Old 03-02-2010, 03:10 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Front mount spare tire carriers
Long ago, my grandfather bought a 1977 Blazer. After a couple of years he relocated the spare tire, which was then carried inside the rear cargo area, to a spare tire carrier in front of the grille.
No one seems to make these sorts of setups any more and I suppose that given the fact that factory SUVs and pickups alike increasingly mount the spare between the frame rails underneath the rear cargo area, this isn't as compelling a problem as it once was.
Obviously cooling air would be obstructed which would be one disadvantage.
The advantage is that balance is improved when towing a trailer, and the rear deck area is freed up for a fuel tank or generator.
I've seen some front receiver mount setups that could be combined with a tire carrier but these seem unlikely to be satisfactory. Play would be the main problem.
Old 03-02-2010, 03:20 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I had a front mounted spare on a number of tow vehicles over the years. Never noticed any affect on the cooling at all.
It has been a few years since I have seen this done.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-02-2010, 05:12 PM   #3
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
This is interesting... I was planning on putting the A/S spare on a tire mount in the front receiver... reduce tongue weight, add to steer weight
My 8.1L runs hot, and I figured cooling would probably be my only concern...
Then again, how much difference would 25lbs make?
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
spare tire mount Judy Barde Wheels, Hubs & Bearings 5 06-12-2008 07:59 PM
Front mounted spare tire & cover FreshAir Tires 2 06-06-2006 08:23 PM
Front spare tire mount walter1 Tires 4 10-07-2004 11:05 AM
Where to mount spare tire 74SovereignInt. Tires 26 11-27-2002 10:00 PM
