09-14-2013, 06:00 AM
#41
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by mojo
Sorry but I don't see the max trailer weight as meaningless. My Lariat ecoboost is rated to tow 11,300 lbs. Of course that is with the truck empty with no added accesories. One driver at 150 lbs and full tank of gas is included. Payload capacity is 1755 lbs., so subtract the hitch weight and you have the amount of weight you can add to the payload in gear and people. This then needs to be subtracted from the trailer weight as well. But by loading gear into your trailer and carefully monitoring the placement you can affect the weight distribution in the trailer as long as you don't exceed the GWR of the trailer. So I have no problem towing a 7300 lb trailer without exceeding hitch weight or payload. You can not make blanket statements solely based upon what your Toyota can do and what you personally pack.
Be careful how you rate the load capacity of your AS, you are in the same position I am with our Classic.....7300lb GVWR on 7000lbs worth of axles.
JC has updated the axle ratings on some of the newer models, I hope they also updated the axles.
__________________________________________________ _________________
Model: 2006 25' FB Safari
CHASSIS
7300 Lb. GVWR • 7000 Lb. Axle System • 5870#UBW • 1030#NCC • Styled Aluminum Wheels • Radial Black Wall Tires, LRD 15" • 12" Electric Drum Brakes • Stabilizer Jacks w/Pads (4) • Double Steel Step • Manual Hitch Jack • Spare Tire Bracket
09-14-2013, 07:48 AM
#42
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
Yes but not all of the weight is resting on the axles. The jack stand and hitch carry a portion of the weight. I have spent a lot of time with a Sherline hitch scale and unlimited weighs at the local co-op scales in order to measure various set-ups with my Ford Ecoboost and VW Touareg. Remember, all of the manufacturer ratings are calculated numbers based on some theoretical formula. I'm not aware of any manufacturer that has done actual tests adding weight until something breaks in order to set empirical towing and hitch and payload weights.
I'm not saying it is safe to ignore these numbers but I do average around 15K miles of AS towing annually and have been doing so with these vehicles for the past 7 years so I am pretty comfortable with what they can do when at max limits.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
09-14-2013, 07:59 AM
#43
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Please tell that to the CAT scales.....
I believe these tickets accurately represent the "on the road load" for our Classics' axles. (un-sprung excluded).
I would feel much more better with 500lbs wiggle room.
Not to mention adding a little to our 676lb CCC, a bit of a joak in itself.
09-14-2013, 08:33 AM
#44
Lost in America
Santa Fe
, New Mexico
Yeah, I've got a varied collection of weight tickets, none of which match as I am continuously adding and subtracting items and testing different methods of packing with both tow vehicles. Just need to learn what you really need and what you don't based on where you're going and kind of camping planned.
09-14-2013, 08:42 AM
#45
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Thats our problem also....and exactly why I would love a little more actual CCC.
It's also why the trailer goes on stands for Winter storage.....save the axle's for actual road work. (better for tires too)
09-14-2013, 08:45 AM
#46
Common Sense
Bob, I know you have a heavier tow vehicle than I did when I towed the 25' Classic, but you must carry A LOT of really HEAVY STUFF in your trailer as you are almost 1600 pounds heavier than I was.
Regards,
Steve
09-14-2013, 08:50 AM
#47
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yep....set for 3wks 'dock'n. on that trip.
I was waiting in the grocery store parking lot when the DW came back with at least 250lbs more STUFF
04-12-2014, 03:45 PM
#48
We have a 2013 Ford F-150, 6 cylinder with Ecoboost. In September we took a 7,000 mile trip towing our 25 foot 1997 Airstream Excella, round trip to the Grand Canyon. We had no problem towing at all. Our gas mileage while towing was between 11 and 12 mpg.
The most interesting experience was towing out of the Palo Duro canyon in Texas. The incline is approximately 10 degrees for about a mile. The F-150 never got over 2,000 RPM, and came out of the canyon with no problem at all. We are quite satisfied with the F-150.
04-14-2014, 10:12 PM
#49
2020 30' Classic
Derwood
, Maryland
I guess sometimes ignorance is bliss...
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
04-15-2014, 04:45 AM
#50
1984 34' International
Toronto
, Ontario
Would you care to elaborate on that?
04-15-2014, 04:56 AM
#51
2018 30' International
2014 30' Flying Cloud
Los alamos
, New Mexico
Had a Ford Platinum 6.2 2012, traded it on a 3/4 GMC diesel, pull a 30ft FC throughout Colorado and high mountain New Mexico--normal altitude 7,000- 9,500 ft, torque, braking and mountain grades never an issue.
04-15-2014, 11:29 AM
#52
2020 30' Classic
Derwood
, Maryland
Not following the "Max Payload" of a vehicle as provided by the vehicle manufacturer and only utilizing the tow vehicle ratings.
This has lead to our famous saying around here - "The scales are your best friend"!
Those familiar with these threads will know what I am referencing.
**I Love U.S.A.**
04-15-2014, 11:39 AM
#53
Toronto
, Ontario
Ah. Thank you.
04-15-2014, 12:06 PM
#54
2020 30' Classic
Derwood
, Maryland
Ah. Thank you.
I will admit though, I am the first one to sometimes "overanalyze" something so....
**I Love U.S.A.**
