Old 03-24-2016, 06:34 PM   #1
BW1
1991 29' Excella
Rockwood , Ontario
Ford's Pro Trailer Backup Assist
Has anyone out there actually tried out an F150 with the Pro Trailer Backup Assist??
First of all you you have to take 4 measurements so that the truck knows exactly how much junk it has attached to its trunk.
1)Distance from the truck's license plate to the hitch (will a Hensley cause trouble?)
2)Distance from the hitch to the front of the trailer
3)Distance from the backup camera lens to the centre of the sticker (Ford supplies these for you to use)
4)Distance from the tailgate to the censer of the trailer's axle
Then you enter all this information into the screen and you are ready to go.
Has anyone made it past this to try it out? Just wondering if our Airstreams have some strange measurement that will not compute and the whole system will not work for us.
Practice makes perfect and watching this on a video with a small boat trailer and in a parking lot…it sure looks awesome!
Or..is it a complete waste of money??
Any thoughts?
BW1 is offline   Reply With Quote
Old 03-24-2016, 07:31 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Not much conversation here on this
http://www.airforums.com/forums/f463...-a-147273.html
MICHAEL
Old 09-06-2017, 07:27 PM   #3
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I did attempt this but we have to much junk on our tongue. Propane tanks etc. I was not able to complete the measurements so was not able to use this feature.
TinCan
graysailor is offline   Reply With Quote
Old 09-06-2017, 07:56 PM   #4
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
It is possible to make the system work with an AS.....at least it does with my 25' FC.....with a few caveats.
With the sticker placed in the location shown in the picture below, it is just outside the minimum of 7" from the center of the hitch ball as stipulated by the Ford setup instructions. This is the one parameter that might be an issue on some Airstreams. In any event, after entering all the measurements, and with the sticker placed as shown, the computer in the truck picked up the sticker on the first try and was able to calibrate itself properly.
The system works really well most of the time, and it's easy to maneuver the trailer by turning the dial on the dash. Input is intuitive; you turn the dial in the direction you want the trailer to go and the steering wheel spins on it's own. Just don't touch the wheel as the system thinks you are trying to take over manually and will abort.
But (you know there has to be a but) there can be problems. It seems that in some lighting, particularly in dappled sunlight as with light shining through leaves, the camera will lose the sticker. There have been times backing up my steep driveway when the system will abort at a crucial time and on those occasions I've been so frustrated by this I just turn it off and back manually.
Like I said, when Backup Assist works it works amazingly well, but it's not perfect.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 09-06-2017, 10:02 PM   #5
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Nice hear about how it does.
Hope to hear from more folks about it.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 09-06-2017, 10:36 PM   #6
Dave-n-Janet's Avatar
Moss Point , Mississippi
I placed my sticker on my 26U and F150 just like MikeInCa. Works well. I have a tough (for me) backup into and down my driveway. Worst thing is when I touch the steering wheel which kicks it out of backup assist then I must take out of R and let it reacquire the sticker which takes about 20 secs. I suppose someday I should learn to backup trailer without it, but makes it quite easy so not much incentive. It's real nice on passenger side back-ins as well.
Dave-n-Janet is offline   Reply With Quote
Old 09-07-2017, 07:13 AM   #7
MWBishop's Avatar
Huntsville , Alabama
I tried it with my F150 / RPod combo.
Worked ok, but found the acquire time unreasonable if traffic waiting, if acquired at all.
Now have F250 / 26U so no longer have the option.
I think just learn to back without it.
Don't become dependent on a technology few TVs have.
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 09-07-2017, 11:54 AM   #8
mikeinca's Avatar
2018 30' Classic
I agree that it's best not to lean on the tech and instead learn how to DIY.
Just as an aside, does your 2017 F250 Platinum have the tow camera option? If so, then it also has a Backup Assist feature that uses the same computer/camera/sticker components that the F150 does. It won't turn the wheel for you but it does give info in the center stack display that includes a virtual steering wheel that assists with which direction to turn the actual wheel, a gauge to avoid possible jackknife situations, etc.
200W portable solar
Old 09-08-2017, 07:07 AM   #9
MWBishop's Avatar
Yes it does!
Have not played with it yet - on my list.
Thanks for reminding me.
2017 F250 Platinum
Old 09-08-2017, 08:15 AM   #10
TinCan
graysailor's Avatar
2016 30' Classic
I do enjoy fiddling with new technology but I also do not rely upon it.
TinCan
Old 09-17-2017, 07:43 AM   #11
2017 28' International
Baileys Harbor , Wisconsin
I have it on my F-150. It makes back up my cargo trailer a breeze. But that thing jackknifes so easily. The AS does work, BUT you must go very slow and cannot turn too sharply otherwise the camera looses the marker. Just stop. Pull forward a bit to pick up sticker. Back up again. At first I got frustrated and just backed up manually. But backing into my driveway is a bit tricky. So I tried it again and moved slower and tried not to turn sharp. With very little practice I parked exactly where I wanted to with little effort.
I personally like it. I can back up by myself. But not as proficient as I would like. Probably over time that will change. If I have time, do it myself. If it is a tight spot use the assist.
But as I said if you have a cargo trailer it works SUPER. That thing always want to get out of wack and with the assist I backed up first time using it in a very difficult spot and didn't have to stop once. It was amazing.
Daquenzer is offline   Reply With Quote
Opinions on F150/Pro Backup Assist/25'+ clamb Tow Vehicles 39 09-29-2017 12:56 PM
Volkswagen Trailer Assist - Commercial bono Towing, Tow Vehicles & Hitches 3 01-19-2016 05:54 AM
Ford's Pro Trailer assist sroach Towing, Tow Vehicles & Hitches 2 01-12-2016 09:11 AM
Pro trailer back up assist Papa smurf Towing, Tow Vehicles & Hitches 0 01-11-2016 01:48 PM
Ford Dynamic Hitch Assist cwf Towing, Tow Vehicles & Hitches 2 12-12-2014 05:52 PM
