Old 05-01-2007, 10:13 PM   #15
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
I wil bet that none of you have disc brakes on your trailer. My buddy bought a brand new Ford with the Towcommand and a new 2007 Airstream with disk brakes after many phone calls to Ford and Airstream the Towcommand was not compatable with the disk brakes from Airstream. He installed his Prodigy and it works great with the disk brakes. He also tows an older Airstream with electric brakes and loves the Towcommand . Just my Two Cents.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 05-01-2007, 10:36 PM   #16
_
Originally Posted by Andrew Selking
I wil bet that.....
another example of why gambling isn't profitable...
cheers
2air'
Old 05-02-2007, 05:42 AM   #17
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Just a quick note for those of you that may prefer a Chevrolet or GMC over a Ford. GM now has it's own integrated trailer brake controller available on it's new 2500 & 3500 pickups (I think the 1500's will eventually also have this option). I've never driven one, so I have no personal experience with it, but I expect it will offer the same advantages as the Ford Tow Command system over any after market trailer brake controller.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 05-02-2007, 06:36 AM   #18
1990 34' Excella
Windcrest , Texas
Tow Command all the way
I have the tow command and it offers much more than a brake controller does. In my F-350 its' wired into the dash so if the trailer plug comes loose you get a solid 'buzzer sound' and the odomoter flashes "Trailer Disconnected."
Its also at dash level and easier to see then anything under the dash. Everything else has already been mentioned.
One other point I'll make is that this system combined with the TOW/HAUL feature of our diesel automatically downshifts when needed. In essence you get the advantage of engine braking without having to shift on the column.
Of course we'll always have the Ford vs GM argument
Mitch
Swanny is offline   Reply With Quote
Old 05-02-2007, 09:47 AM   #19
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Not true! I have the tow command with disc brakes on the trailer and the actibrake. I was told both wayss but the actibrake bulliten says the tow command is compatable. Depending on when they bought the trailer, the actibrake will need a software update.
Michelle TAC MT-0
Sarah, Snowball
Old 05-02-2007, 11:11 AM   #20
casarodante's Avatar
2012 31' Classic
Back 'in the day', my father would put on a brake controller on the tow vehicle (station wagon) that would connect directly to the hydraulic brake line. This way it would know how much brake pressure being applied. I feel this is the best way to go if you can. I think the Towcommand uses this method. Although it is nice, I can't justify getting a new F-x50 just for that feature. Well, not yet at least.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 05-02-2007, 11:36 AM   #21
CanoeStream's Avatar
St. Cloud , Minnesota
No we wouldn't -- this is an Airstream discussion forum.
Think we're talking apples and apples here. Similar discussion on GMCs with special attention to Allison Grade Braking (thanks to BillTex): http://www.airforums.com/forums/f463...tml#post334044
5 meter Langford Nahanni
Old 05-02-2007, 09:03 PM   #22
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
08 F250
Please forgive me for I am new and my input is worth about -.02 but I've just bought an '08 F250 to pull a 2000 34' Limited.
1. I bought it to get the tow command/electric brake controller. I've only towed the trailer for 300 miles and it works great so far.
2. I've investigated upgrading my electric brakes to hyd discs and have already received this info from Actibrake:
"Duane:
Thank you for your email. The built-in Ford brake controller has undergone several revisions by Ford. Their original versions in the 2005 model year had numerous issues and we don't recommend using their 2005 brake controllers with our unit. However, the 2006-2007 built-in Ford brake controllers should work fine. The Ford brake controllers can be disabled by your Ford dealer and a standard Hayes or Tekonsha controller can be installed. You can review our owners manual at www.activetech1.com (please review the newest of the two ActiBrake models on this site) as a pdf which can be downloaded and printed. This manual lists the recommend brake controlles on page 10. Thank you for your interest.
Best regards,
Phil Stanhope
Active Technology"
Now I can't find a follow up email where Phil says they haven't evaluated their system with the '08 yet but said it should work fine.
And this from Rick March at Jackson Center at Airstream:
Duane, yes the system should work fine with the Ford controller.
