Old 02-21-2012, 02:35 PM   #127
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Originally Posted by timmaah View Post
Oh man this is going to be a tough choice.
Looked at a few Tundras this morning as well as a 2008 F250 6.4 Diesel. Our test drive route included dirt roads and interstate.
We liked the Tundra much more. I fit better in the seats and bumpy roads were much more pleasant. I was surprised at how both steered so well and didn't feel like I was driving a big truck. Had to push the brakes on both, but I'm used to a Subaru Impreza.
The Tundra was at the low end of our price range. $21k.. While the F250 was $30k.
You get what you pay for. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 02-21-2012, 02:55 PM   #128
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
^^^^^ This ^^^^
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 02-21-2012, 02:57 PM   #129
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
The mpg on the ford 6.4 are historically awful. Hope that helps.
Shane
TAC ID TX-1432
Old 02-21-2012, 04:23 PM   #130
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
My experience with the Tundra almost exactly matches TouringDan's on post #123. My Tundra is an '09 Double Cab with 5.7 and 60k miles. I purchased it used with 53k and within 3 months took it on a month long vacation pulling our 25' Excella about 5000 miles. It was a breeze! Easy easy pull with lots of power, brakes, and payload to spare. We carry a Honda 2000i Generator and fuel under an ARE tonneau. We could easily pull 6 more feet of trailer. Before this '09 Tundra I had an '02 Tundra and used it to pull my Excella about 105,000 miles over 9 years. Not a single problem with that Tundra other than normal brakes every 60,000 miles and a leaky axle seal because I used some synthetic rear end fluid I wasn't supposed to use. I replaced the seal and problem solved. I sold it with 177k miles on it last September. The buyer was so glad to find it he called me 10 times in an hour after seeing it parked outside a Home Depot with a sign in the back window while I was inside shopping. The new Tundra is not as agile as the older one, but I can adapt.
So Long!
Bob Thompson is offline   Reply With Quote
Old 02-21-2012, 05:09 PM   #131
JimGolden's Avatar
1977 31' Excella 500
Cummins Power!
Allow me to muddy the waters a bit further
After my Excursion blew up, I traded it and bought a brand new Dodge Ram 2500 4-door long bed 4x4 with the Cummins turbo diesel.
My dad's best friend has owned a Cummins powered Ram since they first came out in '89. He routinely puts 300,000 miles on them and trades them off, still running great, on a new one about every 8-10 years.
My dad bought his '99 new in '99 and has had no problems of any kind with it.
OK, so I buy mine. I love it! Mine is what they call the 2004 1/2. Mid year they offered a heavier automatic tranny for it. Mine is rated 305hp and 555 ft-lbs of torque. I pull a 34' Avion triple axle that is heavier than an Airstream of the same year but a bit lighter than the last 34' Airstreams. Anyway, it grosses about 5 tons.
Running 70-75mph on the interstate I get about 12.5 mpg towing. It would probably do a lot better running 60mph, but I don't drive 60mph on I-95....as everybody else is running 80.... I get 19mpg running empty with it at 75mph, and I have gotten as high as 22mpg with it running 55-60 empty. My dad's buddy's truck is just like mine, only he got a 6-speed manual and his is a 2wd....he gets 24mpg running empty.
My buddy has a new Tundra like mentioned above with the 381hp. It's a nice truck, but torque wins the race and the Ram has gobs of it. I pulled my 34 footer over the Great Smokey Mountains and never hit a hill I could not accelerate up.
Admittedly, it is hard to find a used one with less than a million miles on it for a reasonable price. I myself wouldn't consider selling mine for less than $30K, and I don't care what Kelly or NADA says. I paid a lot more than that for mine, I am religious about the maintenance, and she looks like a brand new one seven years later.
Anyway, you'll be hard pressed to beat a Cummins diesel. My Ram is a big hulking beat with tons of power, and it gets 30% better economy than my old half ton Suburban did. Diesels rock, and Cummins diesels are like Heavy Metal if the rest are just rock and roll.
The only downside I've seen to the Cummins is the cost of entry. If you can get a deal on one, you'll not be displeased.
