Old 09-24-2016, 11:19 AM   #43
2016 28' International
San Marcos , California
From what I can find in the web the hitch is built into the frame and extends farther forward than a traditional hitch which would possibly account for better weight distribution.
Ford has published the specs, limit is 17,600 for a diesel 4x4 SRW.
http://www.ford.com/trucks/superduty...ations/towing/
Mgieselman is offline   Reply With Quote
Old 09-25-2016, 09:06 AM   #44
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Kinda sorta like a built-in Hensley or ProPride?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-25-2016, 09:55 AM   #45
jcl
Vancouver , British Columbia
No, nothing like that.
If anything, more kinda like how some reinforce their hitch receivers with a strut running fore and aft.
jcl is online now   Reply With Quote
Old 09-25-2016, 11:40 AM   #46
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
What difference would that make? The hitch and ball are behind the pickup,
Old 09-25-2016, 11:54 AM   #47
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I think the Ford statement is only addressing the weight capacity of the hitch. With previous hitches, the hitch itself had separate ratings for weight bearing and weight distributing hitches. Now they say that distinction doesn't exist. So if you can tow 21,000 pounds, anticipating a 15% tongue weight, the hitch can carry 3000 pounds tongue weight. But clearly from OP's picture there is less weight on the front end and therefore more weight on the rear. Consequently steering force might be compromised and the rear axle might be overloaded. Even if they have a rear axle with sufficient margin, IMO there is no getting around the reduced steering and braking force on the front axle. Steering and braking are both dependent on the friction force of the front tires at the road surface and that force is directly proportional to the weight load on the tires.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 09-25-2016, 07:35 PM   #48
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Al gets it right on his post!
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 09-25-2016, 08:04 PM   #49
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Ford says no WD hitch required on 2017 SD.
Moving hitch attachment points forward (given a crossmember integrated receiver) decreases frame flex. Makes adjusting a WDH properly a closer thing. If report is correct it's only about 35-years overdue.
And, whether the truck "can" doesn't take into account wind loads on TTs or the high COG of conventional TTs per J2807 (it's most glaring deficiency). "Weight" is relative, not absolute.
Besides likely better handling, steering and braking in which every pickup is deficient (along a scale; a pickup with IFS and 4-whl disc brakes superior to other designs), maxing WD force increases weight at the TT wheels making them more effective at braking the combined rig.
Trailer braking matters far more than how much a given TV can tow per "ratings". Same for steering and handling.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 09-25-2016, 09:20 PM   #50
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
Al
I think Al is correct in his assessment. The no WD reference applies to those vehicles with the Max Tow package which gives a little stiffer front springs and the new hitch with the 3" receiver. On my 2017 F250 I did not opt for Max Tow as didn't need the extra little payload it provided and didn't want to use two reducers to use the 2" stinger on my PP. All I have read is exactly what Al refers to.
Chuck
silverlabs is offline   Reply With Quote
NorCal : 2017 Olema Spring Rally April 7-9, 2017 (formerly at Casini) HootMon-Frau Forum Rallies & Meet Ups 14 04-01-2017 12:46 PM
2017 Ford Super Duty paiceman Tow Vehicles 13 08-07-2016 08:37 PM
2017 Ford Super Duty Review pappy19 Tow Vehicles 15 03-06-2016 05:59 PM
