Old 09-12-2006, 01:37 AM   #181
Razorback
razorback's Avatar
2005 30' Classic
Springdale , Arkansas
There seems to be a lot of unanswered questions about whether the ULSD will affect older diesels and if so, how? For some time I have been adding a mixture of Diesel Kleen and Marine 2-cycle oil with TCW3 (burns ashless) to my fillups. I don't know if the diesel needs the extra lube or not, but I thought "What the heck, why not be on the safe side." A small price to pay for extra future miles and some mileage and power benefits now.
I have found that with the additives the mileage is better and I seem to be able to pull hills better without losing as many RPM's. The engine seems to be a little quieter also. So it works for me.
There is a lot more information on the Cummins Forum at this thread:
http://www.cumminsforum.com/forum/sh...t=diesel+kleen
Razorback
Sid and Becky
2005 Classic 30 "Twinkie II"
Hensley Arrow
2008 Bighorn 4X4 Dodge 2500 Cummins
WBCCI Member At Large #2786
Life is not a dress rehearsal, live your dreams!
razorback is offline   Reply With Quote
Old 09-12-2006, 01:44 AM   #182
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Thank you all for the congrats!… hiker…
Jim Clark… the dealer started with a relatively low price…
and I got $3000 factory rebate on top of that.
Minnie’s Mate… cloth seats for me… should wear longer…
…especially with my two dogs.
2air’… thanks for helping me keep this tread focussed…
and encouraging us to think out of the box…
interesting article on hcci… looks like Ford might have one in 5 years...
or you might find one at that next ladies rally!
Cheers,
Bill
Name:	My PSD2.305.jpg
SilverGate is offline   Reply With Quote
Old 09-12-2006, 01:56 AM   #183
_
hi bob and razor back...
well the leaded gas comparison isn't really the same. lead was removed, nothing was used as a replacement. instread the engines were changed (hardened valves) so as not to need lead.
your gasoline is now reformulated regularly...mtbe has been removed and ethanonl inserted....additives change all the time...
on the diesel side the BIG change is fuel was a few years ago when sulfur was reduced from 5000ppm to the current levels...in lsd...
ulsd takes sulfer from approx 150ppm to 5-15ppm...so the change isn't that big this time...
also other lubricants have already been put in the diesel fuel as a substitute for sulfer...
like razor back..i already use a lubricant/cetane booster...i really like stanadyne....
and i'm gonna try a bottle of the motorcraft diesel fuel treatment this week.
cheers
2air'
Old 09-12-2006, 09:59 AM   #184
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
That reminds me - I need to go dump some Marvel Mystery Oil/Service Power Kleen in the tank. Filled it up last night and forgot to add it.
The Cummins doesn't love creeping around town. There are two possible remedies - go run it and haul something, or medicate it.
Both quieten it down nicely.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 09-12-2006, 11:33 AM   #185
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Boy has this thread got off topic since I was last here (cloth/leather seats?)!
To really simplify, let’s keep in mind that big block gassers have MORE CYLINDERS (Ford/Dodge=10, GM=8) than the diesel’s used by the Big 3; Ford/GM=8 cyl, Dodge = 6 cyl. More cylinders= more moving parts. If we are going to make comparisons of gas versus diesels, then small blocks just don’t aren’t in this league.
Unlike gasoline fired engines, diesels lack a butterfly valve (choke) in the inlet system, which closes at idle. This creates parasitic drag on the incoming air, reducing the efficency of gasoline engines at idle.
Diesels also lack an electrical ignition system. The high durability of a diesel engine is also due to its overbuilt nature (see above) as well as the diesel's combustion cycle, which creates less-violent changes in pressure when compared to a spark-ignition engine, a benefit that is magnified by the lower rotating speeds in diesels. All internal combustion engines must have a means of ignition to promote combustion. Most engines use either an electrical or a compression heating ignition system. Electrical ignition systems generally rely on a lead-acid battery and an induction coil to provide a high voltage electrical spark to ignite the air-fuel mix in the engine's cylinders. Compression heating ignition systems, such as diesel engines and HCCI engines, rely on the heat created in the air by compression in the engine's cylinders to ignite the fuel.
On average, when comparing the engines for sale today, in car lots across America, diesel engines offer greater efficiency, and produce more power, than gas engines. I don’t really favor one technology over the other, I drive both. I love the small block 350 in my daily driver-what a great engine. But there is no question I would rather tow with my diesel.
When people start to discuss (defend/compare) towing with small block V8 gas engines versus towing with a diesel, it really is ridiculous. I have towed with both. As someone said earlier “thou doth protest to loudly” or rather “those that don’t know just haven’t driven a diesel lately.” I am not saying they are for everyone, and many don’t need/ can’t justify buying diesel, especially if you are not towing a lot of weight or long distance. But I suspect, and the many conversations/trip reports on this board confirm, that many here do tow a lot. And like their diesels.
BTW Silvergate, good choice on the F250 PS-nice truck. Your decision has answered the original question
Bill
BillTex is offline   Reply With Quote
Old 09-12-2006, 12:43 PM   #186
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
It seems more civil when we talk about leather vs. cloth upholstry rather than number of moving parts. I vote we stick to upholstry options since silvergate has made his decision.
Family of Disney Fanatics
WBCCI# 4821
Old 09-12-2006, 01:00 PM   #187
1 Rivet Short
1989 25' Excella
Sounds good-some of that was getting ridiculous.
My heated leather seats aren't cold in the winter at all!
Old 09-12-2006, 01:16 PM   #188
1960 22' Safari
in the wilderness , The great Mojave Desert
Cheers,
Bill
WOW!! What a beautifull truck! Thats gotta be one the best looking trucks I've ever seen!!! You are a man of style and taste. Clearly you would would tie in the "tape measure" contest and all women will find you attractive.
