Old 12-24-2009, 08:02 AM   #1
i have moved north to VIRGINIA CITY , Nevada
Ford spark plug problem?
I was reading in another thread about this spark plug problem. does anyone know if they fixed this or.... should i not even think about a 5.4 ford gasser. 2009 or 2010.
i am considering a smaller AS now and thinking about a gas truck.
i am only looking at buying new.
thanks
AnnieD is offline   Reply With Quote
Old 12-24-2009, 10:18 AM   #2
1976 23' Safari
Ponoka , Alberta
I dont normally see the vehicals until they are off warrenty but a freind of mine that works for Ford said the new engines had the problem solved. He also said one of the new ones and i cannot remember the model takes 8 hrs. to change the plugs might want check some of the flat rate on what you are buying
bill & phyl is offline   Reply With Quote
Old 12-24-2009, 10:29 AM   #3
Road Ruler's Avatar
Images: 38
Looks like the new Fords are OK. This Ford forum discussion talks about it.....
spark plugs and triton engines - Ford Truck Enthusiasts Forums
Old 12-24-2009, 12:12 PM   #4
Thanks guys..... i will look into it further
Old 12-24-2009, 01:38 PM   #5
JimGolden's Avatar
1977 31' Excella 500
They claim to have fixed it in 2003. My 2001 Excursion was a piece of junk (sure did look nice though...) and Ford told me to pound sand when it blew up and was "under warranty" when they refused to cover it.
Now I drive a Cummins powered Dodge and no looking back
But you should be fine now with anything newer than an '03.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 12-24-2009, 03:00 PM   #6
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
What problem? I was told by Ford that mine was the only one that blew out a plug, in the middle of no where, and if it did, it was my fault. (For buying a FORD in the first place). Gives a new meaning to "Built Ford Tough"
I would never believe that they have fixed the problem they say they never had.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 12-24-2009, 04:33 PM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Blowing plugs, eh? Not a big deal if you've owned vintage, late-60s/early-70s beetles.
Lynn
WBCCI 21043
Old 12-24-2009, 07:15 PM   #8
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The "current" spark plug problem is the plug unthreads from the head when you change them, but leaves part of the plug permanently imbedded in the head. I know this is an issue with 2004-2006 5.4 engines, but with 100,000 mile plug change intervals, you may not experience that particular issue if you trade before the truck has 100,000 miles on it.
Old 12-24-2009, 08:48 PM   #9
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
As I said "Built Ford Tough"
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Old 12-24-2009, 08:59 PM   #10
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
No plug problems with my Tundra! Never heard of anyone having plug problems with a Tundra.
So Long!
Bob Thompson is offline   Reply With Quote
Old 12-24-2009, 09:28 PM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Spark plug problem?
thanks
Hi, My 5.4 L Lincoln engine won't have that problem because it is a slightly different animal. [dual overhead cam 4 valves per cylinder] The 5.4 L engine with single overhead cam, two valve heads, were the ones mentioned. Under warranty Ford would not repair these heads, but we were required to replace them with a new head. After warranty, we have a special insert, that will take care of this and save a lot of money. The newer 5.4 L heads are three valve and use a different spark plug; These don't have that problem. This isn't something that happens to all of the effected engines, but a very small percentage of them. High numbers of production will also have higher numbers of failures. [basic math] Sort-of like all Marathons are going to explode and destroy your trailer. It is also recommended to only remove the spark plugs when the engine is cold on engines with aluminum heads or the threads will be destroyed.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Atwood water heater -- light on, no gas or spark dre00 Water Heaters, Filters & Pumps 4 02-27-2009 09:51 AM
Electric Spark Arizona Guys Electrical - Systems, Generators, Batteries & Solar 2 03-09-2007 07:14 PM
1975 Argosy MH 454 proper spark plug gap? cejohnsonjr Mechanics Corner - Engines, Transmission & More... 2 04-21-2006 10:17 PM
Burning Spark Plug Wires geodude1958 Mechanics Corner - Engines, Transmission & More... 10 07-10-2005 07:58 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
