Old 01-29-2008, 03:04 AM   #1
JLD1942
Profile:  Currently Looking...
seattle , Washington
Gear Vendors
I pull a 31' sovereign with a 1986, 6.9, F250 ford diesel. Another list member suggested I add Gear Vendors to the vehicle. He suggested it would be more cost effective than buying a newer vehicle like a 1999 Suburban since the truck has a rebuild engine and is in good shape. I live in the Seattle area. Where would be a good place to have the work done and does anyone know how much it should cost if I have it done locally. I also have a friend who works on the family cars quite often, but is not an expert in diesel. He is an auto mechanic. Does it take a transmission expert to do this work. If he can do it, what would be the cost of the parts alone? Thanks. Joan
JLD1942 is offline   Reply With Quote
Old 01-29-2008, 06:44 AM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  Bay Area , California
Strangely enough, it was me that suggested it...
There are several threads in the motorhome areas (mechanic's corner) where the process is documented. The overdrive units are not diesel-specific, so your family mechanic can probably do a lot of the work, but a driveline specialist may be a better choice.
Here is a link to GV's website. Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
They are also good at helping over-the-phone to get the bugs straightened out.
Old 01-29-2008, 11:42 AM   #3
Kajtek1
Kajtek1's Avatar
Profile:  1965 22' Safari
Orinda , California
You are not saying why you want the gear vendor? Since you are talking about towing, it is definitely not for fuel economy. Do you have a problem with low speed torque?
Gear vendors cost several thousand dollars and they will not bring much resale value to the truck.
The 6.9 l diesel is not having the best reviews to start with.
Kajtek1 is offline   Reply With Quote
Old 01-29-2008, 03:59 PM   #4
bobchevy89
bobchevy89's Avatar
Profile:  Inverness , Florida
you should look up gear vendors and check out what the do.it gives you a extra gear that comes in handy when climbing hills towing a camper.read the G V article and you will learn something.
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 01-29-2008, 05:55 PM   #5
overlander63
Rivet Masher
Resale value on a 20 year old truck is not part of the equation, improving uphill towing and towing speed on flat ground is, along with keeping a vehicle they have had many miles and years of experience with.
The 20% underdrive will help the truck to tow the trailer in a higher transmission gear uphill, without overheating, and the 20% overdrive will allow for faster running on the flat ground. A 6.9 with a C6 automatic, and 4.10 rear axle, is not set up for a blistering top end.
Also, the direct descendent of the 6.9, the 7.3 Powerstroke, has millions of users driving tens of millions of miles, and an excellent performance record. The 6.9 also was miles ahead of its other light truck competition in its time.
Old 01-29-2008, 06:26 PM   #6
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
And what reviews are those? It was a bit under powered, but not surprising for a non turbo engine. And it is the same base engine that became the 7.3 PSD probably one of the best light diesel truck engines ever built.
Aaron
WBCCI #2449 AIR #2495
Gear Vendors Finally Coming! noiva Mechanics Corner - Engines, Transmission & More... 173 11-13-2006 10:21 AM
Gear Vendors Success/Advice noiva Mechanics Corner - Engines, Transmission & More... 2 12-23-2005 02:16 PM
GEAR VENDORS overdrive, same as units IPM Mechanics Corner - Engines, Transmission & More... 12 07-02-2004 10:13 PM
Gear Vendors rdm Airstream Motorhome Forums 10 03-15-2003 05:21 PM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 09:00 AM
