Old 11-28-2007, 09:04 AM   #15
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by safari 28
Bad decision for GM. This is the type of penney wise and dollar foolish decisions that they are famous for. Our 08 f150 had the pig tail in the drivers door panel and the dealer had the prodigy hooked up in 5 minutes.Why GM wants anyone pulling wires through the dash is beyond me.
Better yet, get the (Ford) tow command. Plug in the trailer set the gain and go!
Michelle TAC MT-0
Sarah, Snowball
Old 11-28-2007, 10:50 AM   #16
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Originally Posted by LI Pets
On my '07 I just plugged in a pigtail to the fuse panel under the dash, put a fuse in the panel under the hood and that was it.
I have used a Prodigy with my last three trucks (all GM of course) and they were all plug and pray...took 5 minutes. There was no "GM" pigtail (Prodigy provided that) you just plug into the fusebox on the firewall.
I will have to stop at the dealer and look at the firewall on one of these LTZ's...I am surprised this would change significantly...does the truck have tow package?
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 11-28-2007, 11:05 AM   #17
nymphfishin's Avatar
1977 Argosy Minuet 6.0 Metre
Del Norte , Colorado
Images: 30
Michelle
I was waiting for someone to mention the Ford TCM ease of operation.
Just takes 20 seconds including plugging the trailer cord in.
Well maybe GM will get it right in the next few years! :-)
nymphfishin is offline   Reply With Quote
Old 11-28-2007, 11:16 AM   #18
1 Rivet Short
1989 25' Excella
Originally Posted by Pahaska
new Silverado diesel LTZ. My truck doesn't have the built-in brake controller
He did not get the GM built in control on this truck, available on 07 and newer...
Old 11-28-2007, 12:11 PM   #19
SteveH's Avatar
Common Sense , Texas
OK. Your truck must be the "Classic" model. That model still uses the old type dashboard and old wiring as did '07s made up to about the middle of the model year according to the dealer.
My truck is the LTZ which is a completely new layout with the dash moved forward and down 5". No pigtail on these trucks.
Nope, mine is the new one. The new body style.
Old 11-28-2007, 02:21 PM   #20
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Bill
Mine did not have the tow pkg.
'77 Sovereign Intl 31' CB
Old 11-28-2007, 02:42 PM   #21
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
OK, now I'm scared....
I just bought a 2008 Silverado 2500 Diesel, Crew Cab, Long Bed, 2WD... and it's got a "pre-wire" for a brake controller located on the bottom of the dash to the left of the steering wheel. Yes it's got the tow package.
I just got my Prodigy model 90185 controller from Camping World today.
So this isn't going to be a "just plug it in and adjust it thing?" AARGH! I shoulda known when there was a miniature DVD in the Prodigy package.
I'm going to read all the instructions, play the DVD, read the owners manual and then probably call one of "youse guys" to help me do the actual install.
Paula
Old 11-28-2007, 04:04 PM   #22
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Fuse
The GM's fuse issue pertains to the power supply to the trailer 12V supply. the brakes and controller work plug & play. The plug or blank square fuse is only the power supply and it is likely that many people are towing without a 12V supply to there trailer. You would only know if you check the terminal with a tester. I can't remember which peg is the 12V supply but the cover has a diagram on the face. I can't imagine why GM does not include the fuse? I guess they save 5.00 per truck!
Phil Gobie is offline   Reply With Quote
Old 11-28-2007, 08:41 PM   #23
WBCCI 11067 WDCU
ckeysor's Avatar
1986 25' Sovereign
Atlanta , Georgia
Images: 30
Solution to the '07 GM and Chevy Brake Controller
I am buying a Silverado 1500 Max and found the following write up on the brake controller. Wiring Instructions for Tekonsha Brake Control for New GM Hope this helps. Although complicated and I question GM's decision, it is much easier than many of the things we have to conquer.
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 11-29-2007, 05:17 AM   #24
2007 25' International CCD
Arlington , Virginia
I whole heartedly concur. BTW I used a Prodigy when I was silly enough to have purchased a 1/2 ton before the current 06 PSD we tow with. The Prodigy worked well, it was the truck that was inadequate.
Streamer1 is offline   Reply With Quote
Brake Controller 1953 Flying Brakes & Brake Controllers 7 04-26-2007 02:17 PM
brake controller DOCTOR-MX Brakes & Brake Controllers 6 11-27-2006 05:34 PM
Brake Controller (which one ) poorboycjs Brakes & Brake Controllers 3 07-25-2003 05:42 AM
brake controller JPAIRSTREAM Our Community 3 05-04-2003 08:38 AM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
