Old 02-02-2007, 04:03 PM   #1
safarijim
safarijim's Avatar
Profile:  2007 28' Safari SE
Fresno , California
GMC/Chevy Tow Haul Mode
I was just wondering if anyone has used the Tow/Haul Mode that came on my 2005 2500HD? If so, how did you employee this feature? I haven't towed with the GMC yet, so interested how it worked for others.
thanks
Safari Jim
N6QYV
GMC 2500HD Diesel
"The Older I Get - The Better I Was..."
safarijim is offline   Reply With Quote
Old 02-02-2007, 04:05 PM   #2
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Greeting Jim-
This was discussed once before, use the search feature, but since I'm here, whenever we are towing we always have the tow mode engaged and I keep the tranny out of Overdrive.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 02-02-2007, 04:43 PM   #3
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
If your towing you hit the button, it changes the shift points, it does go in overdrive.
Moreover, it down shifts to help you stop
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 02-02-2007, 05:00 PM   #4
DEO
DEO's Avatar
Profile:  2005 25' Safari
West of Boston , Massachusetts
thanks
I find it to be excellent especially when exiting the highway or when you need to slow down...
DEO is offline   Reply With Quote
Old 02-02-2007, 05:01 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Jim,
I'm guessing that you have the Allison 5 sp. auto trans with your Duramax engine. If so, you do not have to tow in 4th gear as suggested. This trans is plenty stout to tow in 5th just as I have done with my 8.1 gas engine with same trans and rear end as you.
What I have discovered is that when and if the transmission needs to downshift, in tow/haul mode, the engine rpm is not as high as it would be if this feature was not selected. I use it this way to keep engine rpm down slightly; however, I have found that the transmission does not always shift back into 5th gear as soon as I would like it to after cresting a hill. I just take it out of tow/haul mode, the engine shifts back into 5th, rpms drop and I then press the tow/haul button again. Sounds like a pain but it works for me.
The tow/haul also give you additional braking on down hill grades but I don't use the feature with my 8.1. I just work the brakes carefully making sure not to overheat them. I believe if I was doing much up and down hill driving with the diesel, I'd get an exhaust brake (jake brake) if the size/weight of my trailer indicated it would help.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-02-2007, 05:08 PM   #6
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The transmission that comes with the gas 6.0 liter engine also has enough muscle to tow in OD. The vehicle manual notes that it's ok. I use the tow/haul and it hangs on to the lower gears longer during acceleration, and kicks you down into a lower gear earlier if necessary. I don't see that it provides any benefit on downhill grades though. If I'm in od it stays there. To get additional braking I need to downshift to 3rd.
Bottom line read the manual and see what the manufacturer recommends. My current vehicle is the first one that ever permitted OD towing.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 02-02-2007, 05:11 PM   #7
2airishuman
2airishuman's Avatar
Profile:
the best reason i've read to keep it out of overdrive!
remind me never to follow you in a caravan....
cheer
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 02-02-2007, 05:17 PM   #8
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
cheer
2air'
2air,
Give him a break, it is only a typo.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 02-02-2007, 05:23 PM   #9
Cracker
Cracker's Avatar
Profile:  2000 30' Excella
Pittsfield , Maine
I use the tow/haul mode consistently in the mountains. It does restrict the upshift to overdrive to about 58 mph. A nice feature.
Cracker
Cracker is offline   Reply With Quote
Old 02-02-2007, 06:03 PM   #10
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Tow haul is a great feature that GM and I believe Ford have offered in their light truck lines (vans too).
Tow haul basically uses the computer to manage shift points, locks the torque converter, etc. It is suggested it be used when towing and I've used it with great success. The GM version I don't believe actually turns off overdrive, but more control the transmissions ability to downshift as frequently/easily as it normally might without tow/haul on....but it will downshift if the need comes up. Transmission temps I've observed using tow/haul when towing are slightly cooler than without tow/haul on due to the constant downshifting that happens.
Bottom line, the suggestion to review the owner's manual is a great idea. Press the button (on GM trucks-- I assume Ford has them in the same place, but have no idea if Dodge has it or where it would be located) located on the the gear selector when ready and you too will be a happy camper.
Old 02-02-2007, 06:17 PM   #11
davidz71
davidz71's Avatar
Originally Posted by Silvertwinkie
...Tow haul basically uses the computer to manage shift points, locks the torque converter, etc. ...
I get the impression that from a standing start, the shift points are higher and when the vehicle goes up a grade and the transmission shifts down, I can see the tach drop further as the torque converter locks up to limit slippage with the resulting heat associated with this slippage. Would you say that is what is actually happening? Again, this is what I am seeing with the 8.1 gas and it may be different with the diesel due to programming.
Craig
AIR #0078
3.73 rear end
Old 02-02-2007, 07:21 PM   #12
LI Pets
Silver Mist
LI Pets's Avatar
cheer
2air'
What's that mean?
I have a 6 speed allison, it drops into 6 when at hwy speed??????
WBCCI
Old 02-02-2007, 07:31 PM   #13
Silvertwinkie
Aluminut
It's hard to say when the TC locks for sure in that situation. I know that on the flat road, if you tap the brakes, ever so slightly, you will see the TC unlock by the RPMs increasing. I would guess that if you see the RPMs drop, you may be seeing a TC lock situation. If you tap the brake pedal when that happens, every so slightly, basically making the brake lights come on and not acutally engage the brakes, and the RPMs go up that would pretty much say to me, yea, you just saw the TC lock and unlock.
An unlocked TC is one of the main sources of heat buildup, if not the biggest and tow/haul can help eliminate some (not lots, some) of that heat.
Old 02-02-2007, 08:18 PM   #14
davidz71
davidz71's Avatar
I love my Allison 5 speed but it must be even better as a 6 speed. LI Pets, have you driven the 5 speed and the 6 speed to get a comparison?
Craig
AIR #0078
3.73 rear end
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 01:18 PM
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 9 10-01-2004 12:05 AM
tow vehicles paul k Tow Vehicles 96 01-19-2003 10:59 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 08:04 AM
Banks PowerPack for 7.4L Chevy LTD93 1969 Overlander 6 09-24-2002 06:53 PM
