Old 07-07-2014, 01:10 AM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Formula for calculating tongue weight?
Is there a formula for calculating tongue weight based on the actual weight of the cargo and water?
I'm wondering what percentage of the used portion of the "Net Carrying Capacity" should be added to the A/S published unladen hitch weight to arrive at a Tongue Weight. I need that figure to add to occupant and cargo weight in order to see how close I am to the max payload of my tow vehicle.
Also, should the hitch and weight distribution system weights be assigned to tow vehicle or to the trailer?
I'm also interested in how the weight distribution system setup might affect the payload calculations of the tow vehicle and the trailer? Is this actually important?
My 2013 International 19 has a "Hitch Weight (w/LP & w/o options, water & cargo)" of 550. A "Unit Base Weight w/LP & w/o options, water & cargo) of 3823. "Gross Vehicle Weight Rating" of 4500. "Net Carrying Capacity" of 677.
2013 Dodge RAM 1500 Outdoorsman Crew Cab 4x2. 1403 pound payload...max cargo and occupants (door sticker-not RAM website).
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 07-07-2014, 05:15 AM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Why have two threads about the same subject. The current discussion is here:
http://www.airforums.com/forums/f238...ts-121859.html
Doug and Cheryl
Old 07-07-2014, 05:27 AM   #3
2004 16' International CCD
Chicagoland , Illinois
Not that we can probably get ahold of. AS might have a computer model of these relationships? You would need to know where each of the loads rests on the frame.
Without an actual tongue weight I would assume that it is 15% of your GVWR. This number will likely increase if your water tank is located in-front of the axle, and is full of water. If you've actually weighed your tongue at 550 lbs. then I would divide 550/4500 = 12.2%. If you have a tongue scale you might try filling up the tank and loading up your cargo. I received a rude-awakening when I did that exercise.
I assign them to the tow vehicle. My assumption is that the majority of the parts are physically hanging from the TV's hitch receiver. Generally only brackets are mounted on the trailer. I'm using an Equalizer brand hitch. Other brands of hitches might need to be treated differently.
I don't think that it is important, but I'm not absolutely sure.
Airrogant is offline   Reply With Quote
Old 07-07-2014, 08:16 AM   #4
2016 30' Classic
Erie , Colorado
This would be the same math that a pilot uses to calculate weight and balance for an aircraft. Arms and moments calculation. You would need the starting weight at the axles and tongue. Using a datum point (like the hitch) measure from that point to each spot where you are adding weight. Then do a bunch of math to get close to the weight shift addition. Frankly not worth the effort for all of the different ways you can load a trailer. Better to take it to a CAT scale.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-07-2014, 12:36 PM   #5
I ordered a Sherline Trailer Tongue Weight Scale. This should take the mystery out of tongue weight calculation for various truck and trailer load combinations.
Old 07-07-2014, 02:02 PM   #6
dkottum's Avatar
It has limited value. You need to weigh the truck (without Airstream) ready to camp at a truck scale. Then weigh the combination hooked up and ready to camp and weight distribution set, with the Airstream axles not on the scale. The difference is the payload the Airstream adds to the truck. It costs a lot less than a new scale and will give accurate payload results, which the Sherline scale alone cannot.
If you read the current thread referenced above in post #2 there is a good discussion about tongue weight and it's many variables.
Doug and Cheryl
Old 07-07-2014, 02:39 PM   #7
I intend to do what you describe. However I feel that there is value in knowing tongue weight when placing and distributing cargo in the trailer.
I've fine tuned my Reese weight distribution system for level riding and good handling so I don't want to change that.
Old 07-07-2014, 02:42 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can use a bathroom scale and a few boards to get your tongue weight. So load the coach as if it were ready for travel. Then weigh the tongue weight with a bathroom scale.
Look on the Internet, there are instructions on how to do it.
OR
Weigh the trailer alone at the scales.
Weigh the truck alone at the scales.
In both cases, they should be packed and ready for travel. You and all passengers should be in the TV when weighed.
Hitch the trailer to the truck. Then get the truck weighed on the scale, trailer not on the scale. The difference between the truck only weight and the truck with the trailer hitched is the tongue weight.
TG Twinkie is online now   Reply With Quote
Old 07-07-2014, 02:42 PM   #9
dznf0g's Avatar
Oswego , Illinois
Yes, agree. I have a Shurline and use it as a quick pre-trip check when I've made significant changes to the load for that particular run. They are a good tool but have accuracy limitations.
-Rich-
Old 07-07-2014, 03:54 PM   #10
It's 110 miles round trip to the nearest CAT scale. I realize that the Shurline measures in 50 lb increments but it looks like a good place to start. Besides I can share with friends on rallies in exchange for beers.
Old 07-07-2014, 04:20 PM   #11
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
With that combo I wouldn't be too worried about the payload unless the Outdoorsman has worse payload than my Laramie.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-07-2014, 04:30 PM   #12
This RAM's advertised payload is 1646. The door sticker says 1403. It's going to be close with my new camper shell.
Old 07-07-2014, 04:32 PM   #13
Nomadic , USA
Ahh, I gotcha! Surprising how much those shells weight, I was going to get one myself, but opted to just stick with the flip bak.
Like you, the nearest scale is a hike and a half, thats why I started the other thread.
Old 07-07-2014, 04:37 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You don't need a CAT scale for the process I described above.
Any truck stops near you?
Calculating Tongue Weight at the CAT scales? SteveSueMac Hitches, Couplers & Balls 39 03-23-2017 05:44 AM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Weight Distribution formula in Excel TexasGreg Hitches, Couplers & Balls 4 06-23-2009 10:02 AM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
