Old 04-19-2004, 07:06 AM   #1
RVNUTTY's Avatar
1973 25' Tradewind
Leavenworth , Kansas
Send a message via Yahoo to RVNUTTY
gear ratios
How can I tell what the gear ratio on a vehicle is? I'm shopping for a van with the 3.73 or 4.10 gear ratio that I see is recommended by many...but every time I ask a salesperson what the gear ratio is they give me a blank stare! Be specific, about all I know is where the engine is (sometimes). thanks
RVNUTTY is offline   Reply With Quote
Old 04-19-2004, 07:11 AM   #2
Images: 59
RVnuttie,
If you ask them about their what size 'rear end' they have, and they look over their shoulder, you should walk out!
Old 04-19-2004, 08:13 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Count turns
A 3.73 gear ratio, for example, means the driveshaft spins 3.73 times for every one turn of the rear wheels. Hopefully, someone will correct me if I am wrong, but I believe you can chock the front wheels, jack up one rear wheel, put the vehicle in neutral (motor is off), mark the suspended wheel, turn the driveshaft by hand one or more times, and count the number of revolutions the suspended wheel made. Then simply recall your high school algebra for the answer.
I would give more detail, but am dancing on the edge of my experience base as it is...
Old 04-19-2004, 08:27 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
If its a new vehicle, I believe that information is printed on the "Monroni" sticker. (with all the options, equipment, and the MSRP"). It should also be printed on a tag somewhere on the vehicle. its usually stamped on a metal plate on the rear axle, but also printed on a tag under the hood.
sales people are so clueless.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-19-2004, 08:42 AM   #5
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
Smile
i have ask that question also. but my sales person said check inside the glove compartment and there is a list of options. three digit codes so you need a book or a cheat sheet to decode. the parts department can help in that effort they can translate. or if you looking for only one option ask an then look for it. for gm products don't know about brand x.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 04-19-2004, 11:46 AM   #6
Over59's Avatar
Putnam , Connecticut
Images: 37
I had to push on my dealer guy to find and look up the code for my 96 gmc. It's in the glove box and coded. It took him awhile to find the decoder. These sales guys only want to sell you what they have and most aren't at all into the mechanicals. Find a place that sells alot of trucks and talk to the truck guy or order a nice new one.
Over59 is offline   Reply With Quote
Old 04-19-2004, 12:27 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Decoder's available online
Run a google search for the brand you are looking for, use the brand and the word "decoder". A lot of good information can be found that way. I always run the VIN's before I buy a used vehicle...it has kept me from getting burned more than once. BTW I would reccomend a 3.73 or a 4.10 limited slip rear end.
Aaron
WBCCI #XXXX AIR #2495
Old 04-19-2004, 02:19 PM   #8
jjonesnc's Avatar
Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
Yes thats the old school way of doing it. I have seen some that the ratio was stamped on the Differental cover. the a cretain number on the VIN is the ratio of the rear end. the dealer "should" be able to look that up on the ALLDATA or what ever program they use if you call a dealer with the vin. Some parts houses have this info also if you provide them with the VIN
jjonesnc is offline   Reply With Quote
Old 04-19-2004, 05:23 PM   #9
RVNUTTY's Avatar
1973 25' Tradewind
Thanks for the replies, I see now why they give me a blank stare. I did research the vin number...but apparently on a gmc 1986 van...it does not give that type of information. (ratios) Next I'll have to get the flashlight and a scraper and go look underneath layers of gunk. Thanks for trying though...I guess it's not so easy to figure out on an older vehicle after all.
Old 04-19-2004, 08:11 PM   #10
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
gear ratios
Greetings RVNUTTY!
I haven't run across any direct links to information in the GM VIN to identify much more than series and original engine especially and the early to mid 80s models. On all three of my GMC/Chevrolet tow vehicles ('83 GMC G20 Vandura/'95 K1500 Z71 Pickup/'99 GMC K2500 Suburban) there was(is) a placard on the glovebox door listing all of the factory option codes including the codes for differential ratios. A knowledgeable GM service advisor should be able to decode this information for you - - I know that the service advisor at my local GM garage was able to provide the axle ratio from this information when I was considering a used GM vehicle earlier this year.
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
Old 04-19-2004, 08:40 PM   #11
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Codes
For GM products look for the following RPO codes in the glovebox :
GU4 for 3.08 rear end
GU5 for 3.23
GU6 for 3.42
GT4 for 3.73
GT5 for 4.10
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-04-2004, 03:38 PM   #12
Most older rear ends have a tag on the rear cover(under a bolt) that will tell you the ratio. Works unless: 1.tag removed, 2. gear change. You can figure it out by the "tire/drive shaft" as stated earler, or the other choice , pull rear cover, count teeth , and do the math . But that will cost you the price of a gasket and the grease.
On my 99' suburban ,the dealership was able to just run the Vin#.
Good luck. Toby
Toby is offline   Reply With Quote
Running gear balance? Cedars Axles 79 06-10-2004 02:57 PM
tow vehicle gear ratio redlion7 On The Road... 16 03-07-2004 06:25 PM
My Suzuki Samurai dropped into gear while being towed williamhenshall General Motorhome Topics 16 04-07-2003 09:30 AM
Antenna Drive Gear CO_Don Audio, Video & TV 0 02-06-2003 04:45 PM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 08:00 AM