Thanks Rick
Sent: Tuesday, May 01, 2007 7:30 AM
To: rmarch@airstream.com
Subject: Re: Kodiak brake upgrade
Thanks Rick, and forgot to ask in my first email. No problems running the system off of Ford's F250 integrated tow command/brake controller system?
3. Tailgate Step. To get the truck I wanted it came with the tailgate step. I didn't think I needed it. I've had the truck only two weeks and have found it to be very useful already. Someone earlier mentioned something about it's safety. Well, it may be a problem if you weigh over 400 pounds but for me its worked great getting up into the bed and back down. Don't see anything unsafe about it.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 05-02-2007, 09:47 PM   #23
_
Originally Posted by dpandorf
The built-in Ford brake controller has undergone several revisions by Ford. Their original versions in the 2005 model year had numerous issues and we don't recommend using their 2005 brake controllers with our unit.....
hi duane...
it's always interesting when one vendor describes the 'revisions' made by a different vendor...
IF you really want to know IF/HOW the ford ibc has changed...
contact FORD
i have a 2005 ford and the controller works PERFECTLY with the 2005 a/s disc brake package approaching 40,000 miles of towing...
with one exception described in the threads below...
and in THIS tsb from henry...
http://www.cvsa.org/resourcecenter/d...tin2005-01.pdf
actibrake's system has undergone changes however between 05 and 06...
visit the actibrake website... SEE the 2 manual versions? mine is version one...
Active Technology-Manuals
in addition actibrake has at least 3 different systems available...
perhaps ford has modified the software (i don't believe they have) but it is my understanding the hardward is the same from 05 through NOW....
check the ford parts # or visit your dealer/parts shop...
craftsman/2 had issues with his 06 systems and ACTIBRAKE sent him modifications...
we've tried to document these issues here so visit the brake/controller threads or read a bit here...
http://www.airforums.com/forums/f439...kes-19936.html
see post 6 below...
http://www.airforums.com/forums/f439...tem-27295.html
and again craftsman/2 describes and photos of the actibrake modifications (post 26/30)
http://www.airforums.com/forums/f439...-up-28809.html
added to the confusion is actibrake/kodiak vs dexter on the a/s side of the equation...
no doubt your 6 drums stop nicely but IF you do opt for a disc upgrade, the difference is significant...
cheers
2air'
Old 05-02-2007, 11:21 PM   #24
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
My two cents worth!
Hi, I can not verify this, but I believe the Ford tow command system is made by or with Tekonsha. Reason I say this, is our trailer brake testers, at the Ford dealer are also made by Tekonsha. [Ford Motor Company / Rotunda special tools and test equiptment.]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-03-2007, 04:53 AM   #25
dpandorf's Avatar
2000 34' Limited
Originally Posted by 2airishuman
hi duane...
cheers
2air'
Thanks 2air, I just wanted to add my -.02 worth since I'm in the middle of trying to decide if I want to invest those additional funds after my initial outlay into this new venture so to speak.
Heck we've only slept in the thing one night and that was when it was parked around the corner!
Duane Pandorf
Blog | Google+
Old 05-03-2007, 07:55 AM   #26
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I read elsewhere that it is made by Tekonsha also. BTW, as I said earlier, I like it a lot.
Family of Disney Fanatics
WBCCI# 4821
Old 05-03-2007, 10:33 AM   #27
_
sometimes the best sort of camping is IN the driveway/parking lot!
IF the brakes are working well and don't need urgent service, just use and enjoy.
no real need to change a well functioning system, there's plenty of time for upgrades...
cheers
2air'
Old 05-03-2007, 11:03 AM   #28
dpandorf's Avatar
2000 34' Limited
cheers
2air'
Thanks 2air. Will just get what I have serviced on the 11th. We're heading to NAS Pensacola on the 14th for that week. Then head back up through Nashville to visit my uncle who helped me get this thing.
So should be a nice maiden voyage.
Duane Pandorf
Blog | Google+
Towing With a 1974 Ford F100 melprice Tow Vehicles 18 04-01-2014 06:34 PM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
1989 370 Ford 460 Overheating ViewRVs Mechanics Corner - Engines, Transmission & More... 14 07-05-2004 03:46 PM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 08:33 AM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
