08-23-2017, 07:16 AM
2009 27' FB Classic
Southlake
GM Integrated Brake Controller and Disc Brakes
Hello all,
I recently purchased a 2012 GMC Yukon XL 2500 tow vehicle to tow my 2009 27FB Classic. I have yet to hitch them up but, after a little reading on the Integrated brake controller, it appears that it is not compatible with my disc brakes. Does anyone have any information, if indeed this is the case, on a "workaround" with this issue.
I really like the idea of using the ITBC and not too keen on wiring in my Prodigy controller.
Thanks!!
Cory
08-23-2017, 07:30 AM
Oswego
I am afraid you will have to wire in your Prodigy. GM ITBC was not compatable with E over H until 2014 in the 1500s and 2015 on the HDs. For the FSSUs, it was 2015. New body style is the clue.
-Rich-
08-25-2017, 02:25 AM
2009 27' FB Classic
Southlake
Thanks, that's a bummer! I was hoping someone had found a workaround.
08-25-2017, 04:32 AM
Houston
There is a little knpwn GM service bulletin on how to properly do this. The integrated controller has to be disabled a certain way apparently. Ancira in Boerne, TX did ours. They are a car dealer and RV dealer on same property. The service manager there knew exactly what to do, whereas none of the Houston dealers would touch it.
08-25-2017, 04:52 AM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Do some searching on Air Forums. I feel like I've seen some other threads on the subject. I think the solution is to put a standard RV brake magnet in the system to fool the brake controller. I know that sounds a little odd but there are several people doing this if my memory is correct.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
08-25-2017, 06:43 PM
2009 27' FB Classic
Southlake
I'll dig a little deeper. Thanks for the insight.
08-25-2017, 08:21 PM
2009 27' FB Classic
Southlake
I did some research and you can indeed wire in some brake magnets inline to correct this error. I ordered 2 pucks from amazon and will try this before moving toward replacing the hydraulic actuator and a module compatible with my ITBC.
Thanks for the suggestions everyone!!
08-25-2017, 10:14 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Airstream recommends the "DirecLink" brake controller for disc brakes. I have one for 4 years and am quite pleased with the features.
guskmg
08-26-2017, 05:59 AM
2009 27' FB Classic
Southlake
guskmg
Guskmg, I checked out Direclink's website and I'm still a little confused on their products.
Do you have the DirecLink controller or the ActuLink actuator? or both?
It seems like a well thought-out product but, the information on their website is a little confusing. I guess a call to them sometime should clear many questions.
Thanks!
