Old 08-15-2005, 12:06 PM   #1
JeepinAudiophile's Avatar
1968 24' Tradewind
Fort Myers , Florida
Images: 66
Send a message via AIM to JeepinAudiophile Send a message via Yahoo to JeepinAudiophile
GM Gauge that will tell you EVERYTHING
There's a gauge for GM vehicles that ties into the OBD system and will tell you just about everything going on with your vehicle on one gauge.
Some examples of display parameters are: Intake air temp
Coolant temp
Transmission temp
Engine RPM
MAF lb/min
MAF freq
Manifold PSI
Throttle percent
Throttle volts
Miles per hour
Knock retard
Ignition advance
Fuel trims, short and long, right and left
02 Voltage, right and left
Run time in minuets
Battery volts
IAC position
Fuel injector pulse width right and left
Engine load
Oil pressure
* The actual number of available parameters will vary depending on the
manufacturer's specifications for that vehicle.
I found this gauge on a forum I have been using, you can read more info, call or order it from here... http://advanced.westersales.com/#Interceptor%20Gauges
Tow Rig: 2005 GMC Sierra Denali AWD, 6.0L HO- LOTS OF UPGRADES to help Towing (and Fun)
Trailer: 1968 Tradewind 24', Land Yacht trim (Shell-Off Rebuild and upgrades)
***Missing from my life***
WBCCI # 13657
++Take a look at my restoration photo album++
http://picasaweb.google.com/ChadsAirstream
JeepinAudiophile is offline   Reply With Quote
Old 08-15-2005, 02:38 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
check out www.obd2.com and check out their palm based unit compatible with all OBD2 systems.
Black water indicator gauge not working? Ron C Waste Systems, Tanks & Totes 26 06-06-2005 12:35 PM
Temp Gauge thenewkid64 Mechanics Corner - Engines, Transmission & More... 12 09-27-2003 07:43 AM
Temperature Gauge cookieduster1 Mechanics Corner - Engines, Transmission & More... 5 04-26-2003 06:50 PM
Propane tank gauge Jim Miller LP Gas, Piping, Tanks & Regulators 6 04-09-2003 04:25 PM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
