Old 08-20-2013, 11:02 PM   #1
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Gcwr
A general question, does anyone know how a vehicle's GCWR is typically arrived at?
Steve; also known as Mr UK Toad
"You can't tow that with that!"
https://sites.google.com/view/towedhaul/home
MrUKToad is offline   Reply With Quote
Old 08-21-2013, 05:17 AM   #2
"Cloudsplitter"
Thumbs up
Dartboard, GM
Dice, Chrysler
Wheel of fortune, Ford
Everything else, London Ont.
Old 08-21-2013, 05:48 AM   #3
MrUKToad's Avatar
Chatham , Ontario
Originally Posted by ROBERT CROSS View Post
Dartboard, GM
Dice, Chrysler
Really? That scientific, eh?
Who'd a thunk it?
Old 08-21-2013, 07:09 AM   #4
dznf0g's Avatar
Oswego , Illinois
CGWR is a number arrived at by the strength/durability of the weakest link in the longitudinal force affected components. Such things as all the driveline components, brakes, frame... Usually the vertical force components are not involved (like axle housing, springs, front suspension, etc. That is why they have separate specs, like rgawr, fgawr, payload, Gvwr...these are vertical load affected components. There may me some overlap of components which limit GCWR and one or more of the others...like rear springs which ( on a rear drive vehicle) sustain both kinds of loads. That's the elementary version of the answer.
Cooling system can often be the GCWR limiting factor as well
-Rich-
Old 08-21-2013, 08:29 AM   #5
MrUKToad's Avatar
Chatham , Ontario
OK, but longitudinal forces are variable depending on what you're towing. Trailers of identical weight will exert vastly different longitudinal forces dependent on the shape and size of the frontal area that trailer presents to the oncoming air. In that case, surely to express the GCWR as a simple measurement in pounds is, at best, misleading.
Similarly, if you modify (improve!) something like the transmission cooling, doesn't that blow the manufacturer's stated GCWR out of the water?
I'm not disagreeing with you, by the way Rich, just exploring the issue.
Old 08-21-2013, 10:30 AM   #6
dznf0g's Avatar
Oswego , Illinois
All those forces are taken into account when arriving at the Max rating. A mod MAY change things....but even I don't have access to what component(s) is/are the limiting factor. Maybe stock trans cooling could support 5000#s more than stated max, but frame tips can't take any more calculated forces than stated, as a hypothetical example.
If trans temps are high, I put on a cooler....not to increase GCWR.
-Rich-
Old 08-21-2013, 11:03 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Each manufacturer looks at the competitors numbers and adds a couple hundred pounds. Probably the last ad writer wins
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 08-21-2013, 11:39 AM   #8
MrUKToad's Avatar
Chatham , Ontario
This where I was going with this.
I liked (the other) Rick's mention of longitudinal forces as it makes sense to a degree, especially when considering individual components, but those forces are so variable that it would be impossible to put any realistic and finite limit on it in terms of the weight of a trailer. It would be simpler for the manufacturer to simply not quote a GCWR at all, which is in fact what Toyota have done with my vehicle, at least not on the door post. The manual says that the GCWR is the GVWR plus the weight of the trailer, by which I assume they mean the maximum weight permissible or the tow rating. On that basis, to use a tow rating figure in the calculation of the GCWR renders it entirely meaningless as the tow rating is a figure arrived at by marketing departments and not engineers, which is what you've said in your post Rick D.
I only used the example of improving the transmission cooling to show that that these things are variable, not expressly to improve the GCWR.
All this came about when a guy at a campground (in Canada) became quite agitated with me and told me that I should never tow my trailer in the US as the combination of TV and trailer surely exceeded the GCWR. The police would impound both vehicle and trailer at the first opportunity, apparently. This was patent nonsense as we'd just arrived back from a week in the US and have travelled in the US quite a bit and never so much as raised an eyebrow. Quite why the police would be any more interested in the US than in Canada was another point, but he didn't want to listen. Anyway, it had me thinking about the GCWR and how enforceable, if at all, it was. Given that it seems to incorporate the unprovable tow rating, the answer has to be that it's nothing more than a marketing exercise.
Axle and tire ratings are another matter of course; directly measurable and finite.
Old 08-21-2013, 11:59 AM   #9
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
I pull trailers commercially and their are laws in the US regarding GCWR. 26,000 is the limit to tow without a cdl license. If you exceed 26,000 pounds their are big fines to pay. They fine you for each pound you are over. I do think that anyone pulling a trailer should be held accountable to the same rules a commercial drivers that is what gets me so agitated about Can Am and their setups. I know you Canadians thinks he is the greatest thing since a pocket on a shirt because you get to use whatever tow vehicle you want to and get told that it is ok to pull with it. While the manufacturers GVWR rating might be a somewhat arbitrary number it is not going to be some completely random number pulled out of a hat. The engineering that has gone into vehicles over the years and even today has merit as to what the vehicle is capable of towing SAFELY. While you can easily tow more than the vehicle is rated at doesn't mean it is safe to do. REMEMBER Just because you can pull doesn't mean to can stop it or control it.
panheaddale is offline   Reply With Quote
Old 08-21-2013, 12:00 PM   #10
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Alternatively, they just fabricate the number to suit the vehicle.
As an example, a Toyota Tundra comes with a tow rating of close to 10,000lbs, but the total payload of 1330lbs is actually lower than that of a Toyota Sienna minivan at 1513lbs, but with a published tow rating of 3500lbs.
andreasduess is offline   Reply With Quote
Old 08-21-2013, 12:02 PM   #11
Toronto , Ontario
That's not at all what happens when you consult with CanAm. Turn up with a vehicle that can't safely tow the trailer of your choice and they will tell you immediately.
