Old 01-08-2014, 01:31 PM   #1
East Tawas , Michigan
Gear change
2003 Chevy 1500 Express Van,5.3L V8.,tow package. Am I wasting money on changing the rear end gearing to increase towing capability ? I think that I am at #6800 now, what can I gain ?
baylito99 is offline   Reply With Quote
Old 01-08-2014, 01:56 PM   #2
Denis4x4's Avatar
Durango , Colorado
First off, what is your current gearing? If you go to a lower gear (higher numerically), it may very we'll screw up the computer controlled functions like rich/lean and spark advance. I'd check with a performance oriented shop to see what your options are. If they say it's feasible, spend a couple of extra bucks to get some sort of posi-traction set up.
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 01-08-2014, 03:23 PM   #3
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
gear
Changing your gear ratio will not gain towing capacity. If you change your ratio it will change the torque applied to the rear wheels which will give you more power pulling hills and may even increase your gas milage slightly. cost will probably be in the $1000 to $1500 dollar range.Should be able to reflash comp. to take care of any issues with the gear change.
panheaddale is offline   Reply With Quote
Old 01-08-2014, 03:54 PM   #4
2005 19' Safari
GLENDALE , AZ
Years ago, I had an old Chevy van and switched from regular 75-series tires to 60-series low profile tires, which is similar to changing to a higher numerical gear ratio in the rear-end. This resulted in constant, high engine RPMs, horrible fuel economy and engine overheating.
Your van is much newer, but you should be aware that changing rear-ends may cause unexpected results; and you'll have a lot more work to change the gears back if you aren't satisfied, compared to just switching back to the old tires.
