Old 02-15-2006, 09:22 PM   #15
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
How Dose Limited Slip Work
Clutch packs inside the differential create additional resistance. This resistance is always present. It is called preload. So, whenever one side wants to start rotating faster than the other, this resistance (preload), in addition to the traction present at the wheel has to be overcome before a tire can spin.
Traction and preload have to be high enough to keep tires from spinning but low enough to still allow tires to rotate at different speeds in a turn. Since the preload has to be kept low enough to allow safe cornering the slowing effect on wheels that want to spin is marginal. It works in easy off-road conditions and on mildly slippery roads. For serious off-road use and very slippery roads (snow, ice) limited slip is not powerful enough.
Remember, it limits slip but it does not prevent it completely. Only a differential lock can do that.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-15-2006, 09:31 PM   #16
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Look in your glove box.
GT4 equals 3.73
GT5 equals 4.10
You will probably find you have a GT4. If you have a GT5, you must be living right. Praise the Lord.
Alumaholic is offline   Reply With Quote
Old 02-15-2006, 09:38 PM   #17
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Double D I got that info off a site, but to make it simple limited slip allows the inside drive wheel to slow down when making a corner while the outside wheel will turn faster, this makes less bind on the carrior in the rear end.
Old 02-16-2006, 07:30 PM   #18
Grand Rapids , Michigan
GT4 equals 3.73
GT5 equals 4.10
I will look at all those numbers again and see what I can find. Thanks for your help!
Double D is offline   Reply With Quote
Old 02-16-2006, 07:32 PM   #19
Whew. I was a bit lost on the first one. Makes sense. Thanks again!
Old 02-16-2006, 07:34 PM   #20
Originally Posted by basecamp
check the glove box, this is where GM lists the option content. Unless this truck was a special order I doubt that it has a 4.10, more likely a 3.73(GT4)
Thanks, Basecamp. Will check again!
Old 02-16-2006, 07:41 PM   #21
Hey, everyone! It's a GT4! 3.73... Thanks all!
Rear End Gear ratio Bfrank Mechanics Corner - Engines, Transmission & More... 3 05-15-2008 01:08 PM
Gear Ratio Change? SteveH Tow Vehicles 27 03-28-2008 07:07 AM
Gear Ratio ??? slow-canoe Argosy Motorhomes 2 07-24-2007 10:09 AM
Gear Ratio ? slow-canoe Mechanics Corner - Engines, Transmission & More... 9 04-10-2006 08:29 PM
tow vehicle gear ratio redlion7 On The Road... 16 03-07-2004 06:25 PM