Old 08-21-2013, 12:20 PM   #12
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Pretty much what panheaddale said.
While I claim no legal expertise, I have about 40 years experience with travel trailers and 10 years of commercial work delivering them.
I have never known any one to be ticketed for exceeding the GCWR of rating of their tow vehicle. Of course if you exceed 80,000 lbs that would be different.
It also irks me that a half blind 100 year old can drive a 40,000 lb motor home , but I can't legally deliver it to him because I don't have a CDL but that is another issue
I too strongly disapprove of the CanAm approach, but I do have a Canadian friend who tows his 34 with a Chevy Minivan and so far both he and the Minivan are still alive.
I have seen dealers park them with a riding lawnmower but it doesn't mean you should go on the road that way..
How the Insurance companies would react to a severe over GCWR is another question. I have heard stories and speculation but have no hard facts
13 Ram 2500 TD
Old 08-21-2013, 12:31 PM   #13
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It looks like manufacturers tow ratings are not believed. SAE came up with standard methodology to do the ratings and manufacturer's lowered (in most if not all cases) their tow ratings. I think the Tundra's went down a few hundred pounds from 10,000. Of course, it has been argued that SAE's engineers are lackies for the manufacturer's.
I'm not about to hire an engineering firm to calculate this for me.
So, my understanding of Gross Combined Weight Rating (GCWR) is what Toyota says, but I say it in simpler form—the total of the Gross Vehicle Weight Rating (GVWR) of the trailer and truck. The word "combined" tells it all. The tow rating is different—it means how heavy a trailer you can tow with a specific truck or SUV or car. There are also ratings for each axle and hitch receivers are rated too. Beef up the frame and hitch receiver of the tow vehicle (and maybe more), and you can increase its ratings. That is what I understand CanAm does and there is nothing unusual about people modifying vehicles just like CanAm does.
I think if US cops were stopping people for being over the GCWR we'd have heard about it on this Forum. No state requires people towing travel trailers to stop at weigh stations to check this and I doubt any state wants to go there. They don't have the money to operate enough weigh stations for commercial trucks as it is.
Gene
Gene
Old 08-21-2013, 12:34 PM   #14
Toronto , Ontario
Borrowed from another poster, BradB, but worth posting here too - a 1987 Airstream brochure:
I wonder what the tow rating on this TV would be, happily married to a 34' triple axle. What I do suspect, strongly, is that my 2008 Honda is superior in any way to the car on the Airstream brochure - payload, engine, brakes.
(I didn't grow up in North America, so I have no idea what car this is. Perhaps somebody else can dig up the numbers)
Old 08-21-2013, 12:38 PM   #15
Master of Universe
Gene's Avatar
Insurance companies do not want to spend a lot of money on checking everything. They seem more interested in your credit rating than anything else (aside from collecting premiums).
So I doubt they are thinking much about GCWR. So long as GCWR doesn't show up as a problem very often, they just figure a few accidents caused by excessive GCWR are far outweighed (pun alert) by all the people without such a problem. And the problem most likely manifests as a tow vehicle that wears out too soon. That is no cost to an insurer.
If there is a lawsuit and a victim's lawyer discovers that GCWR may have contributed, it may come up. I doubt many lawyers even have heard of GCWR and I don't know how you prove excessive GCWR is a direct cause if an accident, but you may be able to prove it is one of several factors.
Gene
Gene
Old 08-21-2013, 12:44 PM   #16
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I don't know about that. I really like my 2012 Accord coupe, but it doesn't have those cool blue arrows that go back around the trailer.
(It's a Chevrolet Impala)
Vaughan
Old 08-21-2013, 12:52 PM   #17
Toronto , Ontario
Awesome. Three gears and 110hp.
Old 08-21-2013, 12:52 PM   #18
DKB_SATX's Avatar
Alamo Heights , Texas
It is a Chevrolet Caprice Classic, '77-'90. Since it's an '87 Airstream brochure, I'd guess it's an '86 or '87. It was never available with larger than a 350 cubic-inch V8 (either gasoline or the AWFUL GM 5.7l diesel). By the mid 80s, you couldn't get the gasoline 350 anymore, just a 305. My old car book tells me that was good for all of 165 horsepower.
EDIT: Oh, and note that it's probably the OLD formula for SAE horsepower, so rated on the current scale it would be even less.
— David
Old 08-21-2013, 12:57 PM   #19
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Gene
At risk of being wrong, I believe I read in a recent (last 6 months) Turbo Diesel Register that the SAE did come up with a set of standards. I also recall it saying that Toyota is the only one following them at this time
13 Ram 2500 TD
Old 08-21-2013, 01:33 PM   #20
Toronto , Ontario
So was Airstream promoting unsafe tow setups in their marketing materials?
Given that there are many voices on this forum who strongly opine that some of today's setups not involving trucks cannot be trusted, despite the fact that these vehicles are stronger and more capable than almost any vehicle available to the average family during the 1980's, this leaves me with two possible conclusions:
a: towing 30 years ago was inherently unsafe and a far riskier activity as it is today. They just didn't know any better and didn't have the technology available to do a better job. As with airbags and seat belt laws, we've moved on.
or
b: towing 30 years ago was inherently safe, the TVs performed fine under most circumstances. Considering the improvements in car design since the mid-80's, towing today is even safer than it was then, even with a family car.
I am not trying to be confrontational with this post, nor am I trying to change anybody's opinion, I am genuinely interested in people's thoughts on this.
