF problems are not rare on these trucks. Thinking that maybe another brand was better, I have done extensive reading on forums for Ford and Ram diesel trucks. It seems to be the same story industry wide.
Unfortunately, my load situation requires a diesel tow vehicle. A gasoline engine vehicle couldn't handle the load I am carrying. If it could, I think that I would have gone back to a gasoline tow vehicle several years ago.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 09-16-2016, 11:57 AM   #11
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Brian
I can guarentee you that you're not the only one with these sentiments. I have been cautioning potential buyers of diesels that any perceived savings on fuel economy will be eaten up in higher maintenance cost and long term durability issues.
Sad to say but gone are the days of the 500,000 mile Dodge diesel that rotted out before the engine gave out. Now days you'll want to trade that diesel in before the warranty is up, as EGR, sensors and extra gimmicks are going to sap your technicians ability to diagnose problems properly and cost you a bundle.
The other big issue as new better systems, mid year changes and fixes are rolled out, previous parts may become obsolete and NLA to fix your diesel, especially if the old system is found out to not meet government standards; you maybe on the hook to replace an entire system.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 09-16-2016, 12:03 PM   #12
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I'm a first time diesel owner. If this happens to me in the first 5 years of ownership my Ram is gone and I'll go back to a gas tow vehicle. 1st year is used up.
Kelvin
Old 09-16-2016, 05:22 PM   #13
moosetags's Avatar
Kelvin
I don't blame you. I would have retreated to a gasoline tow vehicle if I could have. If they don't get this DEF stuff straightened out, I don't know what I am going to do in the future.
Brian
Old 09-16-2016, 06:00 PM   #14
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Sounds like something you can claim under comprehensive in your insurance policy. My 2015 RAM ecodiesel had a engine failure that was attributed to contaminated fuel, like you I did not put gasoline in. Under warranty not covered, my insurance company paid the bill less deductible under the comprehensive part of my policy. I later learned that even if it was my fault it would have still been covered.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Denali 1500 w/6.2L vs. Denali 2500HD Duramax DHart Towing, Tow Vehicles & Hitches 60 08-18-2017 04:41 AM
2015 GMC Yukon Denali 12,000 lb Towing Roadtech Tow Vehicles 50 10-21-2014 10:13 AM
Tow Vehicle-2011 GMC Yukon Denali-FC 23/25FB BMay Tow Vehicles 10 04-09-2011 10:24 AM
31' Excella 500 with GMC Denali TV ?? DesertRat Tow Vehicles 14 05-17-2007 09:59 PM