Can you tell that my new truck and your new truck look alike?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 09-12-2006, 10:28 PM   #189
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I'm stuck with leather seats in my Navigator, for now anyway. I preferred the very comfortable cloth seats that my 1996 Ford Explorer 2 dr Sport had, but the Explorer's 4.0 L push rod engine and vehicles short wheel base and lack of tow capacity just had to go. After we bought the Navigator the Explorer had to find a new home. Even with heated and cooled seats, [in the Lincoln] The Explorer's cloth seats were much better.
My vote is for cloth!
Old 09-12-2006, 11:18 PM   #190
Salem , Oregon
Images: 18
Apples and Oranges
Bill
Hi, I started with a V-6 2 cycle Detroit Diesel; Then a Ferrari V-12 4 cycle 48 valve, dual overhead cam gas engine. and the count was on!
You win, Bill Tex, The gas engine has a lot more parts.
By the way; the Ferrari had leather seats.
Old 09-13-2006, 08:21 AM   #191
2006 30' Safari
Orlando , Florida
My 1995 F-150 Extended Cab has the manual 40-20-40 cloth front seats with the inflatable lumbar support. That configuration is essentially two armless captain's chairs with a center seat section that folds down to make a very wide arm rest with two cup holders and a covered storage compartment. Those are comfortable seats. With the extended cab I can get just the right angle and could actually lean back and support my head on the high-back seats. With the fold down bench seat in the extended portion of the cab you can seat 6...just not very comfortably. When the kids road in booster seats, the back seats were adequate. When my oldest outgrew his booster seat, the back seat just wasn't adequate any more. I still enjoy driving that truck and I hate to part with it.
My 2005 F-250 Crew Cab has power leather captain's chairs with a mechanical lumbar support. No where near as comfortable as the F-150's. The way the seats are arched there is no way to lean back and support your head. Even with the 6-way power adjustments I can't get it so I can. This leads to neck fatigue. It's a bummer on long trips. However, I have grown to enjoy driving this new truck as much as the old truck with the exception of lack of neck support on long trips. I'm sure I will get used to that part in time.
I wish Ford had kept the seat design they had in the '95's. Even my wife admits those seats are more comfortable than her Expedition's.
WBCCI# 4821
Old 09-13-2006, 08:41 AM   #192
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
The real question is how much gas mileage dose the Ferrari get pulling your Airstream 5 miles an hour above the posted speed limit.
I am not even go to bring up the tape measure issue.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 09-13-2006, 08:47 AM   #193
Jim Clark's Avatar
I am sure the 2006 PSD I test drove had the 40-20-40 seat in a crew cab cloth. I remember because I have captians chairs and I keep my brake controller in my center console and thought how much less junk I would collect. It may not be available in leather.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 09-13-2006, 09:45 AM   #194
2006 30' Safari
Orlando , Florida
It seems to me they could have just stuck arms on the 40-20-40's captain chairs and used them instead of coming up with a new design for the regular captain's chairs. You'd think they could leave well enough alone.
WBCCI# 4821
Old 09-13-2006, 09:48 AM   #195
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Then they wouldn't be able to advertise it as "All New" or "New and Impoved"...wouldn't want to violate the truth in adverstising laws would we
BTW I agree most of the time the New and Improved stuff is no improvement at all.
Aaron
WBCCI #XXXX AIR #2495
Old 09-13-2006, 10:45 AM   #196
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
Here's a quick report on our DMax. Just returned from a 900 mile trip with the AS, all of which was through Wyoming and Colorado mountains. With 15,000 on the clock, averaged 14 mpg overall. Pulling mountain passes can be summed up with maintaining a steady 50 mph in overdrive up Rabbit Ears pass. It is an 11 mile climb at 7 per cent grade east out of Steamboat Springs.
Antique Pedaler
'10 Flying Cloud FB
'05 GMC Pickup,
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 09-13-2006, 11:53 AM   #197
2006 30' Safari
Orlando , Florida
Which AS were you pulling?
WBCCI# 4821
Old 09-14-2006, 12:25 AM   #198
Salem , Oregon
Images: 18
Seats
Hi, I can't figuer out these seats either. Like I said before, I work at a Ford dealer and road test cars and trucks vertually every day. It seems to me that Ford keeps changeing the seats and or seat positions. Trying to get more rear leg room they don't let the seat go back as far as it used to go. Also, some seats don't go down as low as they used to. This does not make sense to me since people are getting taller and larger each generation. Some cars [or trucks] the seats and head rests fit me pretty good and other's just don't feel comfortable no matter how I adjust them. I like my Lincoln, but it would be almost perfect if it had the same seats that my 1996 Explorer had.
Old 09-14-2006, 09:46 AM   #199
2006 30' Safari
Orlando , Florida
When I saw the interior of the Super Chief concept truck I thought it was really cool and quiet handsome but my first thought was that those seats would ride like a truck bench seat out of the '70's. My second thought was I'd love to own one but first order of business would be after market seats up front. Maybe Raccarro's.
WBCCI# 4821
Old 09-15-2006, 01:04 AM   #200
Salem , Oregon
Images: 18
Hi, Minnies Mate. You had to mention Ricarro's. You must be much younger than me. Last time I sat down inside a Mustang with Ricarro's It was very comfortable, But when it was time to get out of the car, that was a different story. Very difficult to climb out of.
Which tow vehicle for a 19' Bambi? Jay_Iski Tow Vehicles 50 02-21-2017 08:12 AM
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 11:28 PM
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 10:31 AM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 03:37 AM