However, to muddy things even a bit further....when you say fulltiming, how often do you plan to move? In other words, if you'll set up in one spot for 6 months to a year and then move, you could just get a Miata and hire a guy to pull the trailer. Seriously....even Nicky and Tacey (Desi and Lucy....aka from The Long Long Trailer) were advised by the New Moon salesman to hire a pro to pull the trailer from CA to CO for them. But, if you plan to move fairly frequently, then you'll need a bigger rig than a Miata
Best of luck!
- Jim
JimGolden is offline   Reply With Quote
Old 02-21-2012, 06:05 PM   #132
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
I would echo Shane's comments and my earlier comments about mileage on the F250. I have a 2010 F250 Crew Cab short bed with 6.4L diesel, and the mileage solo on the highway routinely runs 14-16. Towing my Sport 22 (4500 lbs wet and loaded) drops me to 11, and my boat (26' on a double axle trailer, 6500 lbs. wet) drops me to about 9.
Taking into consideration that diesel fuel is also considerably higher in cost (15% in our neck of the woods) and that oil changes are substantially more expensive, you won't want to buy the diesel for cost savings.
However, in spite of bad mileage, the engine will pull a house. The ride is very comfortable and arguably much better than my prior F150.
Hibby
Hibby is offline   Reply With Quote
Old 02-21-2012, 06:10 PM   #133
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The Miata is a better idea than a 4 x 4 four door long bed Cummins diesel, unless you're pulling three 25' Airstreams. Or have some other use for it. At least it would be for us. Can't imagine having that as a daily driver when full timing.
No problem here with those who like to drive them, but a tow vehicle for a 25' ?
doug k
Old 02-21-2012, 06:43 PM   #134
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
doug k
I have a 2011 6.7 diesel superduty..I park and drive everywhere in the Dallas fort worth area. I also had a 2007 6.0 superduty..aka F250.. Been driving in the city and parking just fine.
Great trucks for towing and around town. It's not a difficult adjustment. Worth every penny. Better to be prepared than not!
Shane
TAC ID TX-1432
Old 02-21-2012, 06:48 PM   #135
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
Not to completely go south..the 2011's to 12's are night and day comparison wise to the 08-10's.
Ride mpg and power.
Shane
TAC ID TX-1432
Old 02-21-2012, 06:48 PM   #136
Mike91208's Avatar
2009 27' FB International
LA LA Land... , California
Yes, seems to be a bit of macho overkill on the TV in these threads (i.e., far more TV than needed). Consider a Ford Edge hauling a 34' 2002 Classic. See link below...
http://www.airforums.com/forums/f238...ml#post1109934
Mike91208 is offline   Reply With Quote
Old 02-21-2012, 06:55 PM   #137
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Shane, agreed.... Timmah specifically mentioned a 2008 F250 diesel 6.4L that he was considering. I think anything newer is not a consideration here, based on price range.
Hibby
Old 02-21-2012, 06:59 PM   #138
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
I agree with this too... A diesel is certainly not required, nor is a 3/4 ton truck. However, you may like the 25' so much that you upgrade to a 30' trailer and then you'll have to change the TV too. It's a thought to consider. We just upgraded from a 22' to a 30' and I'm SO glad we already had the F250 for our other needs!
Hibby
Old 02-21-2012, 07:37 PM   #139
casa3805's Avatar
Images: 41
Really?
Diesel is better than Gas.
Gas is better than Diesel.
My brake is bigger than your brake.
That axle will never make it, you need one like mine.
3/4 is better than 1/2
1/2 is fine, don't need 3/4
Tundra is better than Ford.
Ford is better than Tundra.
Weight rating is good
Weight rating is bad.
Sometimes we need to take a step back and just go with our gut. Style matters!
IMHO, one simply needs a TV with class!
Name:	Jack Black.jpg
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 02-21-2012, 08:13 PM   #140
r carl's Avatar
Lin , Ne
It appears a gas 3/4 ton wins overall.
Aluminum vs Steel Roof Truss masseyfarm Classic Motorhomes 16 12-11-2014 03:04 PM
ST vs LT tires Phil&Sher Tires 125 08-31-2012 02:11 PM
235/75R15XL vs 225/75-15 trailer tire perryg114 Tires 129 07-18-2012 01:59 PM
Full timing and the eternal toilet question... racer155 Full-Timing 20 03-03-2012 06:33 PM
Classic 1969 airstream 18' travel trailer with factory air & full bathroom ca eBay Watch Airstreams on eBay 0 02-12-2012 06:50 PM
