Old 09-15-2007, 12:26 PM   #1
gowyn's Avatar
Profile:  2007 27' Safari FB SE
London , ontario
GMC 2500HD Query
Hello, have a question.
Recently we replaced our Bambi with a 27FBSE. We were towing it with a short wheel base Landcruiser but also replaced it with a 2004 GMC crewcab 2500HD DMax/Alli.
So our setup is: truck (stock CC SB), Hensley Arrow hitch, 27FBSE.
Only had the combo out the once so far, on the highway it's great, along bumpy roads however there seems to be a bit of up and down wagging or oscilating. Never really noticed this much in the LC so is this perhaps a wheelbase thing, HA WD needs some more adjusting or perhaps shocks in the GMC are a little softer?
I've heard that a lot of people replace the stock shocks with Bilstein, any particular reason?
Thanks.
gowyn is offline   Reply With Quote
Old 09-15-2007, 12:49 PM   #2
U.S.Navy Retired
Safari-Rick's Avatar
Profile:  2005 25' Safari
Lakewood , California
They are a very "stiff" gas shock. Suppose to be the best out there and have a "lifetime" guarrentee. I had them on my Dakota but it bounced all over the place when I wasn't towing. Maybe with your larger TV this is not an issue.
Oh, and $$ wise, they are not cheap!
S-Rick
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 09-15-2007, 02:40 PM   #3
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
what are you running for air pressure in your rear tires on the truck?
you may try the maximum (80 psi rear 55 front i believe) and see how that works.
check the sticker on the door jamb to be sure, you can always lower the pressure when you are not towing or hauling a ton and a half of bricks!
john
you call them ferrets, i call them weasels.
john hd is online now   Reply With Quote
Old 09-15-2007, 04:22 PM   #4
Profile:  2007 25' Safari FB SE
Burien , Washington
john
Sounds like a similar combination as ours.
The maximum is 80 PSI in the rear. I think you can go higher in the front that 55, but, check the sticker.
When moving your hitch from one truck to another, does one need to adjust it?
Sam
SRoffe is offline   Reply With Quote
Old 09-15-2007, 04:35 PM   #5
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Gowyn,
It may be that you can relax the WD a bit - that might help the jarring part of your ride.
Sounds like a great rig - Pat
pmclemore is offline   Reply With Quote
Old 09-15-2007, 04:58 PM   #6
gowyn's Avatar
London , ontario
Hmm,
when I hooked up did just that (lowered amount on WD)
I test drove a few trucks and found the GMC was more car like (i.e. smoothe riding) than the Dodge and Fords. Even empty it's a very non-jarring ride.
I'll experiment I think, thinking of the physics I may not of had enough weight on the front tires.
How do others with these trucks find the ride on bumpy roads?
Old 09-21-2007, 11:53 PM   #7
tetstream's Avatar
Profile:  2007 19' Bambi
Somewhere , Between the Tetons and the SF Bay
replace your shocks
I would say, replace your shocks. It's widely felt that the OEM GM shocks are junk, very soft and fail quickly. I replaced mine with Bilsteins at 500 miles. It gave the truck a more controlled feeling, and cured what I called "the bob", or the truck oscillating up and down from hood to tail. The ride is a bit firmer, but tire pressure makes more difference than the shocks.
Some guys have used the Rancho adjustables and like them.
Around the same time, I replaced the oem tires with Bridgstone Dueler Revos 265/75 16 E. That improved the control and ride.
Also installed HD sway bars front and rear, which really made a difference.
All in all, I am very happy with the way the truck handles now. It's not a supple 1/2 ton ride, but it IS very confident and sure footed. I would never go back to stock.
Shocks from Kennedy Diesel.
Sway bars from Frederico Racing.
Did both installs myself.
TT: 2007 Bambi 19' 75th Anniversary Special Edition
TV: 2006 Chevy HD2500 Duramax 6-speed manual
tetstream is offline   Reply With Quote
Extended Cab or Crew Cab 2500HD w/Duramax for TV??? TomR Tow Vehicles 19 01-31-2007 07:27 PM
New wire Query. chalcedon Electrical - Systems, Generators, Batteries & Solar 9 09-16-2006 10:34 AM
Hensley and 2500hd davidz71 Hitches 4 03-24-2005 09:57 PM
food query norbert Off Topic Forum 8 12-15-2004 08:46 PM
A/S Factory query blucloud Off Topic Forum 1 07-13-2004 09:58 AM
