Old 02-15-2006, 03:40 PM   #1
Grand Rapids , Michigan
Gear ratio for my GM TV
Does anyone know how I can find out what my gear ratio is on my TV? I checked the owner's manual- no luck. Someone told me to look inside the glove box for a sticker. THhere's one there alright, with LOTS of numbers but nothing resembling a gear ratio.
I've got a 2002 Yukon Denali.
Thanks!
Double D is offline   Reply With Quote
Old 02-15-2006, 03:43 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
mine is on a tag under the hood. might check there, as well.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 02-15-2006, 03:46 PM   #3
HEy, thanks. I'll look!
Old 02-15-2006, 04:39 PM   #4
JimGolden's Avatar
1977 31' Excella 500
If you can't find a tag telling you, a surefire way is to take it to a level parking lot, put it in neutral and turn it off. Take a couple of your stronger friends with you. Crawl under it. Put a grease pencil mark on the drive shaft, and also put one on the inside side wall of one of the rear tires. Have your big friends slowly push it forward while you crawl along with it. Count the revolutions of the driveshaft while you make one complete turn of the rear tire.
For example: You mark the rear tire at the 6 o'clock position, straight up from the ground, dead center at the bottom. You then mark the driveshaft. As you skinny along under the truck while your buddies push it by hand, count how many turns the drive shaft makes until your tire mark is back in the same place it started. In our example, at the bottom. If the driveshaft turned about three and 3/4 turns, you've got a 3.73. If it turned a little over four turns, you've got a 4.11, and so on.
You can't just jack the wheels up because the differential slip will allow the wheel to rotate independantly of the driveshaft. Unless you've got positraction, that is.
Now, if you can somehow see the driveshaft without getting under the truck, all the better. You could also have someone you really really trust pull the truck forward one revolution with you under it counting, but I wouldn't recommend that. If it's got posi's, then you can just jack it up and turn the driveshaft by hand until the wheel makes one turn. But if you can determine if it's got positraction, you can probably find the ratio
My truck has it printed on a label inside the glove compartment. You might look there too.
Good luck,
- Jim
JimGolden is offline   Reply With Quote
Old 02-15-2006, 05:25 PM   #5
1985 Avion 34v
Partsman's Avatar
Fountain Inn , South Carolina
Axle Ratio
You will probably not find a ratio number in the glove box, but all those numbers and letters mean something. So, go to this site and look through all these numbers until you find one that matches a number on you tag. This is a list of RPO's, that is, regular production numbers. It may look confusing but if you print out the page and take it out to your favorite TV you should be able to figure it out for yourself.
http://www.drivetrain.com/GMtrkratio_posidata.html
Have fun and you will be learning something new about your vehicle too!
Chris
Partsman is offline   Reply With Quote
Old 02-15-2006, 05:48 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
You can also take you VIN number to your friendly GM parts counter and ask for a Build Sheet Print out. It will tell you everything that came on the vehicle from the factory including the rear end ratio...assuming a PO didn't change it
Aaron
WBCCI #XXXX AIR #2495
Old 02-15-2006, 06:46 PM   #7
Good luck,
Wow, very interesting. Sounds like something maybe I could get my daughter's boyfriend to do! Thanks!
Old 02-15-2006, 06:46 PM   #8
Chris
Thanks, will take a look!
Old 02-15-2006, 06:47 PM   #9
Aaron
This sounds the best yet! Thanks!
Old 02-15-2006, 07:00 PM   #10
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
Don't know if GM is the same but on Ford there is a metal tag attached to the differential cover. It will tell the ratio and if it is a limited slip or not. Example would be 4.10 L meaning 4.10 ratio with limited slip.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 02-15-2006, 07:51 PM   #11
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Double D, There should be a steel tag on the rear end housing where the rear cover bolts to the housing if not on the back check the the front. you will find the info you need, if it is missing just jack up one side of the rear wheels and mark your drive shaft and rotate jacked up rear wheel and count the revelations of drive shaft to one full revelation of wheel.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-15-2006, 08:38 PM   #12
Cool, if we don't get the 1 to 4 of snow and 1/2 inch of ice predicted tonight, maybe I'll crawl under there a take a peek! Thanks!
Old 02-15-2006, 08:39 PM   #13
Thanks. Can you explain limited slip?
Old 02-15-2006, 09:10 PM   #14
basecamp's Avatar
1996 30' Excella
Bowmanville , Ontario
check the glove box, this is where GM lists the option content. Unless this truck was a special order I doubt that it has a 4.10, more likely a 3.73(GT4)
Hensley Hitch, Jordan controller
basecamp is offline   Reply With Quote
Rear End Gear ratio Bfrank Mechanics Corner - Engines, Transmission & More... 3 05-15-2008 01:08 PM
Gear Ratio Change? SteveH Tow Vehicles 27 03-28-2008 07:07 AM
Gear Ratio ??? slow-canoe Argosy Motorhomes 2 07-24-2007 10:09 AM
Gear Ratio ? slow-canoe Mechanics Corner - Engines, Transmission & More... 9 04-10-2006 08:29 PM
tow vehicle gear ratio redlion7 On The Road... 16 03-07-2004 06:25 PM
